Jason 98 TA
Old 05-09-2012, 09:39 PM   #1
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Wiring Help
I have searched around and didn't have any luck on finding the answer I am looking for.
Can you guys tell me a source for 12v constant, 12v ignition switched, and 12v headlight switched near the fuse panel in the driver's side dash?
I am looking to install some aftermarket gauges and just want to know where I can tie these in.
Thanks in advance!
lsuguy is offline   Reply With Quote
Old 05-09-2012, 09:49 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
only 12V constant inside the cabin is the wire going to the Homelink buttons.
Click to view my build thread
Old 05-09-2012, 10:42 PM   #3
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
Most of the blank slots on the fuse panel itself are always hot. Just use an add a fuse and plug into one of the blanks.
jeepguy_1980 is offline   Reply With Quote
Old 05-09-2012, 11:22 PM   #4
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Can you guys tell me a source for 12v constant, The power drivers seat fuss for one. 12v ignition switched,The only one i know is fuss #15 in the under hood fuss box and 12v headlight switched near the fuse panel in the driver's side dash? pull the headlight switch out and t-tap the yellow wire its for the LED lighting.
Thanks in advance!
Old 05-10-2012, 07:34 AM   #5
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Thanks guys. Exactly what I needed.
Old 05-10-2012, 02:26 PM   #6
Third-Gen
Olson Kustom Works
Drives: 91 Camaro, LS3, TVS2300, TR6060
there is an ACC at the cig lighter too. turns off with the key, doesnt retain RAP
Third-Gen is offline   Reply With Quote
Old 03-30-2015, 11:35 AM   #7
Hopstar
Drives: 2010 camaro Ss
Help
Originally Posted by 2SSRS@Gen5diy View Post
I read the post and it didn't work for me I have a 2010 camaro ss/rs I also installed aftermarket gauges and I need 12v headlight switched power to make my gauges go from blue day lights to red night time lights. I read where you said the yellow wire on the light switch is 12v headlight switched power .. on my car that's not the case I used a test light on all wires on the plug with switch in all positions and I get a light on all but black and blue wires at all times no matter of position... please help me locate 12v headlight switched power this is driving me nuts!
Hop
Hopstar is offline   Reply With Quote
Old 04-06-2015, 06:00 AM   #8
Hopstar
I installed 4 gauges and tapped power and ground off the cig lighter. Everything seems to work fine but my RAP relay gets hot and smells like heating plastic... is this normal when you tap off of this circuit? The gauges don't pull that much power and no fuses are blowing.... any ideas what the deal is?
