Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 05-05-2012, 08:21 PM   #1
csjcsj
"VIRTUAL MEMBER"
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
Need oil pump!!!!
Got the low oil pressure light today, and the gauge said 0! Going to get a melling pump and change to that!
I have an LS3!
So my question is, how difficult is it to change yourself! I am somewhat mechanically inclined, is or are there any thing I should know before I tackle this job! Or are there any how to's on here!
Any help or pointers would and will be appreciated!!!
csjcsj is offline   Reply With Quote
Old 05-05-2012, 08:40 PM   #2
acowherd
acowherd's Avatar
Drives: 2010 2ss/RS 4l80. 2009 2500 HD
It's not terrible, but it's pretty involved. If you feel comfortable tearing into the front end of your motor, then it's no big deal. Just pull your front cover off your motor, and your oil pump is down at the bottom. The pick up tube is one of the worst parts of the job. Good luck, and if you go on to do it, post a DIY!!
D1SC-LG G6x3-SW 2" Headers-DMH Cutout-3" Flowmaster A/T-ADM Dual Fuel-ADM Boost,Air/Fuel gauges-Nitto NTO5r-SJM line lock-Modded LS3 Oil pump-BMR-Toe Bar,Trailing Arm,Sub Connectors,Cradle Bushings-Shep Tunnel brace-MSD Shift Light,2Step-CINCY SPEED Tune-DSS 9" Conversion..3.70s gearALKY Control-Extream Innovations Roll Bar- 4l80!! 763RWHP 629TRQ
acowherd is offline   Reply With Quote
Old 05-05-2012, 08:59 PM   #3
csjcsj
"VIRTUAL MEMBER"
csjcsj's Avatar
Do you have to pull any pullies or the harmonic balancer off? That's main main concern!!! If not it seems pretty straightforward!
Old 05-05-2012, 09:15 PM   #4
acowherd
acowherd's Avatar
Yes, harmonic balancer will have to come off.
Old 05-05-2012, 09:29 PM   #5
2SSRS
On a list for a 2014 Z28
2SSRS's Avatar
Drives: 2010 Camaro 2SS M6
This will help you out.
http://www.camaro5.com/forums/showthread.php?t=125123
2SSRS is offline   Reply With Quote
Old 05-05-2012, 10:41 PM   #6
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
that pick up tube was a real pain
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 05-06-2012, 09:25 AM   #7
csjcsj
"VIRTUAL MEMBER"
csjcsj's Avatar
So if I was to have a stuck valve, is there oil still running through the motor? Or not? It's been sitting over night at my daughters house and read that you can start it and give it a high rev and unstick it! But don't know if that's a good idea since all the oil has drained down!
Or would you not even attempt that and have it towed?
Old 05-06-2012, 12:46 PM   #8
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
Definitely have it towed. No sense risking a damaged engine.
tkrupinski is offline   Reply With Quote
