| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
Deaf Audiophile
Drives: 2010 IBM 2SS/RS, 2013 Avalanche LTZ Join Date: Jun 2011
History:
As some of you may know, I have been fighting quite a battle with a pop/click/thump (henceforth referred to as p/c/t) when I turn off my radio. I have a long history of car stereo installation (amateur and professional) and I have an associates degree in electronics engineering. I am currently employed as a commercial electrical designer. I know my way around electricity and have a pretty decent grasp of electronics. I have had issues with turn-off p/c/t in the past, but it was always a grounding issue, and it was always with aftermarket radios/amps/eq's. When I installed my amp and sub into my camaro, I googled the Boston Amp wiring diagram which eventually lead me to these forums. I found the wiring diagram and began hacking away at my factory harness. Originally, I had an Alpine 3527S and my Rockford T1000-1BDCP. The Alpine was running mids/highs (all car speakers, including center channel) with the Rockford handling sub duty. It sounded pretty damn good. I was smiling ear to ear, until I turned it off. When I turned it off, there was a p/c/t. It wasn't super loud - I didn't expect it would destroy speakers or anything, but it was very noticeable. I was mostly worried about it damaging my amps. Now I had just spent over $1000 and it was like a stick that poked me every time I turned off my car. Being proud of my car and my high-end (to me anyway) equipment, I was embarrassed by the p/c/t. I started a little troubleshooting - having my wife operate the keys while I watched how the amps and sub reacted when the keys were removed. I noticed that after the keys were removed, the amps stayed on for roughly 2 seconds. When they turned off, there was the p/c/t. So I looked around for something that would change the sequence of operation. I found 2 things I thought might work - the Metra Axxess Trigger and the P.I.E. EIS-PS2 (pop-stopper). Now the Metra Axxess Trigger I'm pretty sure was expensive and mostly unavailable when I first started looking - I'm sure I remember seeing it on ebay for $90+ . So I figured I'd try the P.I.E. EIS-PS2 since it was only $25 and it's a pop-stopper - win, right?! It provided a 2 second turn-off delay. I figured that if the amp stayed on after the signal dropped, it would not pop. Wrong.So next I tried removing the amp remote as soon as my wife removed the keys. Viola! No pop! Now I was getting frustrated because I figured that no one made anything that would disconnect the remote at that second. I figured that the factory radio was sending a mute to the factory amp through the mute wire and that the amp was disconnecting the inputs when it got the mute signal. I couldn't think of anything that would do that for me, so after living with the p/c/t for several months, I finally had a breakdown and removed all of my aftermarket equipment and returned it to stock. Yes, I threw a hissy-fit. ![]() I was pretty sad. I love my car, but I missed my overkill sub. I started looking for answers on the internet, on these forums, everywhere. I started asking questions, and thought several of the answers had merit and were worth at least trying. $1000 worth of stereo sitting in boxes in my garage annoyed me. I wanted to use it again, so I started trying anything and everything that I thought might work. Then I tried some things that I didn't think would do anything to help. I figured that honestly, if nothing else, what I learn could at least help others that might have the same problem. I was determined to find the answer. Below, I will detail the causes some said were causing the p/c/t and some things I tried and the solution that is semi-working for me. As a note, none of the solutions are perfect. My opinion is that the only perfect solution is replacing the factory radio, since the p/c/t is all it's fault, ![]()
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille Audio Mods * Stinger SPP 2250 Battery * Pioneer AVH-P8400BH * Scosche Dash Kit * Rockford Fosgate 3Sixty.3 * Rockford Fosgate Power T1000-1bdCP * 2-JL Audio 13W6v2 * Rockford Fosgate Power T800-4AD * Focal 165KRX2 Power (active) * Rockford Fosgate Power T400-4 * Rockford Fosgate Power T1692 |
Deaf Audiophile
Possible Causes
Remote Voltage Too High:I was told several times that the problem was that the remote turn-on voltage was too high. That is incorrect. I have used 12V direct from the battery in past, through a dash mounted switch, to turn amps on and off, with no pop. I have read somewhere that certain Ford factory amplified systems had an issue like this. Groud Loop: I thought I had pretty good grounding, but figured I would try the ground loop isolator anyway. The consensus is that there is DC riding on the low level outputs coming from the radio. A ground loop isolator would in theory remove the DC from the line. I still don't know what to make of this. See Ground Loop Isolator below. Line Output Converter A line output converter takes a high level speaker signal and converts it to a low level RCA output that can be used to connect to an amp. Some amps have this already built-in and you can plug high level inputs directly into them. None of my amps have this feature. That could be a reason some people do not have the p/c/t. Some manufacturers have adapters for their amps that basically are just speaker cable wired directly to an RCA. In those cases, the amplifier must be able to accept high and low level inputs via the RCA connections. Gains Too HighSetting all gains at 0 did not eliminate the p/c/t. It did reduce it to a low level, so gain has an effect on the p/c/t.
