JUICEDMOTORSPORTS
Old 05-09-2009, 08:45 PM   #1
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
So, what are ideal track conditions?
Just thought I'd post up this question because there is a lot of talk about poor conditions but I'm sure there are a lot of members on here who either don't know know for sure, or don't have any idea at all.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-10-2009, 08:15 AM   #2
Rock36
I just like V8s
Rock36's Avatar
Drives: 2007 Corvette Z06
Ideal track conditions would be something along the lines of having a density altitude (DA) of 0 ft or less.
A perfectly level track with no wind, especially no headwind.
And a well preppred launch pad with enough traction compound to limit wheel spin like:
http://www.bazellracefuels.com/strip...n_compound.htm
http://www.jegs.com/i/VHT/870/SP162/10002/-1
"Anyone know who sells the driver mods?"
2007 Corvette Z06: Le Mans blue, 2LZ
Rock36 is offline   Reply With Quote
Old 05-10-2009, 08:46 AM   #3
Phenix
Drives: 2015 Camaro 1SS/RS 1LE
^^^what he said
Also people might wonder what's this density altitude jargon...
Some brainiacs in a land far far away long ago decided to determine a "standard atmosphere." They did this so that you can have a standardized starting point when measuring the performance of anything that is affected by the atmosphere, in our case here that's engines (this same standard is used in aviation and aerospace btw, as a pilot I have to deal with it for every flight). So... what is standard atmosphere you ask?
Air pressure: 29.92" Hg
Air temperature: 15*C (about 59*F)
Humidity: 0%
Wind: none
Remember that this standard is rather arbritrary as you'll likely never encounter these actual conditions, but it gives you a place to measure from, kind of like zeroing out the scale, when you apply a mathematical correction to the actual conditions.
If you do infact find that the weather does match standard atmosphere your DA = the actual track elevation. Without going through all the calculations (there's plenty of free calculators online that make it a lot easier) this is what makes DA higher than track elevation:
Lower pressure
and/or
Higher temp
and/or
higher humidity
Phenix is offline   Reply With Quote
Old 05-10-2009, 10:14 AM   #4
Rock36
I just like V8s
Rock36's Avatar
Yeah I forgot to mention temperatures too. You need a bit of a balance. Cool enough so that the engine is breathing well and not heating up too much, but warm enough that the rubber and asphalt don't loose traction.
Typically I've found temps in the upper 50s/low 60s to be the best.
Old 05-10-2009, 04:07 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Optimum would therefore be in the evening after a warm day ... cold dense air for the engine with a track that still provides a lot of grip
Old 05-10-2009, 04:09 PM   #6
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
Ideal track conditions are clear, cool, sunny weather.
...and no one on the track faster than you!
patriotpa is offline   Reply With Quote
Old 05-11-2009, 09:25 AM   #7
Rock36
I just like V8s
Rock36's Avatar
Good point...
Old 05-11-2009, 12:36 PM   #8
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
Best conditions for drag racing would typically be:
45-55 F temperatures. Any colder and the tires do not hook as well.
No head wind. A tail wind helps with MPH!
High barometric pressure. Anything over 30.0 inHg is good.
Low low humidity. Less than 20% is excellent.
Once your Density Altitude goes below 0 feet, that is excellent drag racing weather. It doesn't happen often, and what sucks is that most tracks close in the winter when we do see negative DA. With most tracks only being open 2 days a week, the odds of it being open on a negative DA day are even less. Those are also the most crowded days
Fquick.com/NineBall
Daytona 500 Camaro Pace Car --------> 01pewterz28 Camaro Photos | Spyshots | Video | Media Gallery 65 02-20-2009 04:53 PM
Car and Driver Drives the ZR-1 at GM's MCR test track drummerstevey General Automotive + Other Cars Discussion 13 09-02-2008 07:22 PM
Track package stovt001 5th Gen Camaro SS LS LT General Discussions 5 08-09-2008 10:36 AM
What should I expect at the track tonight.... Bowtie Guy Z28 4th Generation Camaros 5 05-28-2008 04:20 PM
