Rover City Camaro Customs
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 05-06-2012, 03:44 PM   #1
Unfkwthabl
Unfkwthabl's Avatar
Drives: 2011 V6 Synergy Green Camaro
Problem with Morimoto Projector please help!!!
I'm in the process of aiming my headlight and I cant get the drivers side headlight to raise enough to aim correctly. Everytime I try and raise the lights using the stock light screw it goes up but not high enough for correct visibility. I tried screwing it all the way but eventually it just pops out the housing. Is there something I am missing to get the cutoff line higher. The passenger side works fine also. Any advice on wht to do will be greatly appeciated.
Unfkwthabl is offline   Reply With Quote
Old 05-06-2012, 03:47 PM   #2
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
what cut off are you setting them to? The stock alignment?
Stieger's BLACK Build Thread thanks for the sig Russ
Old 05-06-2012, 03:59 PM   #3
Unfkwthabl
Unfkwthabl's Avatar
Trying to get the cutoff line to be the same as the passenger side but it will not go up that high. I went with a friend wbo has stock projectors to get the cutoff to match and the passenger side worked fine but the drivers side wont go up tht high even when adjusted all the way.
Old 05-06-2012, 04:09 PM   #4
Synerbee
SoCal Headturners
Synerbee's Avatar
Drives: 2010 SGM
It is not suppose to. So you don't blind other drivers
Sent from my DROID2 using Tapatalk
Mods: 22" Lexani LX-15s, Vertical doors, Dynamic RGB grill light, RGB footwell, SGM painted interior, Mace 25mm insulator, Vararam intake, Grantelli trailing arms, Ark N-II exhaust
in box: RX catch can, SS strut towers, eibach 1 in. drop for SS strut towers
For sale: Used Granatelli 1g bracing, Used SGM scosche, New DT shorty headers v6 camaro LLT
Synerbee is offline   Reply With Quote
Old 05-06-2012, 04:40 PM   #5
Unfkwthabl
Unfkwthabl's Avatar
I understand tht im not supposed to blind drivers but its aimed so low it affects visibility at night. Im trying to get it to match a lowered g8 cutoff line which doesnt blind drivers when driving.
Old 05-06-2012, 04:43 PM   #6
Unfkwthabl
Unfkwthabl's Avatar
Yes any suggestions the passenger light is fine the drivers side is the one thats not getting high enough even when I adjust it all the way with the little screw on the back of the headlights. Any suggestions.
Old 05-06-2012, 04:49 PM   #7
The Stig
The Stig's Avatar
OK, not what I asked. How are you setting your HIDs? As in what procedure are you using to align them?
This is how you align your HID headlights
TO AIM PROJECTOR HEADLIGHTS:
1. Align your car dead center in your driveway....the front and back of your car need to be perfectly aligned in the center..
2. Pull your car up to the garage door...as close as you can get w/o hitting the door..dead center in the middle of the garage door / driveway.
3. Put a piece of tape where the headlight beams hit the garage door. This should only be smal dot of light...
4. Pull you car back 25'. Your Projector lens should be 25' away from the garage door...not your tires or your bumper...your headlights. DEAD CENTER IN THE DRIVEWAY
5. With tape Place a VERTICAL line that intersects each piece of tape that you put on the garage where your headlight beams hit. Use a yardstick or a straight edge t make it perpendicular to the driveway. This is important for aiming your lights right to left....this is just as important as up and down because if your lights are aimed to far left you will still be shining omcoming traffic in the eyes and if they are aimed too far right your not getting the most out of your light.
6. With tape place a horizontal line along the garage that intersects each piece of tape that you put on the garage where your headlight beams hit. They should oth be the same height off the driveway.
7. With tape place a horizontal line along the garage that is 2.1" lower than the tape you placed on the garage in instruction #6. This line should be parallel with the line in #6...just 2.1" lower.
8. Cover up the passenger side headlight with a thick towel.
9. Turn on your lights
10. Drivers Side UP/Down: Bring the lower step of the cutoff to or below the tape line that is 2.1" lower than your headlights...Dot Spec is 2.1" to 2.5" drop over 25'
11. Drivers Side Right / Left: The Vertical line on the drivers side of the garage should intersect the middle of the slant on the cutoff. Move the beam pattern until this is the case. We don't have a left/right alignment. Only up/down. Don't worry about this part.
Moving the projectors from right to left may effect the height of the beam pattern. If this is the case..just go back and fine tune. Again, don't worry about left/right
12. Cover the Drivers side headlight with a thick towel.
13. Repeat the UP/Down Left/Right procedure that you did on the drivers side with the passenger side. The vertical line on the passenger side of the garage is to be used for instersecting the slant in the cutoff on the passenger side headlight beam.
Old 05-06-2012, 04:54 PM   #8
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
It's this way by design. The drivers side headlights are purposely made not to have as much adjustment in them as the passenger side so people can't raise them too high.
You can try shimming the housing and see if that works or see if you can remove the adjustment screw and put in a longer one
Old 05-06-2012, 04:59 PM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I don't think this is his problem.
