Old 05-03-2012, 06:49 PM   #1
Gaddism1
Gaddism1's Avatar
Drives: 2010 SS Inferno Orange MT
Question Camshaft Upgrade Cost??
Hi folks, I would like to open a discussion around what a cam upgrade usually costs installed on a 2010 2SS MT. Specifically, a full cam upgrade with springs, push rods, timing chain and dyno tune.....
Thanks in advance!
[B][SIZE="3"]Dynatech LT's Ceramic coated / Dynatech Hi Flow Cats / SOLO Mach X CAT Back Exhaust/ CAI / JRE Scoop / Pfadt Springs / Pfadt Sways and Links/ American Racing Mags / Rough Idle Cam upgrade package with dyno tune from Slowhawk Performance.[SIGPIC]
Gaddism1 is offline   Reply With Quote
Old 05-03-2012, 07:16 PM   #2
Jcobra
Jcobra's Avatar
Drives: 2010 2ss/rs M6
I'd add LT headers to that list and say around $3000-$3500.
Jcobra is offline   Reply With Quote
Old 05-03-2012, 07:45 PM   #3
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
Thanks in advance!
Was quoted $2350-2500 including tune by one shop. As far as I could tell they were only going to replace cam and springs. Said pushrods were good enough and nothing else needed upgraded. I decided to do it myself. I already have all the parts:
Atlantic Speed
Comp 7955-16 Hi-Tech Pushrods .312 x 7.??? $119.95
Comp 13702-KIT Rocker Arm Trunion Upgrade Kit $129.95
Comp 26926TS-KIT LS Dual Valve Spring Kit $464.95
26926-16 Ultra Dual Valve Spring
779-16 Tool Steel Retainers
623-16 7° Steel Valve Locks
511-16 Valve Seals
4695-16 Spring Seats
COMP LSR 54-459-11 (3 Bolt) 281 Lr HR13 $359.95
231/239 .617/.625 113 LSA
TOTAL $1074.80
Lingenfelter
C5R HME-G68V-2 HD Timing Chain $149.95
TOTAL $149.95
GM Parts House
GM 12633904 Front Timing Cover Gasket $19.63
GM 12585673 Front Timing Cover Main Seal $18.45
GM 12630223 Two Water Pump Gaskets 2 x $4.10 $8.20
GM 12557840 New crank bolt $4.15
GM 12586481 3 Bolt Cam Gear $18.45
GM 12556127 3 Cam Bolts 3 x $2.26 $6.78
GM 12588670 LS2 Timing Chain Dampner $14.86
TOTAL $90.52
Summit Racing
MEL-10296 Melling 10296 High-Volume Oil Pump $139.95
TOTAL $139.95
Atlantic Speed $1074.80
Lingenfelter $149.95
GM Parts House $90.52
Summit Racing $139.95
Cam Parts Total $1455.22
Also spent about $300 on tools and this doesn't include a dyno tune. I'll have around $2300 in it for everything. I have seen quotes from $2000-$4000. Just make sure you know exactly what you are getting for your money.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 05-03-2012, 08:24 PM   #4
kaler
kaler's Avatar
Drives: 2011 Dodge 3500 dually Mega Cab
Atlantic Speed
511-16 Valve Seals
TOTAL $1074.80
Lingenfelter
TOTAL $149.95
GM Parts House
TOTAL $90.52
Summit Racing
TOTAL $139.95
I like the specs on your cam By any chance are you going to get a baseline dyno pull. I would like to see how much HP this cam gains in a LS3.
2010 SS a6 with TSP VVT-3 cam,PRC ported heads,Yank 3200,Kooks and CAI inc. = +121 RWHP 1/4 mile 12.1 E.T. On P-Zero Tires.
kaler is offline   Reply With Quote
Old 05-03-2012, 08:26 PM   #5
Bennyb
Drives: 2011 Camaro 2SS
I paid 2600 for full upgrade including labor.
Bennyb is offline   Reply With Quote
Old 05-03-2012, 08:40 PM   #6
RogerBzSS
RogerBzSS's Avatar
Drives: 11 IBM n White 2SS/RS M6
Thanks in advance!
Since you are in Mass I would Call JRE talk with them..
I am scheduled May 15th to drop off
My Plan of Go Fast Goodies installed dyno tuned just shy of 6K$
Cam JRE 415 and other supporting Mods.
Rough Idle Bump Stick Package
Dynatek Headers Hi FLo Cats out the stock cans
CIA with added Air Intake Scoop
SCT Tuner
Ported T Body
Under Drive Pully + Belt
Washer Bottle reloc kit
+ Shop Hours and Misc Materials Oil / Filter / coolant etc
Dyno Tuned
RogerBzSS is offline   Reply With Quote
Old 05-03-2012, 11:18 PM   #7
2010SSRSM6
2010SSRSM6's Avatar
If you were out here in Cali you could get a nice stage 2 cam installed and dyno tuned for $2200. That includes springs, push rods, etc.
Old 05-04-2012, 06:34 AM   #8
jam3
jam3's Avatar
Drives: 2010 camaro ss
JRE is the place to go.
Call Ted and talk with him.
Saving a ccouple dollars could cost you much more in the long run.
Good luck
jam3 is offline   Reply With Quote
Old 05-04-2012, 07:46 AM   #9
Gaddism1
Gaddism1's Avatar
Thanks folks, I have used Ted for my headers and tune. I know he has a top notch shop.
Old 05-04-2012, 08:14 AM   #10
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Yes I am hoping to baseline it and will probably post before and after results.
Old 05-04-2012, 11:40 AM   #11
kaler
kaler's Avatar
I will be watching for your results.
Old 05-04-2012, 12:38 PM   #12
asrautox
Drives: 2010 SS
Where? and was a tune included?
asrautox is offline   Reply With Quote
Old 05-05-2012, 02:36 AM   #13
Bay Area SS
Bay Area SS's Avatar
Drives: 2010 rs/2ss
Complete TSP Cam package, install and tune was about 2k I think
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
Bay Area SS is offline   Reply With Quote
Old 05-12-2012, 07:45 AM   #14
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
Originally Posted by devilmaycry View Post
Most later model of camaro have hydraulic lifters in them. If you using improper oil , then your valve LIFTERS might be clogged up. This will cause engine ticking. If you remove the valve covers and physically SEE that the cam lobes are worn, then it's time to cam shop. I doubt it, sincerely! You should have your engine de-sludged with butyl cell solve and switch to ELF or Mobil One 0W-40 oil. But, only if it meets Alfa's specifications!!! NEVER use bulk oil found at the local quicky lube. Most of those oils have NO specific specifications. They WILL clog up oil galleries and lifters. Ask for proof that your cam are bad before you start buying parts. Most foreign cams NEVER go bad. They are all race tested and proven. Usually, the worst part of the foreign car is the owner, and their ability to read and understand your auto repair manuals.
What the hell are you talking about? Don't think the OP was complaining about a cam issue. Sorry if I don't follow your logic on this one.
Bildo is offline   Reply With Quote
