JUICEDMOTORSPORTS
Old 05-07-2012, 10:24 PM   #1
HDRDTD
Wax Clear Bra?
Forgive the stupid question but does one apply wax to the Clear Bra (Avery Nanofusion) like they do the pinted surfaces?
Old 05-07-2012, 10:47 PM   #2
Fiveg56
Drives: -
I have the 3M film. They say I can apply wax if I want...but I have not...dont really see a need to I guess.
Fiveg56 is offline   Reply With Quote
Old 05-08-2012, 06:17 AM   #3
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
It's up to you if you want to, but to answer your question yes you may.
Old 05-08-2012, 09:15 AM   #4
Dznts
Anabolic Connoisseur
Dznts's Avatar
i keep mine waxed, as my installer told me too.
Old 05-08-2012, 09:28 AM   #5
zkdreads
zkdreads's Avatar
Drives: 2010 Camaro LS V6
u can wax it. its no need. it doesnt do anything, doesnt hurt anything either
C-LO or Sonic
"Without Struggle there is no progress"
I am your best nightmare!
zkdreads is offline   Reply With Quote
Old 05-08-2012, 12:30 PM   #6
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
As the others said, you can, but its not required.
One tip I would give you is to mask the edge of it prior to doing any wax or polish work. The edges get caked up with product which can look pretty ugly. Prevention is the best medicine.
Adam's Polishes is online now   Reply With Quote
Old 05-08-2012, 12:45 PM   #7
Swacer
Drives: 2012 Camaro 2SS/RS
My installer said to wax it the same time as the car. I have 3M. So I use the same wax on it that I use on the car.
2012 2SS/RS Camaro~Imperial Blue Metallic~LS3~M6~GM High Spoiler~GM Ground Effect~GM Tower Brace~Heritage Grill~Roto-Fab Cold Air Intake~Stainless Works Exhaust~Stainless Power Headers~VMAX Ported Throttle Body~BTR Stage 4 Cam~BTR CNC LS3 Heads~FAST 102 Intake~1LE 3.91 Gears~LPW Rear Cover~GEN5DYI Spare Clutch Reservior~Barton Short Throw~ShowStopper Side Markers~UMI Performance Trailing Arms~UMI Performance Tunnel Brace~Elite Engineering Catch Can~VMR V710s
Swacer is offline   Reply With Quote
Old 05-10-2012, 09:24 AM   #8
SmokinBills 2SS
SmokinBills 2SS's Avatar
Drives: 2SS Cammed up, Clear Bra, Clean
If you don't put a sealer on the clear bra, you will get bug stains and bird poop stains easier. Keep it slick and protected or it will just protect from rock chips only
SmokinBills 2SS is offline   Reply With Quote
Old 05-10-2012, 10:41 AM   #9
GPC1
GPC1's Avatar
Drives: Camaro SS
We install the 3M clear film here and like many of the others have said, you can but you don't have to. And like Dylan said, stay away from the edges
GPC1 is offline   Reply With Quote
Old 05-10-2012, 10:49 AM   #10
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
I would recommend something like Ultima Paint Guard Plus or BLACKFIRE Crystal Seal. Both of these products are wipe on and walk away sealants. You simply mist on to the clear bra, spread into a thin coat, and walk away. The product self levels and dries to an amazing high gloss. The best part is that you don't have to worry about wax in the cracks or along the seem, these prodcuts dry 100 percent clear.
It is the same sealant used in these threads: BLACKFIRE Crystal Sealant- The 7 minute high gloss shine
BLACKFIRE Rapid Fire
