JUICEDMOTORSPORTS
Suspension / Brakes / Chassis All suspension, brakes and chassis discussions.
Old 05-07-2012, 08:22 AM   #1
Leb SS2/RS
Leb SS2/RS's Avatar
Drives: 2011 Camaro SS2/RS
Big brake upgrade??! Suspension?
Hello camaro5 members,
My camaro is currently under build process... End result should be 850 hp and 780-800 tq .... All I have done for handling is Eibach Pro lowering springs, Eibach front and rear sway bars that's it... And my brakes were left stock the 4 piston brembo front and rear... What do I need to improve to get best handling but also keep it street daily driven(but track ready also) ?
And for the brakes what do you suggest I do? I have looked for big brake kits brembos, thy were too pricey .. Any suggestions to help advise a fellow member
Leb SS2/RS is offline   Reply With Quote
Old 05-07-2012, 08:52 AM   #2
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
Hi.
I don't know what your budget is, but this is what I would recommend for handling:
  • Pedders Xa coil overs
  • Pedders replacement subframe bushings
  • Pedders radius rod inserts
  • the other thing would be sway bars, but you already have those
Pedders actually sells a kit designed for daily drivers that just want better handling. It's called their Daily Driver package, LOL. The next step up from that is their Pace Car package (I think so anyway I could be wrong). Either or, if you contact Pete and let him know what your budget is, I'm sure he'll be more than happy to work with you to get the package that's best suited for your driving needs
For braking, I would contact Chase at Apex Speed. They are currently having a sale on 2-piece slotted rotors. Each rotor is like 3 or 4 pounds lighter than the stock rotors. Then pick up a set of Hawks High Performance brake pads and you'll be set.
Stieger's BLACK Build Thread thanks for the sig Russ
Old 05-07-2012, 08:55 AM   #3
Orange5thGen
Orange5thGen's Avatar
Drives: 2011 Convert
Send a message via Yahoo to Orange5thGen
You can get a set of CTSV brakes too..and sell your Brembo's to me.
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
Orange5thGen is offline   Reply With Quote
Old 05-07-2012, 09:18 AM   #4
Leb SS2/RS
Leb SS2/RS's Avatar
thxx for the help on suspension stieger, will contact pedders for sure... as for the brakes ur sure only changing the rotors and pads will handle tht much horsepower ?
Old 05-07-2012, 09:22 AM   #5
Leb SS2/RS
Leb SS2/RS's Avatar
orange5thgen ,any idea on where to buy the CTS-V brakes ? wouldnt mind selling mine to you but i live all the way in lebanon in the middle east :-P so serious shipping will be involved :-P
Old 05-07-2012, 09:31 AM   #6
The Stig
The Stig's Avatar
You *should* be OK with just swapping the rotors and pads. How aggressive of a pad you'll need I honestly don't know. If you're honestly worried about having enough stopping power then I would go for a big brake kit. Brakes are one thing you never want to half-ass
Old 05-07-2012, 10:03 AM   #7
Leb SS2/RS
Leb SS2/RS's Avatar
probably going to end up getting a big brake kit, your going to want to stop at some point :P pnly the fronts though, ill leave the rear one's stock!
thx for the help stieger, appreciate it
Old 05-07-2012, 11:18 AM   #8
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
For street or occasional track use a set of high quality performance pads should definitely be enough, but if you're going to spend a bunch of time on track use you may want to step up in brake sizes. You won't see huge benefits from a big brake kit until you spend some time on track. Larger brakes have the ability to carry larger amounts of heat generated by repeated stops over and over like you see on track. The factory brakes when paired with a performance brake pad should be enough for most anything you can throw at them on the street because typically with street driving the car will see single stopping events with plenty of time for heat to dissipate between them.
There isn't anything wrong at all with using a big brake kit on the street, but the factory brakes are actually pretty good for street use when paired with a performance pad.
Just so you know, we also manufacture Camaro suspension components! We offer everything from Drop Springs and Sway Bars, to replacement bushings and control arms, to full coilover systems. Whether you're building a street car or a full blown race car we have suspension parts that will help you meet your goals.
Since you're going to be putting down really big power we would suggest doing some mods to help you put power to the ground. Our Rear Arm Package consists of replacement Trailing Arms and Tie Rods, including all polyurethane bushings needed for install. The factory arms are known to deflect at both the arm and bushing, and these arms being both lighter and stronger than the factory will help mitigate some of the wheel hop you will see with big power.
Another item which will help tremendously to eliminate wheel hop and increase confidence while launching and driving are Solid Subframe Mounts. Sports cars like the Corvette have had their subframes solidly mounted to their chassis' for years now, and we just take that same idea and apply it to your Camaro. By solidly mounting the chassis to the rear subframe you eliminate a huge source of deflection with minimal impact to ride quality. Check out this video we took during development of the solid subframe mounts to see what a difference they make:
If you have any questions please feel free to shoot me an email! My direct address is jarrett@pfadtracing.com. We love discussing our parts and how they can help our clients reach their performance goals!
Old 05-07-2012, 01:36 PM   #9
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro 2SS
My 2010 goes into the shop tomorrow for the following upgrades.
StopTech Big Brake Kit 15inch rotors front/14inch rotors back
Pfadt Racing ASB's front and rear
Pfadt Rear Arm Package
KW Variant 3 Coilovers
I would have included the Pfadt Coilovers but they aren't being produced currently for the Camaro. I'll post my impressions shortly. I'll run the ASB's full stiff initially but not the KW's.
Next purchase will be wheels and Pirelli slicks for track days.
ERL 500 cu in Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, Invo's 295/275, MGW Shifter, StopTech BBK, KWv3's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
Old 05-07-2012, 01:38 PM   #10
Leb SS2/RS
Leb SS2/RS's Avatar
Pm sent pfadtracing
Old 05-07-2012, 01:41 PM   #11
Leb SS2/RS
Leb SS2/RS's Avatar
NICEE and gd luck doubleblank
Let me know on what The end result is!
I can't wait, my car still needs around a month and a half in the shop
For the build.. :-(
Old 05-07-2012, 01:43 PM   #12
ModBargains.com
ModBargains.com's Avatar
Drives: Camaro, 996TT, 335i, Etc.
Location: 1721 E. Lambert Rd. Unit C, La Habra, Ca 90631
Hi.
Couldn't have said it better myself. That's a good package there!
Jurrian Terpstra | Jurrian@ModBargains.com | (714) 582-3330 ext. 8002
Hours: Monday - Friday 8:00am-6:00pm | Saturday 8:00am-5:00pm (PST) Check out the ModBargains Blog!
Add me on Facebook! for up to date deals and more!
ModBargains.com is offline   Reply With Quote
Old 05-07-2012, 03:34 PM   #13
Leb SS2/RS
Leb SS2/RS's Avatar
Ill check that out too, am not in a hurry... Trying to fix the best set up that will serve my SS best keeping all the options open !
Thx for the help !!
