sjm autoprod
Old 05-13-2012, 06:29 PM   #1
Angeliiis
Angeliiis's Avatar
Drives: 2010 LT2 RS Camaro
Doors Unlock Themselves
I have this issue intermittently with my 2010 LT2 Camaro. When I leave the windows cracked open, the doors will not allow me to lock them. I push the lock on the phab and the locks go down and then immediately pop back up. This even happens if I manually place the key in the door and turn it to lock it. Also, the alarm will not set during this scenario. There are times when this does not occur as well. I have sat in the driveway trying to recreate the issue so I could possible change the personal preferences; however, the doors and alarm did lock and set. Can someone shed some light on this? Thanks
Angeliiis is offline   Reply With Quote
Old 05-13-2012, 10:47 PM   #2
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Check your settings on the radio's Config section. What you described, sounds like the 'Unlocked Door Anti Lock Out' setting is on.
rolnslo is offline   Reply With Quote
Old 05-14-2012, 11:09 AM   #3
Chevrolet Customer Svc
Drives: GM Vehicles
I agree with the last post. You may want to check out page 4-40 in your owner's manual under the heading called Unlocked Door Anti Lock Out. It states: When on, this feature will keep the driver’s door from locking when
the door is open. If off is selected, the Delayed Door Lock menu will be available. Press the MENU / SELECT knob when Auto Door Unlock is
highlighted. Turn the knob to select On or Off. Press the knob to confirm
and go back to the last menu.
Let me know if this works.
Good luck!
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 05-15-2012, 08:03 PM   #4
Angeliiis
Angeliiis's Avatar
Thanks
I did read through that section, but was not sure if that was the problem as it does not do this all the time. I will change the setting and see what happens.
