Old 05-11-2012, 12:39 PM   #1
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '18 E'nox Pre 2.0T
How to Adjust DIC Speed Warning?
How do you adjust the Speed Warning in the Driver Information Center? The instructions on the DIC say "Press SET to Clear or Reset". However, all I have been able to do is toggle from On to Off. The ON setting is preset at 55 mph, therefore I always have it turned Off. If I could reset to a higher speed, then the warning function would have some practicality. Anyone have any experience resetting? Thanks in advance.
RJT Impala is offline   Reply With Quote
Old 05-11-2012, 12:50 PM   #2
RADAR
RADAR's Avatar
Drives: 2012 2SSRS/M6 SIM
I messed with mine yesterday. Once you turn it on twist the switch to change the speed up or down.
RADAR is offline   Reply With Quote
Old 05-11-2012, 02:52 PM   #3
RJT Impala
RJT Impala's Avatar
I'll give it a try. The last time I attempted that, it just cycled thru to the next function on the DIC. I'll play with it more after work. thanks.
Old 05-11-2012, 10:21 PM   #4
RJT Impala
RJT Impala's Avatar
Played with it some more and figured out the process. Works well! Thanks for the help.
