sjm autoprod
Old 08-08-2012, 08:37 AM   #365
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Originally Posted by chappy48 View Post
It may have been said earlier, but I can't remember so forgive me...but what is actually causing the TB's to close? Something in the ECU? It's happening at all HP ranges, so it doesn't sound like it's the flow of air. What in the tune would make it close vs staying open and working as advertised?
Ryan did a good job of explaining this, but there is another side to this as well.
Predicted Air flow tables must be adjusted to match actual, Your All Set No worries.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 08-08-2012, 09:54 AM   #366
Ryne @ CMS
Ryne @ CMS's Avatar
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra
Ted.
yeah i didnt go into the calibration side, i explained more of the TB issue itself...
Ryne @ CMS is offline   Reply With Quote
Old 08-11-2012, 05:40 PM   #367
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
i just got off the dyno .... Patrick G made all kinds of adjustments and its still closing around 6500 rpms... besides that everything is great... he spend about 3 hours working on it this morning... Talked with Nick W. as well him and patrick are gonna get together to see what else needs to be looked at. Hopefully we can get it right!!
Whipped416 is offline   Reply With Quote
Old 08-11-2012, 05:41 PM   #368
Whipped416
Whipped416's Avatar
Also to note, Nick Williams has been great with his continued support to resolve this issue!!!
Old 08-11-2012, 08:08 PM   #369
TeddyP25
TeddyP25's Avatar
Drives: 2SS
Actually witnessed this happen today on the dyno with a buddy's car (Blue70SS) closed 3 times on I think 4 pulls..
2SS/RS CGM/BLK GFX MN6418 Stroker.785rwhp/885lbtq.50 SHOT NO2..Pfadt arms,toe links,coilovers,swaybars,end links,engine mounts,dif/sub bushings.MGWshifter.Tick LVL 3.ARH1 7/8 LT's/ARH exhaust.ADM gauges/race CAI.E-FORCE SC.8 rib IW 10%OD.LPE dual pump/module.85lb inj,custom valve covers.RMCR tune.TOOLEY RACING CAM.JRE posi kit.JRE fuel upgrade.RX MONSTER CatchCan.DSS axels/DS.Hammerhead rear, 3:73's. WYOSPEED builthttp://www.camaro5.com/forums/showthread.php?t=115687
TeddyP25 is offline   Reply With Quote
Old 08-12-2012, 12:55 PM   #370
Whipped416
Whipped416's Avatar
did they ever figure is out Teddy? we thought maybe it had a weak motor replaced with a brand new motor and still closing around the same rpms....
Old 08-12-2012, 01:23 PM   #371
TeddyP25
TeddyP25's Avatar
Drives: 2SS
This was the old version, reset codes and continued. Still was interesting to see this happen live. I believe Blue is awaiting the upgrade version.
Old 08-12-2012, 01:53 PM   #372
Whipped416
Whipped416's Avatar
i had the upgrade made it go another 1000 rpms before shutting down..
Old 08-13-2012, 01:37 AM   #373
JUISSD
JUISSD's Avatar
Drives: 2010 White/IOM 2SS/RS M6
Originally Posted by Ryne @ CMS View Post
vacuum behind the TB created by the blower over powers the TB electric motor and starts to pull it closed... once the the Actual TPS changes from the commanded/predicted in comparison to the accelerator pedal % the car instantly goes in Reduced engine power mode because of safety protocols built into the PCM.... my experience is you can turn off codes that are trigger when this happens but the car will still go into reduced engine power... i heard that NW has resolved some of the issues of the blade closing....
What about centrifugal blower set ups that are blowing through the tb instead of pulling?
2010 White/IOM Camaro 2SS/RS M6
JUISSD is offline   Reply With Quote
Old 08-13-2012, 09:25 AM   #374
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
So the upgrade fix for the origional NW102 doesn't work, the newer NW102, or both? Was just packaging mine for the fix.
LPE Brotherhood
Old 08-13-2012, 09:40 AM   #375
JANNETTYRACING
It is in the tune
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-13-2012, 12:55 PM   #376
Whipped416
Whipped416's Avatar
i wish you could tell me what needs to be looked at because patrick worked on it 3-4 hrs saturday with no luck...
Old 08-13-2012, 01:22 PM   #377
JANNETTYRACING
This would be the fourth attempt to try to help you I've asked you to have your tuner call me but my phone didn't ring I am on the road today but will be back in the office tomorrow
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 08-13-2012, 08:21 PM   #378
Whipped416
Whipped416's Avatar
Ted i dont think its in the tune.. As everyone knows Patrick is a complete tuner and very expierenced with big builds and high horsepower setups.. Nick is sending me a 1.5 inch honey comb spacer with a new tb with a stronger inlet.. Will be at LSX performance to get on the dyno Wednesday night to see how it turns out..
boooo, oc2donefixed