Deaf Audiophile
Possible Solutions
A Little Turn-off Pop is Normal: I didn't accept this answer. I'm not going to call anyone out on this, but dropping thousands on a system to have "a little pop" is unacceptable - for me anyway.Precision Interface Electronics EIS-PS2: As detailed in history, no effect. Ground Loop Isolator: I tried 3 different models. One Stinger, one AudioPipe, and generic. It seemed like it made the p/c/t less severe, but did not eliminate it. As a note, my original Alpine 3527S did not need ground Loop Isolators but my Alpine MRV-F357 goes into protect without them (when fed low-level radio output directly). My RF T1000 didn't need it either. Line Output Converter (LOC): I just knew this would do it. The consensus about the DC and removing it pointed to a LOC being the best bet at getting rid of the DC. I went and bought the best LOC I could find - and AudioControl LC6i. I tried the LC6i in front of and behind the BA amp. It did not remove the p/c/t. I was devastated. There was speculation that it might actually cause a p/c/t itself, so upon direction of Steve @ Subthump, I tried his AudioPipe LOC. Honestly, I didn't think it would work, but I figured I would give Steve a shot. Well, it didn't remove it, but it did reduce it to a very low level (probably because it reduced everything to a very low level). Resistors Across Low Level Inputs: One person said placing a resistor across the low level inputs should remove the DC, but the p/c/t did not go away. I used a 10 ohm - 10 Watt resistor. The p/c/t was greatly reduced, but not eliminated. I believe the signal volume was also reduced, but I don't 100% recall. Relay: I had an idea that if I used a single-pole double-throw relay to break the remote going to the amp by using the mute, it would kill the p/c/t. I tested the voltage of the mute and I believe it was around 6V. I went to RadioShack and purchased around $20 in materials (blank board, 5-7V SPDT relay, new soldering iron, etc). The plan was to use the Radio-Mute to actuate the coil, thereby breaking the remote and turning off the amp as soon as the mute went active. Turns out that the Mute only provided 1.9mA of current, and the mini-SPDT relay required 56mA to operate. I had a good laugh at that. This would have been the simplest solution - of course it wouldn't work.
Deaf Audiophile
The Actual Solutions
Metra Axxess Trigger: A "guy at Metra" sent me a Metra Axxess Trigger to try. When he told me he was going to send it to me, I figured it would probably work because it was the one solution I originally passed on (I didn't know this person worked at Metra until after I PM'd him to ask him if he needed my first born or soul as payment). So, I looked it up online again, and they can be had in the $30-40 range now. In the description of the device, it says "GMLAN Aftermarket Amp Turn-On provides an amp turn on LAN vehicles for adding an aftermarket amp". Truth in advertising. It does just what it says, but there is a caveat. My relay, had it worked, probably would have done the same. When you first turn on the radio, or if you press the mute on your steering wheel controls, it turns off the amp. Therefore, there is a 2-3 second delay when turn on the radio or un-mute the radio. I can deal with it.......for now. Use Accessory Outlet Power (Cigarette Lighter) As Remote Source: This will work, to an extent. The caveat of using this remote source is that when you turn off your car, your amps turn off as well. Normal operation is that you can open the door of your Camaro and turn on the radio, without the key in the ignition. If you use the cigarette lighter, you have to turn the key on to accessory for your amps to come on. Replace Factory Radio: Yeah, this should definitely fix it, but I wanted to keep the factory radio and all of it's functions. Did I miss anything?
