| Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum All audio, video, bluetooth, nav, radar, and electronics discussions. |
Thread Tools |
iphone 4s phonebook access - bluetooth?
Im looking for some help from one of our member experts; Have you been able to use bluetooth voice commands to access your phonebook? (or push your data to the car). What about using siri? I put my phone in the center console, so holding the home button isnt a great option.
Thanks for any help, tips, tricks |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
Thank you for reaching out! I do have a website that could be very useful to you on how to access your phonebook through Bluetooth. The website is http://www.onstar.com/web/bluetooth/ . From there, you must select your brand of vehicle and then from there you should be able to choose the phone you have and how to access your contacts from your phonebook to make a call. If you need further assistance, private message me, and I will promptly walk you through the details.
Hope this helps! Brandon Chevrolet Customer Service |
Two Miles An Hour
Drives: SIM 2LT RS Join Date: May 2010
The 4S isn't listed on that site linked above. But I do know for the iPhone 4 the 2010 camaro does not support phone book download, so u wont ever see contact names on the radio display unless you manually program them in one by one.
You should be able to access Siri though. I don't have a 4s, just the 4 but should be the same. Push the talk button> say Bluetooth > say voice. Then you should be able to use voice control. I never use it though cuz its too much of a hassle, too many steps and pauses in between. You have to speak like 3 commands before the actual commad that does what your trying to do. I can manually do it faster. I wish there were a setting that would make my phone the default for voice instead of onstar, that way u would only need to push the button once and skip the extra commands.
expect nothing, but take everything |
Master of All Things
Drives: '10' Camaro 2LT/RS,'08' Caddy STS Join Date: Jul 2009
well I don't have a iPhone....but you can always take the time and put the numbers in your CARS phone book.....then when you want to make a call, hit the call button on the wheel, your phone accesses your phone and you get your dail tone, then using your CARS phone book, say the name or however you put in the vioce command in and access them that way. I did that very thing. It just takes a little time. not a big deal.
![]() Drives: 2012 2SS 45th Ann. Edition Join Date: Jun 2012
It looks like the iPhone 4 does not currently support phonebook downloading:
https://www.onstar.com/web/bluetooth...apple-iphone-4 What I can't figure out is if this is a limitation on the phone or the bluetooth system. The new version of iOS 6 is supposed to support bluetooth MAP profiles, allowing text messages and emails to be passed on to the vehicle. I'm not sure if Chevy's bluetooth system is capable of handling that, but I know my girlfriend's Ford Escape is. I'll see if I can download the beta and test it out (I'm an iPhone developer, so I'll do as thorough of a testing as I can). |
#6 |
![]() Drives: 2011 IBM 2SSRS LS3 Join Date: Jun 2011
I can see my phone book on the radio display and I have the 4s. I did receive a letter from GM / Onstar about doing an update for some 2011 cars to make it more compatible with the bluetooth You can get a 30 day free onstar update to get th new software download.
Here is my other post. http://www.camaro5.com/forums/showthread.php?t=234733 |
#7 |
I can see my phone book too, what does't work is saying "Call John Smith" unless I've previously punched that contact into the OnStar system. Other phones will automatically sync their information over.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
I've tried 4 different phones and voice commands will not work on any of them unless I've already programmed the number I'm calling into the car itself.
#9 |
Update from my previous post:
http://support.apple.com/kb/HT3647 It seems that the iPhone DOES support PBAP, and it's probably just a limitation on the PDIM. GM is probably just blaming it on the phone, when in reality it's their system that is lacking.
2012 2SS 45th Anniversary Edition
#10 | |
SoCal HT5
Drives: 2010 Camaro Join Date: Jun 2009
Mods: Brembo Brakes/ Pedders Street 1/ Cold Air Inductions CAI/ Vmax CNC TB/ ZL1 Fascia
#11 |
Weird, it doesn't work for me and I have a 2012. I checked my Bluetooth device settings and the option to sync the phone book is marked as "yes". I tried toggling it on and off just to see if that would make a difference and it doesn't. It definitely seems to be a limitation on the system installed and not of the phone itself.
My current workaround is to hit the hands-free button and then say "Voice". That dumps you right into the voice control mode of the phone itself, and then you can say "call Mr. X" and it will work just fine. Annoying, but at least it works.
#12 |
Murdered, did you try turning your phone off then back on?
Sometimes when I get in the car my phone book won't sync. When I turn the phone off and turn it back on it will sync right up. |
#13 |
Yea, several times. If I manually go into the phone book I can get a listing of everyone, but I still can't just say a name and have it call. Isn't that supposed to work too?
#14 | |||
The only way to be able to voice activate a call is if that number is programmed into the cars phone book using the procedure listed in Chapter 7. Here's the procedure listed in the manual for this. Quote:
#15 |
Ahh, well that explains it then. Thanks!
| Thread Tools | |
