Old 05-11-2012, 10:09 AM   #1
Indy Bumble Bee
Indy Bumble Bee's Avatar
Drives: Beest
Tar Removal from Paint?
I work and live in two construction zones unfortunately, and consistantly get tar on my car. Some of is is very stubborn to remove, does anyone have a good way to remove it?
Indy Bumble Bee is offline   Reply With Quote
Old 05-11-2012, 10:12 AM   #2
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
goof off works for me, just don't hit any plastic or moulding......
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 05-11-2012, 11:12 AM   #3
grocerygetter
instigator
grocerygetter's Avatar
Honestly...good old turtle wax bug and tar remover. If that doesn't get it, wd40.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 05-11-2012, 11:40 AM   #4
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
CarPro TRIX Tar and Iron Remover works great in removing tar on your finish and at the same time helps in removing iron or metal shavings that are on you paint.
Old 05-11-2012, 11:59 AM   #5
belliott
belliott
Drives: 2011 Camaro SS Convertible
I use the turtlewax bug & tar too! Its the only turtlewax product I use. The trick is to spray it and let it sit for a couple of min. Its got to do the work. I lay on the ground and spray the entire bottom sides 3-5 inches of my car once every 2 weeks just to keep it clean. Just also make sure to add some protectant after your done a wax over top to help in the future with problems. Good luck!
belliott is offline   Reply With Quote
Old 05-11-2012, 12:01 PM   #6
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
I am going double Angelo's suggestion of CarPro TRIX. Here is a quick review of it
Not only does CarPro TRIX have powerful tar & bug removing agents but it also will deep clean the paint by removing iron oxide build up that has etched into the paint. Given that you are buy a construction zone this could have a great benefit for your paint system.
Here is another reivew, this time using their IRON X: Deep Clean your Paint with CarPro. IRON X is similar to TRIX but with out the bug & tar agents. It will still give you a good idea on the cleaning ability.
Old 05-11-2012, 12:06 PM   #7
grocerygetter
instigator
Yup only turtle wax product I recommend as well.
-John S.
Thanks to:
Tony@ dv8motoring
Old 05-11-2012, 12:22 PM   #8
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Car pro tar x is great stuff
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Ryanbabz71 is online now   Reply With Quote
