| Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection Anything related to keeping your Camaro clean and in good cosmetic condition. |
Thread Tools |
![]() Drives: 2012 Chevrolet Camaro 2LS Join Date: Jan 2010
Hello everyone!
Well im writing today about help removing a stain:(…. The other day I left a bottle of body spray in my cupholder. I guess with the heat (living in Florida) made the bottle not explode, but leak a little. Most of it leaked into my cupholder which I easily cleaned out. A little bit of it dropped on the silver part of the center console. I do not have a picture of this, its just a small stain the size of a dime in the silver part. I tried using Armorall interior cleaning wipes but barely did anything. I was wondering if you guys know of any good cleaner that could get rid of this? I included an image with a red square around where the stain is to better help show it. It’s just a generic image but resembles my car. What do you guys think? Any help would be awesome!
Drives: 73 Camaro Z28 (Sold) Join Date: Jun 2009
The only thing that comes to mind is replacing it or trying Optimum Power clean. Would be nice to see it in a picture. Sorry to see tbis happen to you.
#3 | |
Thanks, I will pick that up and try it out. If not, I can always replace it (maybe an excuse to get the leather center consoles I have seen on here lo). It sucks but it is bound to happen, also it is barely noticable but since only having the car for about a month its on my mind..... Grrr PS I see the cleaner online, do you know if they would sell at advance or autozone?
Drives: 2010 Mazdaspeed 3 Join Date: Mar 2012
Can you 'feel' the stain at all? Is it something, like a residue that is stuck on the surface, or is it completely flat and even to the surface?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2009 Avalanche Join Date: Mar 2010
You're likely not going to find a good product for this job at autozone.
Before you pull the trigger on ordering though, maybe post a picture of it. Oddly enough this isn't the first time I've heard of this happening, and in the previous case a cleaner wasn't enough to remove the discoloration caused by some Axe body spray. Does the spot 'feel' any different than the surrounding area. Not sure whats in those body sprays, but the other case of this it actually bubbled the surface slightly. Edit - Todd beat me to it.
#6 |
Getting picture in a minute, stay tuned...
#7 |
Here it is...
#8 |
And you can not feel it. It feels just like the rest of this part... I don't know if that helps.
#9 |
If you cannot feel or detect that it is slightly higher than the rest of the surface (like product that has dried on top of it) then it is likely that the solvents have actually penetrated and stained the plastic itself. IF this is the case you can remove it.
Hopefully it is just a very thin residue stain. You can try a high quality APC, such as the one suggested by Angelo or even diluted ispropyl alcohol. |
#10 |
Thank you Todd and everyone else. I am going to see if there is anything I can pickup around me, if not I will order the product Angelo mentioned.
#11 |
![]() ![]() ![]() ![]() Drives: 2012 45th Vert, 2011 4x4, 9sec Vega Join Date: Mar 2012
Think of what that crap is doing to your body if it does that to your car
#12 | |
I keep it on clothes, but good point....
#13 | |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
Don't feel bad, a few years back I had a scented oil air freshner clipped on the ac duct in my Hummer, after sitting in the hot sun all day it leaked out as did your bottle. It dripped down the heater and radio controls literally melting the trim. I was rip roaring mad. I ended up relacing it with a new one, not the trim, the Hummer.
#15 | |
Wow! Well im sorry about that happening to you in the past. Same thing happened to my 94 Camaro, though was an older car and had its own cosmetic issues besides just that. Hopefully I do not need to replace anything for my Camaro, I will order that stuff tonight!
#16 | |
#17 | |
Yea true... If it doesnt clean up, is there a gmparts site that sells this part?
#18 |
#19 |
Thank you Angelo and Todd, and everyone else. Just purchased this with the 10% off at Autopia! Hopefully this works, and seems like a good cleaner for any future issues :/
#20 | |
See how it works. Heck you could even pull the trim and repaint it yourself (body color or whatever). Best of luck and make sure to let us know how it turns out! |
#21 |
Will do. I see you are located nearby? For future reference does Autopia have a store in Orlando/Stuart?
#22 | |
#23 |
![]() Drives: 2012 Camaro SS2 Join Date: Dec 2011
Lighter fluid (no, not lit). If that does not remove it then the stain is inset into the plastic and it can either be sanded and repainted or replaced.
Some items that you should be careful of are: deodorants, tanning solutions, body sprays, all hair care products. These things are rough on the cars surfaces. To remove most things an oil based remover is best, which is why I say lighter fluid. Other products can dry out the parts causing future problems. You can also try WD40. |
#24 |
Lets go Rangers!!!
Close but yet so far. If I order from you guys not only do I get hit with shipping, I get hit with tax.
#25 | |
I will remember this if I order alot at once, could save a bit on shipping!
| Thread Tools | |
