Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Suspension / Chassis / Brakes
Old 05-09-2012, 01:30 PM   #1
Sales@Phastek
Sales@Phastek's Avatar
Drives: 2010 X5 Camaro Turbo
Air Lift Lifestyle Manual Combo Lowering Kit @ Phastek Performance
2010, 2011, 2012 Camaro SS/LS/LT/RS Air Lift Performance Lifestyle Manual Combo Kit #77775
Lifestyle Manual Combo Kit Includes:
- Front Kit (75575)
- Rear Kit (75675)
- 4 Paddle Valves
- 2 Dual Needle Gauges
- Viair 380 Compressor
- 5 Gallon Air Tank
- 1/4" Airlines
- All fitting and hardware
- 1 year warranty and excellent customer service!
Performance Data:
- Front Drop: 102mm/4”
- Rear Drop: 102mm/4”
- Total Lift: 25.4mm/1" above OEM
- Track proven faster lap times than OEM
- Ride rated more comfortable than OEM
- Reduced wheel hop on acceleration
Tech Specs:
- Fits all Camaro 2010+
- 9-level damping adjustable struts
- Powdercoated black steel
- Anodized red aluminum
- 2+ degrees neg. front camber adjustment
- QA1 rear performance valved rear dampers
Air Lift’s engineering team has developed the ultimate suspension for the 5th Gen Camaro. This fully adjustable, bolt-on kit offers the lowest stance possible for the Camaro, outstanding handling, and tunable ride quality. This suspension is CAD designed, then tuned and optimized using the racetrack, real world public roads, and Air Lift’s industry leading hydraulic test rig, to provide the consumer with an unbeatable suspension. Unlike drop springs, this product actually maintains significant wheel travel which benefits both the ride quality and the handling. The kit fits both V-8 and V-6 models.
The Camaro looks amazing with this lowered suspension! Starting with the static drops, the kit lowers the car 4” below stock and can lift it 1″ over stock. To top it off, 22” wheels will tuck easily behind the fenders, giving you an enviable stance. And of course, with adjustable air suspension, the car can be raised to get over speed bumps, or up steep driveways, saving damage to ground effects, spoilers and exhaust systems.
Performance junkies will not be disappointed either. Road course testing with Air Lift’s data acquisition equipped Camaro helped the engineers tune the suspension spring and damper rates for a handling experience rivaling that of a quality coil-over set-up. Lap times and feel both improved over stock.
Ride quality is a high priority with any Air Lift product, and the Camaro kit excels. The front uses a proprietary, 9-level adjustable strut. The rear features a QA-1 shock at the heart of the air-over assembly with a progressive spring rate piston. This combination yields a sporty, well controlled, comfortable ride over any surface, and is tunable by the consumer.
In order to bring to market the most durable air suspension possible, Air Lift tortured the components of this kit to 1 million cycles (equal to approximately 100K miles) on their hydraulic test rig at temperatures from -30 deg F to 150 deg F. Couple this test lab work with thousands of miles of on-road testing and the 1 year manufacturer’s warranty: this is a kit you can count on to handle whatever the road throws down!
Order yours at www.PhastekPerformance.com
Sales@Phastek is offline   Reply With Quote
Old 05-18-2012, 03:53 PM   #2
Sales@Phastek
Taking orders all day long
Old 06-06-2012, 12:15 PM   #3
Sales@Phastek
post or pm if you have questions
Old 06-13-2012, 01:40 PM   #4
Sales@Phastek
post or pm with questions
Old 06-21-2012, 01:19 PM   #5
Sales@Phastek
taking orders daily
Old 07-06-2012, 03:04 PM   #6
Sales@Phastek
taking orders
Old 07-06-2015, 01:56 AM   #7
iKhans
Black & Blue is how we do
iKhans's Avatar
Drives: 2010 Camaro RS (Blue)
Send a message via Skype™ to iKhans
shipped to 77373?
iKhans is offline   Reply With Quote
Old 07-08-2015, 11:38 AM   #8
Sales@Phastek
Originally Posted by iKhans View Post
shipped to 77373?
iKhans,
Unfortunately we had some issues with the manufacturer and we are no longer offering this kit.
Thank you,
Ricardo
