Gen5DIY
Old 05-11-2009, 02:44 PM   #1
SSCamaro2010
SSCamaro2010's Avatar
Drives: 2010 Camaro 1ss/rs
TUNE and Skip shift eliminator
Does a tune void the motor warrenty?? and with this skip shift eliminator that SLP is selling, does that mean that when driving the car i have to shift from 1st to 2nd and so on... i cant skip gears. how is that possible is it computer controlled?? any help is great
SSCamaro2010 is offline   Reply With Quote
Old 05-11-2009, 02:57 PM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Normally with the manual for better MPG, you will be forced to go from 1st to 4th (at low speeds). WIth the eliminator, you can drive as normal (it doesn't force you to do anything) ..
For the Tune .. yes, it could void that warrenty if it is shown to be the cause of failure ..
Crowley
Crowley is offline   Reply With Quote
Old 05-11-2009, 03:11 PM   #3
SSCamaro2010
so your telling me if i dont get the shift eliminator, if im driving at low speeds with a manual, i cant shift from 1st to 2nd, i have to shift to fourth??
Old 05-11-2009, 03:43 PM   #4
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Here is a good Read:
http://www.bfranker.badz28.com/96ss/skipshift.htm
Not sure if all of this is still the same, but the spirit of it sure is
Crowley
Old 05-11-2009, 03:48 PM   #5
SSCamaro2010
okay so if i get this, this is to help me with gas mileage, so the stock car will let me shift to 1st two second to third whenever i want, correect, doesnt matter what speed or RPMs??
Old 05-11-2009, 04:19 PM   #6
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
The skip shift eliminator will allow to shift however you want. The reason GM Put it in to begin with is to help with gas mileage (so we didn't have to pay some sort of gas guzzler tax).
Crowley
Old 05-11-2009, 04:33 PM   #7
SSCamaro2010
okay let me get this straight, i ordered an 1ss Camaro manual, so from the factory this already has the skip shift eliminator, or what? or is this an option to buy aftermarket, from the factory this will force me to shift to fourth gear if im in first gear, this skip shift eliminator will allow me to shift to whatever gear i want, is htat correct, and at anytime??
Old 05-11-2009, 04:48 PM   #8
DZbob
Drives: 2010 RJT Camaro M6
Send a message via ICQ to DZbob
The manual transmission that comes with the Camaro will force you to shift from 1st to 4th at low rpms. The skip shift eliminator will allow you to shift whenever you want to. (skip shift eliminator is an aftermarket product, it does not come with the car)
DZbob is offline   Reply With Quote
Old 05-11-2009, 07:38 PM   #9
SSCamaro2010
does anyone plan on doing this to their car??
Old 05-11-2009, 08:02 PM   #10
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
There is no doubt I'm buy this skip shift eliminator. Now who sells it? How does it work? Is it an easy install?
Carlos Garza is offline   Reply With Quote
Old 05-11-2009, 08:06 PM   #11
SSCamaro2010
http://slpcamaro.com/
Old 05-12-2009, 09:40 AM   #12
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
never heard of slp? they a pretty reliable company that build high performance stuff?
logan1080 is offline   Reply With Quote
Old 05-12-2009, 10:12 AM   #13
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
I did it with my 2001 SS .. then when I had some work done that included a tune, it was done in the tune ..
Crowley
Old 05-12-2009, 10:15 AM   #14
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
SLP makes good stuff. They were actually the folks that helped with the 4th gen production SS I believe. Someone may have more history.
Here is a little history:
1996 saw minor mechanical revisions, as well as small power gains from the new OBD II-compliant engine controls. All base model Camaros were now equipped with the 3800 series II. V8 models still came with the 5.7L LT1 engine. The dual catalytic converters required by OBD-II resulted in lower restriction and a mild power boost to 285 hp (213 kW) and 325 lb·ft (441 N·m) of torque. Two option packages also returned: the RS (last seen in 1992), an appearance option for the V6 model, and the SS (last seen in 1972), a performance and appearance package for V8-powered cars. The SS cars, which were modified by Street Legal Performance (SLP) through contract with GM, were the highest factory performance Camaros offered at the time and included a functioning hood scoop and new five-spoke 17 in (43 cm) x 9 in (23 cm) wheels. The new wheel and tire package on the SS resulted in better handling and braking compared to the Z28. Also available this year for the V6 model was the Y87 package, which included a Zexel-Torsen LSD, better tires, dual exhaust tips, 4 wheel disk brakes, and a sportier steering ratio.
Crowley
