SDTW Custom Wheels & Tires
Old 05-09-2012, 05:50 PM   #1
SSYNRS
It return's the favor !
SSYNRS's Avatar
Drives: "Synergy" Summit White 2-26-12
Camaro Dies while Driving - HELP
Three times today ... I Need help / advise !!
(quock details, background)
Here is what happened;
Pulled Camaro out of garage, turned around and put back in.
Installed ZL1 Spoiler, Plugged in the 3rd Brake Light Harness (previously wired / working) got ready for work and;
#1 - Camaro wouldn't Turn over.
Baffled and needing to get to work I thought I would try fusebox.
looked at fuses 16,17&18 all good - Tried again and started ?!?!?
Did not turn Camaro off but had to return a Redbox and get a sandwich.
#2 - Died at a stop light (no I didn't kill it)
Popped the hood, puled / reseated 16,17 &18 and started again ?!?
Got on the freeway, cause now I am in a time crunch and need to get to work
#3 - 15 miles later at 75 MPH it died again,
Put Clutch In, Headed toward the off ramp, Let out clutch thinking 'Push-Start" and no-go.. Rules out the Starter being the trouble.
Lastly,
The 1st time (in my garage) when I got it started, there was no "Check Engine" light, the other times the light stayed on.
The only message I saw was "Engine is running with Reduced Power" that was when the ign was on, buit not starting and when it died on the freeway at 75.
So, Has anyone heard of this ?
Next time I intend on trying the fuses one at a time to narrow it down.
Someone might ask;
I have not taped in to any wires
I do have a Plug-n-Play harness to keep DRL lights on
I have a Plug-n-Play harness for the ZL1 Spoiler
I have one of these "add-a-fuse's plugged in to "Spare" (fuse #52)
UPDATE - Just tried starting three times (in a row) and worked all three.
so rules out not starting/running every time I turn it off.
After the three attempts, I popped the hood and unplugged and pulled the wires out of the fuse box for the above add-a-fuse.
Still Baffled, Any suggestions ?!?!?
$DO || ! $DO ; try
try: command not found
My purchase thread (build to come);
http://www.camaro5.com/forums/showthread.php?t=205615
SSYNRS is offline   Reply With Quote
Old 05-09-2012, 06:23 PM   #2
SS King
SS King's Avatar
Drives: a Panty Dropper
sounds like u have a loose ground somewhere
SS King is offline   Reply With Quote
Old 05-09-2012, 06:28 PM   #3
strych9
Gone Euro!
strych9's Avatar
Drives: 6spd Manual Mercedes, Daytona 955i
+1 I thought this too. Did you take any body eyelet connections loose? If so, recheck them.
Bye bye, Bumblebee!
Old 05-09-2012, 08:13 PM   #4
SSYNRS
SSYNRS's Avatar
Still Dying, not starting
The only bolt I have loosened from the car is the passenger side Upper Radiator Mount for a "Ground".
Here is the latest update -
I let it cool down after the three starts in a row...
Started fine, again, again let it idle for 5 minutes but had to turn it off to do some work (I am at work now)...
10 minutes later, Started, again and let it idle ...
About 7 minutes it died...
Error "Service Stabilitrack"
Error "Engine is running with Reduced Power"
EXCELLENT, At least now I am pretty sure it will fail for the Service Guys tomorrow.... Also gives me a chance to play with which fuse to pull/reseat.
Pulled only Fuse #16 - (5amp Run/Crank IP)
Started and let idle
6 minutes later it died...
Pulled only Fuse #17 - (5amp SDM/IGN)
3 minutes later it died...
Pulled Fuse #18 - nothing - k, don't need to pull 18 again
Still not starting so I Thought I would read what else is in the fuse box
Pulled the K50 Relay and also wiggled pretty much everything else in the fuse box, because I was there.
Worked, Started, again but unable to let idle - had to get back to work.
maybe again later.
Any other Suggestions ?!?
J-Case Fuses Usage
Fuse 6 Wiper
Fuse 12 Starter
Fuse 22 Brake Vacuum Pump
Fuse 25 Power Windows Rear
Fuse 26 Power Windows Front
Fuse 27 Rear Defog
Fuse 41 Cooling Fan High
Fuse 42 Front Heater, Ventilation and Air Conditioning
Fuse 43 Antilock Brake System Pump
Fuse 44 Cooling Fan Low
Mini Fuses Usage
Fuse 1 Air Conditioning Compressor Clutch
Fuse 2 Transmission Control Module
Fuse 5 Engine Control Module Main
Fuse 7 Pre-Catalytic Converter Oxygen Sensor
Fuse 8 Post-Catalytic Converter Oxygen Sensor
Fuse 9 Fuel Injectors - Even
Fuse 10 Fuel Injectors - Odd
Fuse 11 Cooling Fan Relay
Fuse 14 Manifold Air Flow/Chassis Control
Fuse 15 Ignition
Fuse 16 Run/Crank IP
Fuse 17 Sensing Diagnostic Module/Ignition
Fuse 18 Run/Crank Body
Fuse 19 Transmission Control Module/Ignition
Fuse 20 Engine Control Module/Ignition
Fuse 31 Outside Rear View Mirror
Fuse 32 Canister Vent Solenoid
Fuse 33 Body Control Module #6
Fuse 34 Sunroof
Fuse 35 Front Heated Seats
Fuse 38 Washer Pump Front
Fuse 40 Antilock Brake System Valves
Fuse 46 HID Headlamp - Left Front
Fuse 47 HID Headlamp - Right Front
Fuse 50 Fog Lamps
Fuse 51 Horn
Fuse 52 Spare
Fuse 55 High Beam Headlamp - Right Front
Fuse 56 High Beam Headlamp -Left Front
Fuse 61 Heated Mirror
Mini Relays Usage
Relay K26 Powertrain
Relay K50 Run / Crank
Relay K55 Rear Defog
Relay K612 Cooling Fan High
Relay K614 Cooling Fan Control
Micro Relays Usage
Relay K61 Starter
Relay K69 Wiper Control
Relay K613 Cooling Fan Low
Relay K617 Air Conditioning Compressor Clutch
Relay K619 Wiper Speed
Relay K627 High Intensity Discharge Headlamps
Relay K632 Brake Vacuum Pump
"Compliments of Alldata"
$DO || ! $DO ; try
Old 05-09-2012, 08:17 PM   #5
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Check your battery voltage. Sounds like you might have tapped into a constant 12v power supply which drained/killed your battery. The alternator can not charge a dead battery.
