Elite Engineering
Old 05-02-2012, 02:41 PM   #1
2011 SS
2011 SS's Avatar
Drives: 2011 SS M6, LT's, CAI, SLP LM II's.
ZL1 problem!
A friend of mine has an ZL1, he just hit break in, shortly before break in I'm assuming 1300 miles or so he gets this loss of power almost like a slip but its not the tranny slipping. If he starts in first and accelerates to 20mph it wont do it but it does it in second and third, no problems at WOT but it is at 20mph every time, its the wierdest problem I cant figure it out. Suggestions? Solutions? Is this normal?
2011 SS is offline   Reply With Quote
Old 05-02-2012, 02:51 PM   #2
Nightspore68
Nightspore68's Avatar
Drives: 2013 Camaro ZL-1, Victory Red
Supercharger belt loose?
Nightspore68 is offline   Reply With Quote
Old 05-02-2012, 02:55 PM   #3
Monte Mac
Monte Mac's Avatar
Drives: 13 1LE, 14 Cruze ECO M6, 84 MonteSS
So he's shifting into 2nd gear before 20 mph??
Monte Mac is offline   Reply With Quote
Old 05-02-2012, 03:24 PM   #4
2011 SS
2011 SS's Avatar
If the belt was loose it would slip off at wot this doesn't occur at wot good guess though thank you. Its an auto it shifts into second right before twenty I believe then has that hesitation at 20 mph on the dot.
Sent from my SPH-D710 using Tapatalk 2
Old 05-02-2012, 03:32 PM   #5
xx_ED_xx
xx_ED_xx's Avatar
Drives: 04 Silverado
Called torque management...
xx_ED_xx is offline   Reply With Quote
Old 05-02-2012, 04:14 PM   #6
mark
Drives: Z06
What he said.
mark is offline   Reply With Quote
Old 05-02-2012, 04:44 PM   #7
hognutz
hognutz's Avatar
Drives: 2013 ZL1
Turn off all traction/torque managment systems. I the tires break grip and the car runs fine it is probabaly the car cutting the power. If the symptoms continue with all systems off then it is something actually causing the power loss.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 05-02-2012, 04:59 PM   #8
Rice Killer
Cooter
Rice Killer's Avatar
Drives: my wife crazy
I don't think you can adjust torque management without a tune. I have been wrong before though.
#1451 - 2012 ZL1 - White, Black Wheels, Manual, Suede Package, and Exposed Hood Insert. Delivered on 6/20/12. Thanks to Jason from Symdon Motors in Evansville, WI.
Rice Killer is offline   Reply With Quote
Old 05-02-2012, 06:09 PM   #9
JMAN311
JMAN311's Avatar
Drives: 2013 F-150 Limited
Watch the Magnetic Ride Control & Performance Traction Management Video that is sticky'd up top in the ZL1 Owner Welcome Videos thread.
http://www.camaro5.com/forums/showthread.php?t=220554
"Push and holding the traction control button for 5sec will turn off ALL PTM modes. Giving you full control of your ZL1."
hognutz is right, this is the best way to confirm if the car is cutting power due to low traction, or if there is a larger issue.
There just might be a 2016 Camaro or Corvette in my future...
Previous Chevy's
2013 Camaro ZL1 A6|SIM
2010 Camaro 2SS/RS|M6|CGM Exterior|Gray Int
2000 Camaro SS|M6|SLP headers|SLP center mounted quad exhaust|Magnaflow muffler|Hypertech programmed
2001 Corvette|M6|LG Motorsports Headers|Corsa Touring Cat-back|Magnaflow X Pipe|Hurst short-throw|Dyno tuned
JMAN311 is offline   Reply With Quote
Old 05-03-2012, 08:38 AM   #10
Monte Mac
Monte Mac's Avatar
I agree with turning off the systems and see if it still occurs or not. I am a manual trans fan myself so therefore I self manage the torque myself
Old 05-03-2012, 08:51 AM   #11
ffrcobra_65
You saying the power nannies are not on manual cars? Doubt it.
Old 05-03-2012, 08:56 AM   #12
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
i think hes stating since he perfers manual transmision he prefers leaving the nannies off too
MY Car
2013 ZL1 Vin 555
Details
Crystal Red Tint Coat/ Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
6 Spd Manual
Road Trip To Buffalo complete shipment from MO has arrived
closs2sx is offline   Reply With Quote
Old 05-03-2012, 06:35 PM   #13
Kluch
Drives: CTS-V
Same problem on an auto V. Turn off stabilitrak completely as mentioned above. Problem will go away. There is traction loss at the change of gear and the power is cut- even in competitive mode. Keeping the MAF sensor clean also minimizes this.
Kluch is offline   Reply With Quote
Old 05-03-2012, 08:43 PM   #14
Monte Mac
Monte Mac's Avatar
Not at all, just less torque management. Automatics are constantly adjusting the torque request from the engine (primarily at shifts) where as a manual trans has none of this during a shift (I like being in control of the shift) the traction control is pretty much all that manages the torque request (or decrease) based on wheel slip. I could be wrong but that's my understanding of the system.
And yes I like to have the "nannies off" from time to time but for everyday driving I keep it safe.
