Old 05-10-2012, 01:55 AM   #1
azvren
Drives: Camaro 2SS RS IBM
Driver speaker out?
If there is no sound coming from the driver door speaker, does that mean its blown out? I figured if it was blown there would at least be some distorted sound coming through. Any suggestions?
Thanks in advance everyone!
azvren is offline   Reply With Quote
Old 05-10-2012, 10:48 AM   #2
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
It depends on what was going on when it blew. I have seen voice coils melt so bad that the speaker would not move at all. only way to really determine if it is blown is to remove the speaker and see if you can make it move with your fingers. If it moves freely (no scratchy feeling and makes no noise) then you may have a blown channel in your amp, or a disconnected wire.
At least that is how I would go about it.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Pioneer DEX-P99RS * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 05-10-2012, 01:17 PM   #3
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
DarkRider is correct, it could also be the amp or the wiring. Not always, but you will often hear distortion from the speaker if it's a problem with the speaker. You will need to remove it to find out for sure.
CrutchfieldBrooke is offline   Reply With Quote
Old 05-10-2012, 02:15 PM   #4
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Are you running the stock sound system or have any changes been made to the audio equipment?
Old 05-10-2012, 04:46 PM   #5
azvren
It's a stock BA system with no changes at all. It was fine before I took it to the body shop -_-.
Old 05-10-2012, 04:46 PM   #6
azvren
Guess I'm gonna pull the door apart then...
Old 05-10-2012, 05:00 PM   #7
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
