05-06-2012, 11:18 PM | #1 |
TREMEC6060 1-2 needs fix
Drives: 2011 2SS/RS Join Date: Jul 2011
Took my car to the track, light yellow oil is now dark brown
I had the oil changed, Mobile2 synthetic, and it was clear light yellow before and after the change. A thousand or so miles later, I took the car to the track for a total of 8 quarter mile runs on two separate outings . Reving up to 6000 on my way down the track in cool temperatures. I did hit the rev limiter a few times. Now the oil is dark brown, not as dark as molassas, but darker than pancake syrup. Oil level is in the middle of the dipstick marker, as it was before I ran it hard.
It's a 2011 2SS, LS3, 6M, livernoise stage2 cam, Kooks headers, Corsa exhaust and AFE cold air intake. Otherwise stock. DIC says 81% Oil Life left. All the temperatures stayed normal except the outside air that did read 71 degrees F when it was only about high 50's or low 60's at best outside. I attributed that to engine heat from coming off a quarter mile run. Does the rather sudden change in oil color mean anything to one of you experts? Should I be concerned, or very concerned? Or is this just my engine reaching 7000 miles? Other than oil color, everything else seems as normal as it was before pounding on it.
Asimov's Fourth Law of Robotics: If you don't know what else to do, wave your arms and run around in circles.
05-07-2012, 12:11 AM | #2 |
Drives: 2017 1SS 1LE - Hyper Blue, P85DL Join Date: Jul 2011
Sounds normal for making your engine work hard. That's the job of oil to protect it under load.
05-07-2012, 12:20 AM | #3 |
yup sounds ok in my book
1 7/8 long tubes full XS Power exhaust no cats, Rotofab CAI, PowderPro Ported TB, Hurst short throw, TSP 231 236 cam, tuned by Synergy Motorsports 454RWHP, 440 RWTQ. More to come!
05-07-2012, 12:26 AM | #4 |
Drives: 2011 camaro 2SS RS Join Date: Apr 2012
So what were your times?
05-07-2012, 12:32 AM | #5 |
Drives: Camaro SS 2010 Join Date: Mar 2012
That is oil purpose, its normal..
05-07-2012, 02:12 AM | #6 |
Times were embarrassing.
Thanks for the letting me know the oil is Ok.
The best I've managed is 13.473. I just can't get a quick start and I tend to just dump the clutch and spin a bit. I'm working on it, but even if I get first gear to go smoothly, I then have to work on not spinning wheels in second. The track seems a lot like driving on icy roads. My wheels don't spin on dry asphalt with Stock P-Zero's. But I don't get much practice on regular pavement, other than the freeway onramp, and that ends halfway through second gear, to stay legal, so not much to compare. Oh yeah, I'm an old fart so my reaction times are not that good. Even trying to launch on the third yellow, I can't get a good RT. But the main thing is learning to ease out the clutch and grab, and then press the accelerator smoothly and evenly without breaking loose. I think I know how to do it, I just can't actually do it, just like a big fat gymnastics coach can't do any of the stuff he tells his 85 pound gymnast girls to do. I did read the stuff on this link http://www.rangeracceleration.com/ which seems like good advice to me. But the thing I was worried about is that I had the original oil changed with about 30 percent Oil Life left, and it was still light yellow. The new oil was the same color until now. And I thought I had done some rather extreme accelerations on the onramp, not quite to redline, but shifting into second at 6000, or nearby ,quite a few times, and then into third at whatever I could manage under conditions. Thinking about it, all my road driving for 7000 miles probably doesn't equal more than 2 to 5 percent of the over 5000 RPM time that I've done on the track. So maybe the oil just changes color at high RPMS and higher than normal engine tempratures, if sustained enough and I have just been driving within legal limits so that the oil never got stressed like track conditions. On another note, my stock P-Zero tires don't seem to show any wear like I was worried about, even though I pulled out a bunch of melted rubber from the rear wheel wells. Musta been the slippery stuff from the track that I was sliding on.
05-07-2012, 03:42 AM | #7 |
Drives: 2011 2SS/RS Camaro Join Date: Apr 2012
You need to stay out of the water box with street tires
Frank
2011 2SS/RS L99 GMPP Exhaust |
05-07-2012, 07:17 PM | #8 |
One old fart to another, I'm taking mine to the track this summer with a bunch of my Ford fanatic neighbors. I'll let you know how it turns out. It feels as good as it did in the 70's, but I'm not sure about my reaction time now as opposed to 40 years ago.
05-07-2012, 07:45 PM | #9 |
Drives: 2010 M6 2SS Join Date: Mar 2011
Oil oxidizes and becomes significantly darker very quickly when it's in an engine...it gets aerated very easily in there. It's fine. If the oil stinks like fuel then you have a problem, but your car isn't very modified, so I'm sure the tune in it is fine.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
05-07-2012, 08:12 PM | #10 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
05-07-2012, 09:06 PM | #11 |
Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
What was the trap speed? That's a good indication of what the car could run with traction.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
05-08-2012, 12:00 AM | #12 |
Typo spotter sL99CAMA2011 is correct.
It was Mobile 1 synthetic from the Chevy Dealer and what GM recommends. I made sure before they did it that they would use the recommended oil from the manual. They say they did and charged me accordingly.
05-08-2012, 12:04 AM | #13 |
Trap speed 109.97
I know the car can do low 12's. The driver can't just yet. A little more practice and using the power judiciously will help bring the ET down.
Thread Tools | |
