BeckyD @ James Martin Chevy
Old 05-09-2012, 09:29 PM   #1
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Drives: 2012 CRT NF Cammed 2SS/RS
Cool DIY Pinstripe the outer edge of your Wheels
Theres not much to this DIY, but I didnt even know it could be done with vinyl till I looked it up.
- The pinstriping comes in pre-curved vinyl strips, and it takes 4-5 strips per wheel (depending on who you buy from).
- As with applying vinyl to anything, clean first with soap and water, then clean with alcohol. Be sure that its clean! Wheels are very dirty, and vinyl will not to stick to a surface with tire shine left on it.
- When applying the vinyl you can put each piece edge to edge, or overlap them.
- Be sure to let a little of the strip go over the outer edge, so you can fold it over and make sure none of silver shows thru on the outer edge.
- The strips are curved, but you still have to guide it on there using one hand to guide it and the other hand to lay it down.
- I also did all four top halves of my rims at once, then rolled the car forward and did the other halves. You dont want to have the vinyl hitting the ground when you are doing the bottom, you want a clear view, so roll the wheel so what you're doing is always on top!
- They come in multiple sizes, but the common thickness for our rims seems to be 5mm-7mm. Mine are 6.5mm I think.
Bought my stripes from here: http://vehicleartz.com/ , just select 20in rims and pick your color and size (6.5mm is perfect IMO). The set comes with a few extra strips in case you mess up.
--They are shipped in a tube, so its best to lay them flat with a book on them or something to get them flat again so they are easy to work with.
But you can also purchase from this ebay seller, others have used him and seems to have some different options: http://stores.ebay.com/StripesGraphicsNdecals . I did not use him because I wanted a dark red, and he doesnt offer it.
Good luck
Old 05-09-2012, 10:13 PM   #2
BiloxiRon
BiloxiRon's Avatar
Drives: 2012 Camaro 1LT RS
Send a message via AIM to BiloxiRon Send a message via Yahoo to BiloxiRon
Thanks! Just ordered mine from your link. They accept PayPal also, which was very nice!
BiloxiRon is offline   Reply With Quote
Old 05-10-2012, 09:43 AM   #3
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Glad I could help! Post pics when you do it
Old 05-13-2012, 11:06 AM   #4
IBM
IBM's Avatar
Drives: '11 2LT/RS IBM
i would do it but my rims have scratches and chunks out of them on the outer edge, thanks to my sister. :(
IBM is offline   Reply With Quote
Old 05-13-2012, 11:34 AM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
That sucks, one of my rims had what could only be a rock chip on the outside (cause Ive only had the car a week and know I havent run into anything) and the pinstripe went over it fine.
If you have painted rims, you can actually touch up and repair just like normal paint.
Old 05-13-2012, 06:10 PM   #6
josh_lang
Drives: 2010 Chevy Camaro SS
Thanks! I'm definitely going to do this to my wheels this summer!
josh_lang is offline   Reply With Quote
Old 05-13-2012, 07:16 PM   #7
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Cool! Cheap and easy, post pics when u do it
Old 05-13-2012, 09:58 PM   #8
amz
Factory Correct
amz's Avatar
Drives: 2011 2SS/RS
How well are they holding up ?
amz is offline   Reply With Quote
Old 05-13-2012, 10:14 PM   #9
cruznls
cruznls
cruznls's Avatar
Drives: 2010 CAMARO
Cool
Be careful at the car wash...
cruznls is offline   Reply With Quote
Old 05-13-2012, 10:37 PM   #10
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
I washed the car this weekend, and inspected them, all are still there and intact, at the edges and the seams.
They are the same as putting vinyl on your brake calipers or over a bowtie. Only thing that really kills vinyl is sunlight, and on your rims they wont be seeing as much as the rest of the car.
Im sure they will stay in good shape for a while. But they were also 8$ and took about 20-30 mins total to install.
Other members have used the same method and they held up for a long time
Just make sure its really really clean, and then clean again with alcohol
No self respecting Camaro owner uses an automatic car wash, or anyone who cares about their car for that matter!
Old 05-23-2012, 12:31 AM   #11
simon.w
Drives: 2011 2SS RS 6M Inferno Orange
You'll need to replace them when you change tires ... I had them on my car in Australia ... Looked great until they were destroyed by new tire fitting. I even had it done on a run flat fitting machine ... But still tore them in places.
simon.w is offline   Reply With Quote
Old 05-23-2012, 09:31 AM   #12
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Thanks for the tip, ill have to order a set when I go to change my tires, hopefully thats far down the road, I only have 2k miles on them now, lol.
And your car is amazing!
Old 03-28-2013, 11:06 AM   #13
Blu Ray
NO BOOST
Blu Ray's Avatar
Drives: 2015 Black 1SS/RS/1LE*NPP*RECAROS
Send a message via AIM to Blu Ray Send a message via Yahoo to Blu Ray
Good info bro.....sweet ride also
FOUNDER - NY/NJ/PA Domestic Car Club Est.2013
Custom Grind Comp Cam 110 Lobe * Brian Tooley Push Rods, Springs * Kooks 1 7/8 LT Headers * Comp Cam Trunion Bearings * NGK TR55 Spark Plugs * Rotofab CAI * Dyno Tune * CNC Ported Heads * LS7 Lifters & Tray * GM Performance Dual Mode Exhaust * GForce 1000 HP Axels* BMR 1" Lowering Springs, Trailing Arms, Toe Rods, Upper Control Arms* Full Rear Bushing Kit * 504/462
Blu Ray is offline   Reply With Quote
Old 03-28-2013, 11:28 AM   #14
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Thanks man!
pinstripe, red, stripe, vinyl, wheel
