Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 05-13-2012, 10:25 PM   #1
thebatdude
thebatdude's Avatar
Drives: 70 Chevelle big block
Wheel stud size
Does anyone know what size the wheel studs are?
How much can the ZL1 be modified (horsepower and drag slicks) without breaking the wheel studs?
thebatdude is offline   Reply With Quote
Old 05-13-2012, 10:28 PM   #2
htron50
htron50's Avatar
Drives: 2017 ZL1 (Firm Order) Status 1100
Don't know..... but I do know they did 1,000 straight launches from dead stop at a drag strip to test strength/durability and nothing broke! Work for ya?
htron50 is offline   Reply With Quote
Old 05-13-2012, 10:38 PM   #3
oldfriend
Drives: Fiat 500 E
In this location [studs ] more important than size is of what they are made .
Old 05-14-2012, 10:32 AM   #4
Fish-man
SS HWSE
Fish-man's Avatar
Drives: too many to say!
M14 x 1.5
120mm bolt cirlce
for reference, 4th gen was M12 x 1.5 with 120.65mm bolt circle
Fish-man is offline   Reply With Quote
Old 05-14-2012, 09:01 PM   #5
stymie
stymie's Avatar
Drives: 2012 Chevrolet Camaro ZL1
Anyone know the ft/lbs of torque used on the lug nuts on 5 spoke polished wheels?
stymie is offline   Reply With Quote
Old 05-15-2012, 09:57 AM   #6
Fish-man
SS HWSE
Fish-man's Avatar
Check out discussion here, starting at post 58.
http://www.camaro5.com/forums/showthread.php?t=33139
Old 05-16-2012, 06:48 PM   #7
stymie
stymie's Avatar
Mine came with 100ft/lbs of torque applied. I had my dealership's service department split the difference & go for 125ft/lbs as I have heard of shear issues at 140+. 125 should be plenty.
125ft/lbs (technician accident... should have been 85ft/lbs) would literally shear the threaded studs on my '98 Mitsubishi 3000GT VR-4 & Dodge Stealth R/T Twin Turbo. Japanese metal is SOFT! Due to metal differences, the steel hubs & aluminum wheels would literally fuse together & required a bond breaker. If I ever have a stud problem, I swap out all 5. To change out a wheel/tire, they would literally have to be kicked off; not exactly ideal if you get a flat.
Old 05-16-2012, 08:41 PM   #8
Fish-man
SS HWSE
Fish-man's Avatar
100 vs 110 ?... when u check it, always look for torque required to start movment in the tightening direction...not breakaway loosening torque. Also, it might not be surprising to see some differnce between checks.
Old 05-16-2012, 08:57 PM   #9
stymie
stymie's Avatar
My understanding is that the owner's manual calls for 140ft/lbs which on ZL1 studs seems to be a bit much! I don't think they will come off at 125ft/lbs. After a reset, I usually drive a few miles to check for a change. I need to pick up a Snap-On.
Old 05-17-2012, 11:52 AM   #10
Fish-man
SS HWSE
Fish-man's Avatar
Read the owners manual to be sure:
GM began to change lugnuts for Camaro in 2012 per owner manual:
GM lugnuts with silver color ON THE CONE: 190Nm- 140ftlb
GM lugnuts with BLUE color on the cone: 150Nm- 110ftlb
And by cone, i mean cone of the lugnut. My bet is that your ZL1 has blue on the cone of the lugnuts... therefore 110ftlb
Old 05-17-2012, 11:24 PM   #11
stymie
stymie's Avatar
