Solo Performance
Old 05-04-2012, 10:29 AM   #1
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
Dynoing car Saturday and need advice
Hi all,
I'm dynoing my car on Saturday. I don't know whether to dyno in 3rd or 4th. I have never done this before, so any advice about dynoing is appreciated.
My car is a V6 Automatic 2LT.
Thanks,
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 05-04-2012, 10:32 AM   #2
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Are you the one who's actually going to dyno the car? It's usually a 4th gear pull.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline   Reply With Quote
Old 05-04-2012, 01:05 PM   #3
Rangore
Rangore's Avatar
Yeah...It's a Dyno Day for my Camaro Club in the area.
Why do some posts I looked up say 3rd gear and some say 4th gear?
Old 05-04-2012, 04:13 PM   #4
hightower
LS3 Black Widow
hightower's Avatar
Drives: 2012 45th 2SS LS3 and 1968 Mustang
You probably won't be doing the dyno itself. Normally a technician does it there. I'm pretty sure it's a liability thing. Especially if they have a dyno that's off the ground. They don't want somebody dropping a car off the dyno.
And different shops do it different ways as I've seen.
hightower is offline   Reply With Quote
Old 05-04-2012, 05:06 PM   #5
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
4th
Old 05-04-2012, 05:38 PM   #6
dshep214
dshep214's Avatar
Drives: 2011 Camaro 2ssRS Ls3
I've seen 4th and 3rd. Most do 4th gear pulls bc there's not as much kick!
I am here: http://tapatalk.com/map.php?vzlt2y
dshep214 is offline   Reply With Quote
Old 05-04-2012, 06:22 PM   #7
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
For the V6 auto, 3rd is the most popular gear so if you just get one run go with 3rd, but if you get the chance try a run or two in both 3rd and 4th.
4th is usually used by the manual V6ers.
Old 05-04-2012, 06:47 PM   #8
1981DFA
Drives: 2006 GMC serria
It is suppose to be the 1:1 gear. If you dont have a true 1:1 gear then you should do the pulled in the gear that is the closest to 1:1.
1981DFA is offline   Reply With Quote
Old 05-04-2012, 08:26 PM   #9
Silverlsinva
Silverlsinva's Avatar
Drives: 2013 Fiat 500 Abarth Grigio
If the car is speed limited to 118mph like most are that dont have the z rated tires ull hit it before the car is going in 4th i believe so had to do in 3rd.
Silverlsinva is offline   Reply With Quote
Old 05-05-2012, 06:50 AM   #10
Rangore
Rangore's Avatar
Mine is the 2LT with 19" wheels...no speed limiter that low I believe.
The place we're going says it's Mustang Chassis Dyno. This particular dyno is a loading dynomometer it also says.
2lt, advice, dyno, llt, v-6
