Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 05-09-2012, 05:51 PM   #1
E.T.
E.T.'s Avatar
Drives: 2012 Camaro 2SS/RS
breaker bar
Just wondering, is a 12" breaker bar going to be enough to help me loosen the bolts that attach the cats to the exhaust manifold? I have about 18" worth of extensions to get down to the bolt in the engine bay, but those suckers seem to be on super tight. Just trying to figure out if I should get a 12" breaker or an 18"?
E.T. is offline   Reply With Quote
Old 05-09-2012, 05:56 PM   #2
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
I was able to loosen them using a 6" bar, just let it soak on WD-40 for a few hours.
christianmotox is offline   Reply With Quote
Old 05-09-2012, 06:02 PM   #3
E.T.
E.T.'s Avatar
Thanks
Also, do you remember what extensions you used? I have the wobble kind. They seem to reach far enough, and angle enough to give me clearance. I also have a swivel which angles a lot more than the wobble. Wasn't sure which would work better...
Old 05-09-2012, 06:16 PM   #4
christianmotox
Drives: ( . )( . )
I think i used the regular kind, but the wobble ones should work fine.
Also i recommend that you do this when the metal is warm.
Old 05-09-2012, 08:42 PM   #5
E.T.
E.T.'s Avatar
Cool, thanks. Hopefully all goes well this weekend!
