HeadlightArmor
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Transmission / Driveline
Old 05-07-2012, 04:56 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
Camaro 1,000HP Level 4 Direct Bolt-In Axles @ Phastek Performance
Camaro 1,000HP Level 4 Direct Bolt-In Axles - Street/Track Use :: 2010-2012 Camaro
2010, 2011, 2012 Camaro 1,000 HP Level 4 Direct Bolt-In Axles
1. New Anti-Wheel hop design with re-engineered thick bar
2. 108mm CV's on both ends for longer life
3. 300M center bars (from material out of Sweden)
4. Rated at 1000hp
5. Special grease use in conjunction with harder internal designed especially for the Camaro's unique axle angle.
6. Ecoated housings and powder coated bars for superior corrosion protection
7. 1 year warranty
8. Great for Daily driven and road coarse/circuit cars.
The Driveshaft Shop has done all the calculations and per-testing in machines and now its time to to send the new X4 design axles out and show how they work. The axles took a bit longer to make but they wanted to make sure the outcome was worth the wait. We had realized that allot of people were buying the 1400Hp axles that are unbelievable in strength but not exactly designed for a daily driven car. Sort of like a Drag Slick great on the track and does what its supposed to but you would not go get groceries with them on a daily basis.
This new design axle is being made with the new 300 material we are getting out of Sweden, it has by far been the strongest material we have worked with to date and even though these axles are using the smaller 28 spline they were designed for better strength in mind. What was done 1st was we had the material Ground to the exact size we wanted and rolled the spline onto it (Rolled splines are 35% stronger than traditional cut style splines)
We then wanted to be able to go back to the Anti-Wheel hop design but know that one thicker bar would break and we wanted to take the time to figure out how to get an axle with more torsional resistance than a straight bar but not to the point that it caused an issue with it. After much work and testing we came up with this new design.
The bar with the thicker center will not twist as much as a straight bar but with the ends machined this far back it allows the stress to be spread over a larger area and saved the bar from being broke. The next thing we did was install a set of ends on a car that was lowered, we did this to be able to see where not only a Stock height axle needs to ride but also one in a lowered car. One of the reasons these cars have axle issues is the fact that the axle at stock ride height leaves the wheel and heads up to the wheel and an angle, so when a car is lowered the angle become greater and makes the CV work allot harder. We use this 108mmm CV on quite a few platforms, there in numerous fast Vette's GTO's, SRT8's Supras and quite a few other cars that we make axles for but don't have the issues of the angle the Camaro has. We even use the Same ones in all the Pro-Drift Car Axles we make for most of the Pro teams but this Camaro has posed a challenge to the joint being its on such an angle. Our solution was to make an inner Race that not only can handle the stress but also be hearty enough for the angle. We went over to our good friend Randy Halls Shop on Jake Alexander, Randy and Brian run a 5 second 67 Camaro (1/8th) and they take our display to all the local events so they were glad to help when asked. We put Brains car up on the drive on lift to get some dimensions, we already had the Stock length but wanted to see how the lowered car effected the length. take a look, we used mock up axles during the fitting to ensure correct fitment and CV alignment. This set will differ from the 1400hp axle in that the outer will go back to a bolt on style but revisions have been made to move the head of the CV back to the wheel side for better clearance of the bolts and the Boot, We first mocked this up on our cradle that we have for measuring and then double checked it on Brian's car to ensure there would be not issues.
So there we have the completed product with new design outer mounting, Ends are E-coateded and the center of the axle Powder coated in our in house system the CV will not have a stronger or harder inner race but also have the Chromoly cage adding extra strength to the system. We have re-developed the Anti-Wheel hop design to be able to ensure the axles will help with the issue but also be higher torque friendly for cars that will punish them like they are bought for.
Order yours today at www.PhastekPerformance.com
Sales@Phastek is online now   Reply With Quote
Old 05-14-2012, 02:26 PM   #2
Sales@Phastek
Taking orders
Old 05-31-2012, 10:51 AM   #3
Sales@Phastek
post or pm if you have questions
Old 06-12-2012, 01:16 PM   #4
Sales@Phastek
post or pm with questions
Old 06-18-2012, 03:46 PM   #5
Sales@Phastek
HI !
Old 06-24-2012, 10:01 PM   #6
rhunley14
Drives: Camaro SS
How much?
rhunley14 is offline   Reply With Quote
Old 06-25-2012, 02:22 PM   #7
Sales@Phastek
pm sent.
Old 07-09-2012, 01:18 PM   #8
Sales@Phastek
post or pm with questions...
Old 09-07-2012, 01:02 AM   #9
Racecarguy
Drives: 2011 CGM vert
pm for pricing please
Racecarguy is offline   Reply With Quote
Old 09-09-2012, 10:52 PM   #10
SirCrush32
Drives: 2012 Camaro 2SS/RS 45th Anniv Edt
PM for pricing please
SirCrush32 is offline   Reply With Quote
Old 09-09-2012, 11:16 PM   #11
Blk-Ice
750HP of Twisted Reaper!
Blk-Ice's Avatar
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes
What's the price?
Fear the LMR Twisted Reaper Brotherhood!
Blk-Ice is offline   Reply With Quote
