HURST
Old 05-08-2012, 02:52 PM   #1
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
FS: Brand new ARH cats.
As the title says, I have a brand new set of ARH cats. So new, I haven't even opened the package that everything came in, so sorry, no pics until the weekend, if it's absolutely needed. Before doing my research, I didn't realize that I didn't need them, so my loss is your gain. I will consider offers until May 19.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 05-08-2012, 03:30 PM   #2
Synack
Synack's Avatar
Drives: 2011 Camaro SS/RS M6 w/groundFX
These bolt up to stock header? Gains?
Cobalt SS > Nismo 370Z > Camaro SS/RS
Synack is offline   Reply With Quote
Old 05-08-2012, 06:10 PM   #3
Chris82xx
Chris82xx's Avatar
To be honest I really don't know. Hopefully someone with more knowledge can chime in. I bought them as a set when I bought the matching headers, after doing my research, I learned that it's pointless to have cats when your car is blown, so I'm trying to sell the cats and I'm just gonna use test pipes.
811RWHP/719RWTQ
Old 05-08-2012, 06:41 PM   #4
TRIPWIRE
Chillin Like a Villain
TRIPWIRE's Avatar
Drives: 2013 2SS Blue Ray Metallic Dusk Ed.
no they do not theres really only two that bolt up to stock headers those are solo and jba
TRIPWIRE is offline   Reply With Quote
Old 05-08-2012, 07:34 PM   #5
Synack
Synack's Avatar
Haha well that narrows it down QUITE a bit, thanks.
Old 05-08-2012, 11:28 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
These are cats only, not midpipe replacements. They will fit ARH headers for sure. Not sure what other brands they may fit.
OP:
You might want to give the in/out diameters.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 05-08-2012, 11:32 PM   #7
Blackkaz04
Drives: In the market
I am betting they are 3 inch in and 2.5 out...I WISH i had seen these a couple days ago...I ordered these from ARH just days ago...bah!
op:btw, I am blown and running cats works just fine.
Blackkaz04 is offline   Reply With Quote
Old 05-09-2012, 10:08 PM   #8
TrojanRay2418
Drives: 2010 2ss/rs
Dibs. Pm sent
TrojanRay2418 is offline   Reply With Quote
