| Transmission / Driveline Shifters, differentials, gears, rearends, clutch |
| View our official forum sponsors list. |
Thread Tools |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 X5 Camaro Turbo Join Date: Apr 2012
METCO Driveshaft Safety Loop – 6-spd & Auto @ Phastek Performance
METCO Driveshaft Safety Loop – 6-spd & Auto :: 2010-2011 Camaro
![]() 2010+ Camaro Driveshaft Safety Loop by METCO The ONLY driveshaft loop for the 2010 & Newer Camaro that requires NO DRILLING for installation! This bolt-on driveshaft safety loop is designed exclusively for the 2010 and newer Camaro SS equipped with either the six-speed or automatic transmission. This driveshaft safety loop is an original Metco Motorsports design and no modifications to the vehicle are necessary for installation. The loop can be installed without having to remove the driveshaft and it is compatible with popular aftermarket exhaust systems. The mounting brackets, support bracket, and hoop that comprise this kit are made from laser-cut high-grade steel, which is then precision-formed on a CNC press. The components are powdercoated in black for appearance and long-lasting surface protection. ![]() The two mounting brackets attach securely to the transmission mount studs, and the loop support bracket mounts to these brackets at four points, adding great strength and vibration resistance. The loop is positioned in the driveshaft tunnel above the exhaust system, providing maximum clearance for all surrounding components. And unlike the competition, it is not necessary to drill holes in the car's transmission crossmember for installation. If it is ever necessary to remove our loop from the vehicle for selling purposes or warranty work, no one would ever know it was there. The kit includes illustrated installation instructions and all necessary hardware. No special tools are required for installation. Note 1: Since these photos were taken, this driveshaft loop kit has been revised slightly so that the bolts that secure the loop to the loop mounting bracket thread downward from inside the loop into the bracket (instead of up into the loop feet, as shown). This change was made to create additional clearance for aftermarket exhaust systems. Note 2: The images above show the loop kit mounted to the OEM six-speed crossmember and transmission mount. These components are shown for illustrative purposes and will not be included in the kit. Installation for the automatic application differs minimally. Place your orders at www.PhastekPerformance.com |
Taking orders
Place your orders
post or pm with questions
HI !
#6 |
taking orders
#7 |
Place your orders
#8 |
Burning up tires
Drives: 2010 Camaro 1SS/RS Join Date: Jul 2010
Does this safety loop work with larger diameter aftermarket shafts?
Blower, cam, supporting mods 644RWHP 615RWTQ
My Build Thread COTW 11/19/12 Detroit 5th Gen Camaro Club |
#9 |
Enjoys a good train wreck
Drives: 2010 IBM Camaro 2SS/RS Join Date: Nov 2009
#10 |
![]() ![]() Drives: 2012 ZL1 Join Date: May 2012
Will this work with a ZL1 automatic?
#917. Black/Black wheels. A6, ECFW hood, sunroof, cargo mat, cargo net, optional floor mats. ADM race air intake, ATI/Lingenfelter balancer (10" ring), stock upper pulley, 90mm TB, ID850s,Rotofab/Lingenfelter intercooler reservoir, Cooler Logic HX, Lingenfelter idler relocation bracket, NGK TR7ix, 160 t-stat, Dewitts Radiator, Texas Speed 1 7/8" headers(no cats), Mickey Thompson drag radials 305/35-18. Tuning by Frost. 11.007@125.32 1.62 60'
#11 |
I would like to hear from a vender that this loop has a larger diameter than the BMR loop that I have installed with my DSS driveshaft...because my BMR rubs/clunks when hit potholes or washboard bumps
DSS 1400HP axles, DSS driveshaft.
BMR driveshaft loop, 1" lowering springs, sways, trailing arms, toe rods, links, total suspension pro-version poly bushings. 1 7/8 ARH long tubes, 3" cat back, Dynomax VT axle-back. Edelbrock E-force SC with 3.25" pulley, JRE e-force fuel rail mod, 850cc Dynamic injectors, LPE twin fuel pump, JRE rough idle blower cam kit, Roto-fab e-force intake, RX catch can. Jannetty Racing Tuned: 622 rwhp / 582 rwtrq |
| Thread Tools | |