Deaf Audiophile
reserved
#6 |
#7 |
Deaf Audiophile
Actually, that is how I had it hooked up originally, and it does cause the p/c/t. I guess I didn't state it clearly enough.
The amp control line = amplifier remote = Orange Wire on X3 connector. The amp control line stays on for around 2-3 seconds after the radio is turned off or key is removed. I was told that some amps do not have this problem, and that's great. But, a lot of us do have this problem.
#8 |
Pinche Team Leader
I applaud all the steps you have taken and your great documentation.
#9 |
![]() Drives: 2010 1SS Camaro; 72 Chevelle Join Date: Apr 2008
I wonder if this has something to do with the Boston system... Of all the threads I've come across with people talking about this problem, it seems they all have the Boston system... I was pretty concerned with this issue when I went to install my system, but I do not have the BA option in my car.
I used a PAC SOEM-T LOC and tapped into the rear speakers to get the signal. I chose the SOEM-T because also provides the signal to the remote wire, as I didn't want to try to run a wire to somewhere else in the car with keyed power to try and get the remote signal to the amp. IIRC the SOEM-t can detect as little at .5v through the speaker wires and provide the remote signal to the amp... Although it seems like a good idea, it also seems that there is always at least that running through the speaker wires even when the radio is off... So even with I turn off the radio, my amp is still powered on. Is this a big deal? I don't think so, but I don't personally know if it will damage something eventually. ![]() Long story short, I do not have the BA system, and the p/c/t I was so concerned about going into this installation is not present, so I am happy. Like I mentioned, the only thing wrong with this set up is that the amp is always powered on with the ignition is on, even with the radio off... But with the ignition off, the amp is off, until the radio is turned on and then it powers up... No big deal... I think? My system install thread is here: http://www.camaro5.com/forums/showthread.php?t=191938
Specializing in attractive "no drill" front license plate brackets for the 2010+ Camaro Check out our new website! www.jacfab.com 2010 Camaro 1SS RJT w/ SIM Stripes; M6. 12.535 @ 112.33mph JacFab No-Drill front license plate bracket, Dynomax Axleback, JacFab CAI System, JacFab HFC's, Bo White ported TB., DIY short throw shifter |
#10 |
![]() Drives: 2012 Silver Ice SS2 RS Join Date: Nov 2011
So in a nut shell
Buy the Metra Axxess Trigger.. install it. get power from the cig light in the center console. and problem solved?? |
#11 | ||
It has a delayed turn off already. When the radio is powered down, the line holds voltage on it for a few seconds and then slowly bleeds down to 0v over the course of another 5 or so seconds. If you use that line, you will not hear a pop. Quote:
#12 |
Drives: 2011 2SS IOM Vert Join Date: Aug 2009
Everyone needs to keep in mind that this is totally dependent on the amp being installed. Different amps use different internal power supplies and there is no simple formula to know in advance. Just because one amp does it, doesn't necessarily mean the next one will. I know all the JL amps we have tried, they don't seem to need anything because they just plain don't do it. The kicker amps we have tried, do it slightly but the ground loop isolator on the input signal takes care of it completely.
With that said, there will still be times when certain amps need a ground loop isolator or a line converter just to make them work. This is because of the way they are built. A small percentage of amps will go into protect mode without these devices regardless of the trigger mechanism. This is why we recommend the ground loops because it solves that problem for many amps, and also minimizes the thump in a lot of other amps. There are just to many different amps guys are using to say one solution is universal. The axxess trigger may work fine for a subwoofer amp installation, but keep in mind that if you replace the boston amp and try to use the axxess trigger on a multi-channel amp, there will be a rather lengthy delay in how quickly it powers up to play the chimes. What I mean is: The boston amp actually powers up really fast in order to play the chime sounds thru your speaker when you open the door. Aftermarket amps typically turn on a little bit slower--so you actually miss the first and second chime. Add 2-3 seconds of delay on top of that and you will already be seated in the car before the amp powers up and starts playing the chime sounds. Or worse, you might not even hear the chime becuase you'd have the door closed already. Either way, this may or may not be an acceptible solution because of the possible side effects. My recommendation would be to see how your amp responds first and go from there. I still think the ground loop is good insurance if you don't know if your amp can handle the dc. But now that we have some other documented solutions, guys will know what to do in the event they have a persistent p/c/t. I actually have a metra account, I will call my rep and see what the pricing would be should anyone need one. |
#13 | |
Deaf Audiophile
#14 | |
Deaf Audiophile
Also, thanks again for working with me on this Steve.