The way I understand it, he lowered his car and now the headlights are too low to be of any use at night and now require to adjusted up. The passenger side adjusted up just fine but the drivers side won't come up anymore then it is.
Old 05-06-2012, 05:14 PM   #10
Unfkwthabl
Unfkwthabl's Avatar
My friends car is lowered not mine and his lights are alot higher then my drivers side. I wanted to match his cutoff line because his lights have great visibility at night and does not blind drivers. We both parked 25 feet away from a wall and tried to aim my lights to match his cutoff. Also when driving it is noticable that the drivers side needs to be aimed higher. I need to somehow raise the cutoff line without using the factory screw on the back of the headlights because its already at its highest setting. I know the light output is supposed to be lower but not enough where it severely affects drivability at night.
@ steiger I tried it the way you suggested at first. This is when I noticed the problem. After this I took my friend to try and match his cutoff line to see if maybe I was doing it wrong.
Old 05-06-2012, 05:40 PM   #11
The Stig
The Stig's Avatar
OK. How do you know your friend's headlights aren't blinding other drivers? Not trying to be a jerk or anything, I'm just curious.
Old 05-06-2012, 06:11 PM   #12
Unfkwthabl
Unfkwthabl's Avatar
We did a test in a bunch of cars with his car behind them trucks even a miata. I was hoping the case was his were aimed to high so that the problem would be his car not the projectors. None of the cars were blinded by his lights or my passenger light. I then tried the high beams so that I can drive with them on to get a higher cutoff line but that did blind everyone.
Old 05-06-2012, 06:16 PM   #13
The Stig
The Stig's Avatar
Did you try it with him driving the opposite direction as the test car? Because when your headlights aren't aligned you end up blinding on coming traffic, not the car in front of you.
Old 05-06-2012, 10:23 PM   #14
greenvillepilot
2fast4you
greenvillepilot's Avatar
Drives: 2010 Camaro LS
I have the same issue. When I installed the Morimotos i could not get the angle up high enough (D#mn near pitch dark with normal beams on because the beam is only a few feet out from the car)...I tried adjusting and adjusting but still crappy. So I drive with my high beams on, It does not blind drivers and looks perfect. However I am going to re-open the casing and adjust the lights from within the housing by using washers behind the reflector...and before I reseal them I will test them this time mounted and screwed down. If you dont screw them down when you test them you will be off by a whole lot.
greenvillepilot is offline   Reply With Quote
Old 05-06-2012, 10:43 PM   #15
Unfkwthabl
Unfkwthabl's Avatar
I was thinkin of using washers too but I'm going to try and put about 3 behind each screw on the bottom of the headlight to angle it upwards to slightly angle the headlight up. Will let you know how that works. I tried to mess the reflectors to make it them go up more but they were already hitting the top of the housing.
Old 05-06-2012, 11:18 PM   #16
HubStep
HubStep's Avatar
Drives: 2010 Victory Red 2SS
I've had this exact issue! (that's currently being resolved) This was on an AAC projector retrofit and I'm pretty certain they use the morimoto projectors. The drivers side was perfect but the passenger's side was a solid 20+ degrees lower even at max height. At night it looked like I was driving around with one headlight. It was awful, perhaps they have a QC issue?
HubStep is offline   Reply With Quote
Old 05-06-2012, 11:27 PM   #17
Unfkwthabl
Unfkwthabl's Avatar
Wow I'm surprised that more ppl then just me are having this problem. Since the reflector has no more room to go higher. Is there any ways that I can aim the whole headlight up a bit so the the whole headlight is reflected a little more upward. Im going to test placing washers on the bottom 2 screws of the headlight. I will be working on this Tuesday to see if it works. If anyone has any other ideas I would like to try them to see what will work best to correct this issue.
Old 05-07-2012, 10:52 AM   #18
HubStep
HubStep's Avatar
I considered this but instead chose to just mail the unit back for warranty service. I wasn't going to accept that because if it's broken out of the box what else could go wrong 6 months from now?
As far as using the washers, I was concerned about interference with the front facia. There's not a whole lot of room there and for me the # of washers need would have made it awkward looking. I have to have my car symmetrical!
IF it works though please post pics of that particular light against the grill!
Old 05-07-2012, 11:34 AM   #19
Unfkwthabl
Unfkwthabl's Avatar
Let me know how the warranty service goes I might try that if the washers make it look really awkward.
Old 05-08-2012, 11:11 PM   #20
Unfkwthabl
Unfkwthabl's Avatar
I ended up placing 5 washers behind the bottom headlight screws and it solved my problem perfectly. I also checked and my headlights look symmetrical. You would never know I did this unless I told you. The cutoff line and light output is perfect. Here is a picture showing the washers on the bottom of the headlight.
Old 05-09-2012, 12:57 AM   #21
FL1CK
MOVE!
FL1CK's Avatar
Drives: 2011 Camaro
By symmertical I hope you're not meaning the cutoff line is completely straight. It should drop on the driver's side still... as stated earlier in the thread.
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 05-09-2012, 10:00 AM   #22
HubStep
HubStep's Avatar
No, I believe he was referring to a concern I mentioned to him in PM about the headlight modules appearing symmetrical after putting the washers in.
