| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
#101 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010camaro Join Date: Aug 2009
#102 |
![]() Drives: 2010 RS/SS2 Join Date: Jul 2009
A: there has been a problem for two years.
B: I can't stand when people try to sugar coat anything. C: who is he to tell anyone after the fact "they" are working on it? D: we took your money, deal with it attitude pisses the nicest people off. Is that enough reason to be upset about it? It is in my book.
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block. First to run 11's cam only First to run 11's all motor First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous) First to run 10's (10.55) on motor in 2010 Camaro First to break into the 5's (5.97) 1/8th mile First to cut a 1.5X sixty foot First to cut a 1.4x sixty foot First to car to cut a 1.3x 60ft |
#103 |
![]() ![]() Drives: 2010 Camaro Auto 2SS/RS Join Date: Oct 2008
Be mad. Not saying you don't have a reason not to be. I just bought a NW 102 and am concerned now since reading this thread. But I know Ted will fix it and make it right. Just try to leave the personal attacks out of it. Can't we all just get along! :P
Built by Jannetty Racing
670rwhp/649rwtq...Scariness to be determined. Jannety Racing forged 416. TVS2300 Supercharger w/Maggie Max Stage 2, 3.6 Pulley, Innovators West 8 rib conversion, OD rear Cog belt drive. Jannetty Racing Rough Idle Cam, LS3 Conversion. Jannetty Racing built 6l80e Trans, Jannetty Racing Custom Converter, Built rear diff w/ 3.45 gears, DSS driveshaft and 1400 hp axles. ADM Twin Pump Fuel System, ADM CAI, Dynatech 1 7/8" Coated Headers, Borla "S" Catback. Custom 18" Forgestar F14's, Nitto 305/45-18 DR's |
#104 |
I think that Scoggin Dickey is the only outlet that is selling these. If anyone is having a problem maybe they should take it up with them. The original C5 version is good up to at least 1200 rwhp with no issues.
2012 ZL1 #1278
2010 2nd Place Fastest 4 5th Gen LSX Shootout 2011 2nd Place Fastest 4 5th Gen LSX Shootout |
#105 |
![]() Drives: 2010 Black SS M6 Join Date: May 2011
Where are the Mods? There have been at least 4 major rules broken here and the thread is still open for the attitudes to post in. What gives?
I can speak for the NW102 TB on the application that is was designed for. As Hendrix stated it was designed for the FAST 102 manifold and it works great. I admit mine has been finicky for my tuner but they occasionally are. Should there be a disclaimer about high horsepower motors...maybe. How many threads have we seen about wheels being damaged by holes in the road and the ensuing complaints from the owners? It wasnt the manufactures that came on here and said anything it was the dealers! There also wasnt any disclaimers from the manufactures that said if you hit a pothole you wheel is going to be damaged. So why are we getting bent out of shape over 14 throttle bodies not working the way they are suppose to on an application they werent designed for? There seems to be other solutions so if you arent happy with the NW go with something else. Everyone is acting like this is the first time in their life they bought something that didnt work like it was suppose to. Oh wait the complaints are from the guys that the TB is only 1% of the cost of their motors. How about we keep the thread moving toward a solution instead of personal attacks. If we cant then Mods please close the thread and follow the rules with appropriate punishments.
Black 2SS/RS with Silver Stripes
454 installed! |
#106 |
![]() Drives: n/a Join Date: May 2012
I'm pretty sure that I have came up with an easy solution to the problems you guys are having. I made a prototype last week that had over 50% more holding power before shutting. Now I just have to get the production parts made for final testing on a car. Should be done in a few days, I'm waiting on custom tooling to come in. This fix will require the throttle body being sent back to me for machining and change of internal parts.
For the record, this has never been an actual problem with the throttle body, or its design. The failure comes from a safety precaution that is coded into the PCM from GM. When it sees too much load on the TAC motor, it shuts down. This has acutally happend in extreme situations even with the stock throttle body, however it is usually more prominent with the bigger sizes. One reason being that the bigger the blade is, the more surface area it has for the air to have an effect on. Another being that the leading edge of the blade is further from the center of rotation, thus giving the air pushing or pulling on it more leverage. I have seen this happen with the ls2, ls3 and C5 designs at some point. With that explained, you guys should know that I haven't been just standing around. I have considered and tested many options trying to work around the safety precations. The ones tested til now just haven't been successful. I've even had someone working on rewriting the section of code in the computer for me since none of the current tuning software providers will implement it. Each individual combination is slightly different and the issue comes up at different power levels. There is no good way to predict and say at a "X" horspower or with a particular setup you will have issues. Just too many variables to consider. Most blow through setups never give issues. I have heard of one guy that had an issue N/A. I even had one customer with a Kenne Bell on a Vette tell me he never has any problems. So far the only proven fix has been to change to another computer system such as Motec or the Holley. With those, I haven't seen an issue yet. I will keep you guys updated on the progress. Nick |
#107 |
10.48 @ 131.58 mph
Drives: Black & Yellow 2SS/RS LPE LS7 427 Join Date: Mar 2010
Thanks Nick. We scream for development of new power mods for new cars and many manufacturers rise to the occasion and offer the same. I don't understand why some have issues with glitches in new applications for these products. Most, if not all of us appreciate your efforts and look forward to a reliable 102mm TB for FI use. Mine will be ready to ship when your ready to pull the trigger, and I'll be more than happy to pay for the modifications.
