Rick@Livernois
Old 05-06-2012, 08:17 PM   #1
IcePick06
IcePick06's Avatar
Drives: '12 AGM ZL1; '07 Ducati 1098
Question Calling all Electrical Wiring Gurus: ZL1 mirror doesn't have switched Power?
I'm hoping any electrical gurus or those knowledgeable about the 2012 Camaro can answer this. I just got my MIRRORTAP & BLENDMOUNT and tried hooking up my V1 Radar Detector to my 2012 ZL1. MIRRORTAP gives you colored connectors but no instructions; so I used common sense and plugged their BLACK pin into mirror's BLACK wire and RED pin into RED wire. Now the V1 fired right up when I turned the car on... BUT it stays on when I turned the ignition off It appears the ZL1 has no switched power in the rearview mirror; I searched around and it appears all 2012 Camaros with the RearView Camera have this problem...:(
Is this true? I don't want to run a wire to the fuse box, but I also don't want to have to manually turn off my V1 every time I get out of the car to avoid killing the battery.
IcePick06 is offline   Reply With Quote
Old 05-06-2012, 08:42 PM   #2
04ssSilverado
04ssSilverado's Avatar
Drives: above `12 zl1 #780
Awwwwwwww damn,I wish that was my only prob.lol
04ssSilverado is offline   Reply With Quote
Old 05-06-2012, 08:48 PM   #3
04ssSilverado
Sorry,just aggravates me. I love Chevy.
Old 05-06-2012, 08:49 PM   #4
brucedd
Drives: xxx
From http://www.camaro5.com/forums/showthread.php?t=199276
2SSRS said:
" there is a fast way, go 1-2" above the Rearview Mirror pull down on the black plastic its 2 haves and one slides in to the other, that is where the connector is for the mirror, then the black wire is ground and power on a 2010 and 2011 is the pink wire."
Please let me know if this works as I will be mounting my escort soon.
brucedd is offline   Reply With Quote
Old 05-06-2012, 10:13 PM   #5
IcePick06
IcePick06's Avatar
This doesn't work on the 2012 Camaros...the wiring in the mirror harness is different than the 2010-2011 Camaro. Do a search and you will find the thread confirming this, most have to hard wire to the fuse box to get "switched" power...but I'm hoping to not have to do this. I'd like to just plug the V1 into the mirror harness and be done.
Old 05-07-2012, 10:33 PM   #6
brucedd
Drives: xxx
I picked up my ZL1 today and the dealers stereo/electronics guy was there. I will send him the contact number at MirrorTap and he will get the ZL1 wiring info from GM and said he will let me know. If you don't have an answer by the time I get one, I will post the update.
Old 05-07-2012, 11:02 PM   #7
IcePick06
IcePick06's Avatar
Ok Thanks Bruce
Old 05-07-2012, 11:49 PM   #8
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Can any one confirm the colors of wires in the new mirror.
Old 05-15-2012, 08:34 PM   #9
brucedd
Drives: xxx
Still waiting for any input, but mine is in getiting some minor aesthetics, and the guy is an electronics installer, so he will look into the MirrorTap install....so sorry for the slow info (if any)...
Old 06-03-2012, 08:32 PM   #10
PMJ
Seeking 9s on M6...
PMJ's Avatar
Drives: 2012 2SS/RS LS3 aka "BlackWidow"
Any updates on the mirrortap wire scheme for the 2012 w/rearview camera... I just installed...guess i'm going to have to plug/unplug for a while.
PMJ is offline   Reply With Quote
Old 06-03-2012, 08:41 PM   #11
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
It takes all of about 10 minutes to run a wire to the mirror from the fuse box. I used a foam piece of tubular weather stripping and put my wire inside of that before I routed it, so that it would not rattle.
jeepguy_1980 is offline   Reply With Quote
Old 03-12-2013, 08:36 AM   #12
vegassam66
vegassam66's Avatar
Drives: 2012 Camaro 2SS / RS
Okay I guess I am not the only one running into this problem, local dealer service department had no clue as to which wires to use.
vegassam66 is offline   Reply With Quote
Old 03-12-2013, 08:39 AM   #13
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
This is what I did as well running to the side fuse box is a piece of cake.
Sent from my 2SS/RS
FSP tuned: 377/389
Old 03-13-2013, 12:24 PM   #14
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
The Ignition wire is what you are looking for. It's a pink wire. One of three pink wires to choose from. Which one? Pin 2 on the rear view mirror connector.
There is a little more info in the Homelink thread but, you've now got what you need.
All you need is two crimp on tap connectors and the DC plugin connector for your detector with space connectors on the other end. Plugin and voila done.
It's essentially the same power source used for the Homelink mod.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Rotofab CAI with dry filter and sound tube delete, ported throttle body, Stainless Works headers and exhaust. Custom tune by Jannetty Racing.
Darth Martel is offline   Reply With Quote
