Cold Air Inductions
Old 05-04-2012, 05:57 AM   #1
bigted83
They call me captain slow
bigted83's Avatar
Drives: 2010 camaro lt
radio reception question
Has anyone else's radio reception got worse after installing the fark harness, I am not badmouthing ********s harness at all or saying its a bad product cuz its not. I just can't pick up the radio stations
bigted83 is offline   Reply With Quote
Old 05-04-2012, 08:07 AM   #2
ITGuy11
Burning up tires
ITGuy11's Avatar
Drives: 2010 Camaro 1SS/RS
Yes! I don't have the FARK, but I do have the ******** RCA output harness and my radio reception has definitely gotten worse...
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12
Detroit 5th Gen Camaro Club
ITGuy11 is offline   Reply With Quote
Old 05-04-2012, 08:24 AM   #3
jeepguy_1980
jeepguy_1980's Avatar
There have been lots of posts of guys complaining that their amps have interfered with their radio reception. The antenna is in the glass after all.
jeepguy_1980 is offline   Reply With Quote
Old 05-04-2012, 08:29 AM   #4
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
nope, fine here
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 05-04-2012, 12:29 PM   #5
Agent WD-40
Agent WD-40's Avatar
Drives: 2010 Camaro SS
Are you using a Class D amp? That is likely the problem.
I experienced this exact problem when I had a Class D amp. I posted this thread on what I did to alleviate the problem. As I mentioned in the thread it probably fixed about 90% of the problem. If I stayed in town my reception was OK with most stations, as I got out of town my reception got weaker than it did when stock.
I did a bunch of research on this, spoke with JL Audio tech support, etc. From what I learned this is a problem in general with all Class D amps. They can interfere with radio reception. The guy I spoke with at JL said he has done tons of installs with Camaros and Corvettes and a few have had issues but most don't. Some types of cars are more sensitive than others, but a lot of it is specific to the installation of the equipment (where amps are mounted, where the antenna is located, length of the wires and where you run them, etc).
As I'm sure you have here seen here on Camaro5 there are lots of people using Class D amps. It seems like some have problems, lots don't. I know there are lots of other people using the exact amp I started with without issue. I suppose some of the people not reporting problems may never be listening to the radio but I'll bet most people do listen to the radio.
My final solution was to replace my Class D Amp with a Class A/B amp. Now reception is back to exactly the way it was stock. I spend enough time traveling out of town that I wanted better reception.
I still have all of the ferrite clamps I used but don't need any more. PM me if you are interested in buying them from me. Radio Shack and Parts Express both sell these new.
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete
Roto-Fab Intake
Stainless Works 1 7/8" Long Tube Headers
Corsa Exhaust
Agent WD-40 is offline   Reply With Quote
Old 05-04-2012, 12:48 PM   #6
jeepguy_1980
I was hesitant to get the HD900/5 aftrt I read Agents previous thread. But I went with it anyways and haven't had any reception problems.
Then again, I never really thought the camaro had good reception to begin with.
Old 05-09-2013, 02:59 PM   #7
y2jdmbfan
Drives: 2013 IOM ZL1
Where did you install your HD900/5?
y2jdmbfan is offline   Reply With Quote