Bryan |
#108 |
![]() ![]() ![]() Drives: 2010 White/IOM 2SS/RS M6 Join Date: Jul 2010
Nick, I'll be running your tb on a FAST 102 intake with a Procharger F1-R at 19-20psi and should be making right around 1000rwhp. Do you anticipate problems with that set up or will it be a crapshoot?
2010 White/IOM Camaro 2SS/RS M6
#109 | |
#110 |
thanks nick for posting, glad to see you took the time to let us know what is going on instead of 20 different versions ...
#111 |
![]() Drives: 2010 Camaro SS / 2006 CC Duramax Join Date: Aug 2009
Yes it will be a problem. I had one fail on a 2010 Camaro with the NW 102 on a FAST 102. It has a single 88mm turbo. It caused a real problem when the car wouldn't run at the TX Mile event last year due to the tb failing. That NW 102 tb caused alot of problems for us over the weekend.
#112 | |
![]() ![]() Drives: Black 2010 2SS/RS LS3 Join Date: May 2010
#113 |
The Fast 102 intake did nothing for my Ls3, I put the (older nw102) tb on and it picked up 8 total rwhp. I did see where someone posted the intake picked up some power on a FI car recently.
2010 SS/RS SIM
#114 |
![]() ![]() Drives: 2010 IOM SS Join Date: Aug 2009
bump for any updates
Jannetty Racing Built
#115 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: V10 BMW M5, Supercharged 2SS/RS Join Date: Jun 2010
I have an update. My NW 102 slammed on me two days ago on the STREET. 2nd gear about 5500 rpm and slap!! Reduced engine power. I thought I dropped a valve. DTC P2135
. Had to clear the DTC and cycle the engine a couple times.
MAST 416 STROKER: RDS STAGE 3 TVS 2300 CUSTOM CAM TPIS 102 TB IW 8 RIB PULLEY W/ OD COG REARS NX EXPRESS NITROUS KIT CMGS METHANOL INJECTION RX CHILLER CIRCLE D 2800 TCFLEX PLATE /ADM TRANS COOLER DSS DRIVESHAFT/1400 HP AXLES LPE 3.70 GEARS/JRE POSI MOD DYNATECH HEADERS/MAGNAFLOW EXHAUST/ TEST PIPES SQUASH RETURN STYLE E85 FS/ID 850's BMR/EIBACH SUSPENSION Killing mustangs,because the good Lord wants me to |
#116 | |
Are you in Charlotte NC or NY? If you are in NC at them moment I have a prototype I would be interested in testing on your car. Nick |
#117 |
Cool deal. That's progress. Any idea how long these prototypes will be tested before a final fix is released.
#118 | |
#119 | |
PRESIDENT CALIBRATOR JRE
![]() Drives: YELLOW 2013 ZL1 AUTO Join Date: Jun 2009
![]() But your Problem is unique to your car.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs! Ted Jannetty Jannetty Racing Ent Inc. 2984 East Main St. Waterbury Ct. 06705 203-753-7223 tedj@jannettyracing.com www.jannettyracing.com www.turboaddictionparts.com Performance Parts |
#120 | |
Plus I was bored today
![]() Last edited by nyny69; 05-21-2012 at 01:46 PM. |
#121 |
from what i have heard, nick is busy and has some prototypes out in the field...a couple are vendors here , so i will let them post..buy there is def some testing going on...it would def be a bonus to try on cars that have failed..like jamie and lex,as they def had failures, imo
#122 |
PM SENT
#123 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
Yes, testing has commenced.
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#124 |
i knew it before you did...lol
#125 |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
I thought this was a fast car issue? ![]() ![]()
Built by Vengeance Racing
9.31@154.81 mph Procharger F1-X RPM Level 7 4L80e + Coan Converter Hendrix 9" Rear Axle + 3.50 Gear ARH 2" LTs+3.5" Exhaust Fore Fuel System, Bogarts + Hoosier Slicks Pfadt Drag Pack Suspension My Build Thread | Best Pass To Date |
| Tags |
| boooo, oc2donefixed |
| Thread Tools | |