When you reseated the tap and or fuse, you pushed the back connectors in the fusebox farther away, making your fuse connections loose, thus having to reseat the fuses(restart again and again). Check this.
Old 05-09-2012, 08:20 PM   #6
SSYNRS
SSYNRS's Avatar
Thought about that too, but when it is starting I can turn off, start, turn off start several times.
I suppose I can do that until it does not start (mindful of not getting a low battery). I will try again in 1.5 hours.
Nothing goes out (power still to Radio, Lights, etc)...
Just the engine dies and will not start/crank, nothing (no clicks,etc) until I pull/reseat a fuse
I'm baffled ?!?
$DO || ! $DO ; try
Old 05-09-2012, 08:32 PM   #7
2010SLVRBULIT
see my previous post. I bet that is the problem.
Old 05-09-2012, 08:58 PM   #8
SSYNRS
SSYNRS's Avatar
I will check that Battery Voltage, Thank you for the suggestion.
I agree that an Alternator may not be able to charge a dead battery buy
Also note - a dead battery can not start the car...
You Said;
"When you reseated the tap and or fuse, you pushed the back connectors in the fusebox farther away, making your fuse connections loose, thus having to reseat the fuses(restart again and again)."
I will pull the fuse's see if the connectors (where the fuse plugs in) are still at the top for OEM.
Doubt that is the problem cause I can pull/reseat 16,17 or Relay 50 - any one will get it to restart/run.
As far as my "Tap";
Before my troubleshooting, I removed it from "Spare" location #52.
The only fuses I have been resetting are OEM locations
and Fuse #18, but t-shooting proved it did not help...
Back in a few...
$DO || ! $DO ; try
Old 05-09-2012, 09:56 PM   #9
SSYNRS
SSYNRS's Avatar
New Update:
Pulled fuses 16 & 17 and looked at fuse locations along with location #52, all good.
Pulled the trunk apart, Checked Battery Voltage = 12.55
Just cause I was back there, I disabled the ZL1 Spoiler 3rd brake light as well.
Started fine 3 times in a row, let idle on the 3rd.
Checked Battery Voltage Running = between 13.95 and 14.23
Ran for 15 minutes, needed to get back to work so shut off.
For Fun, thought I would start it again, started fine.
Turned off, Started again, started fine
3rd time off / on but let idle....
2 minutes later it died...
Checked battery Voltage 12.51
Did not even finish starting and it died...
5 minutes later it died...
This is where I am leaving it for 2.0 hours for when I am off work.
I will try to start, if no go then a #17 Fuse pull should (hopefully) get me home - about a 22 minute drive.
Still looking for suggestions assistance but will post when I get home and what dealer says in the morning.
I don't have time for this in my life right now, frustrating !!!
$DO || ! $DO ; try
Old 05-09-2012, 10:00 PM   #10
SSYNRS
SSYNRS's Avatar
User LittleMT posted this earlier in a different thread,
"I had these same symptoms in my 2006 Monte SS...turned out that some memory in the PCM had failed, and I need a new PCM...."
Thanks LittleMT !
Old 05-09-2012, 10:32 PM   #11
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
From the looks of it your car is new, why not have it towed to your dealership and have them resolve it while they give you a loaner or courtesy vehicle to take to work.
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 05-09-2012, 10:59 PM   #12
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
could very well be the pcm,,my maxima did this (yea i know its not a chevy but its my dd) it worked then it shut off.. it got to a point where i can only start it while hitting the gass.
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 05-09-2012, 11:18 PM   #13
calbert1999
Camaro SS Lover
calbert1999's Avatar
Drives: 2010 Camaro 2SS/RS Black IOM
Mine did this for the first time today, during rainy weather conditions. I shut it off waited a few moments, restarted and everything was just fine.
calbert1999 is offline   Reply With Quote
Old 05-09-2012, 11:54 PM   #14
SSYNRS
SSYNRS's Avatar
Loaner... Hmmm I will ask if they can't resolve it tomorrow !!
As far as why not tow ? I was already pushing being late to work and am still at work. Will "limp" it home and to the dealer in the morning.
Yea, if I couldn't have gotten it started I would have towed.
Almost off work, It has had a 2 hour sit and the last time it died on me I did not reseat the fuse. Lets go see if it will start of if I need to Reseat Fuse # 17 to get it started !!!
$DO || ! $DO ; try