#15 |
Just wondering.. what chimes are we speaking of?? I mean if we open the door what chime could we possibly be needing? I can't think of any chime I need to hear until my ass is in the seat and the car is running and I am about to move..
I have installed a Low volt trigger and that did not solve my problem. so I will be trying your GLI but it is great to have other paths to try if that does not work. Thanks guys for the info. |
#16 | ||
Deaf Audiophile
#17 | |
If your key is in the ignition and you open the door, your will get a chime sound. I would imagine if you leave your lights turned to 'on' and exit the car, you would get a chime as well. So there are instances when the chimes are helpful. |
#18 | |
![]() Drives: 2010 Camaro SS Join Date: Oct 2010
L99 - 440 RWHP
Livernois 2c Cam & VVT/DOD Delete Roto-Fab Intake Stainless Works 1 7/8" Long Tube Headers Corsa Exhaust |
#19 | |
L99 - 440 RWHP
#20 |
I have an ORIGINAL SoundStream Continuum Amp. 1 of the 800 polished aluminum ones that were sold in the US. I to am getting the turn off crackle, pop, and thump at the 2 second mark after I turn the car off. I used a PAC model TR-4 low volt trigger .. (I was told how to hook this up by a stereo shop.) to which I connected the trigger wire into the factory harness coming from the radio. it worked great for the turn on side of things. but I was not having a problem with turn on thump. I still had the issue at turn off.
After reading your posts.( Steve and Darkrider,, and a few others) I have come to realize it is the delayed signal that is causing this I will be open to trying any and all of your suggested methods if it will fix the problem.. and about the chimes.. sorry I was under the impression you were talking about chimes when you got into the car.. So yeah.. if you are getting out of the car .. yes I would want to know I left my lights on or I left my keys in the ignition.. |
#21 | |||
Deaf Audiophile
I have the AudioControl LC6i in between my Head Unit and my Alpine right now so I have it's output levels adjusted to roughly 90%. It's a LOC, so they're not quite the same as gains, but similar. The gains on my amp are at 0% because I don't want to pop the factory BA speakers while waiting on my RF set to get here. The best bet when adjusting gains is to put the keys in the ignition (with door open) and then adjust them to the maximum level you can stand your chime. Amp gain has a HUGE impact on chime volume. High gain = loud chime. Quote:
When using the Axxess Trigger, you will still have your chimes, they will just have a slight delay. I'm old and fat, so it takes me more than 3 seconds to get my big butt out of the car - especially when getting my 3 year old out of the back.. Honestly, when I say 2-3 seconds, I may be exaggerating a bit, but different amps take different amounts of time to turn on and produce audio. I'll tell ya what: You send me that SoundStream Continuum and your PAC TR-4 and I'll send you my Alpine MRV-F357 and Axxess Trigger ![]() I was very close to going all SoundStream when I started planning my system - would have saved me some cash for sure. SoundStream made some awesome stuff back in the day (they still make some good stuff now, too). My first 15's were SoundStream SPL-15's. They were brutal.
#22 |
me.. send you my Continuum.. are you smokin dope)) I had this thing pushing 2 reference 10s , and I was gettinng 2 1/4 inches of woofer movement peak to valley. a pair of 5-11s and (4) 4.0s in an 89 Camaro.. OMFG did it ROCK.. and you are correct the old SS stuff kicked ass. the new stuff.. it is just ok..
yeah I have been beating my head against the door frame trying to figure this out. glad I have people like you for more ideas.. |
#23 | |
Deaf Audiophile
![]() I think you should give the Metra Axxess Trigger a chance. I can help you with the wiring of it if you need. You have to connect 5 wires - it's something like 2 grounds, a +12V constant, the white remote, and the orange amp control. I'll help out any way I can.
#24 | |
Another question related to this: If you have the radio off and use the turn signal is there a delay before you hear it or does it leave the amp on so you can hear the turn signal right away?
L99 - 440 RWHP
#25 | |
Deaf Audiophile
| Thread Tools | |
