SDTW Custom Wheels & Tires
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 05-14-2012, 10:11 AM   #1
jazznurse
jazznurse's Avatar
Drives: 2012 ZL1;2011 Cruze
After market wheels
Has any one found a source yet for aftermarket wheels for the ZL1? Tire rack and a few others I checked don't have anything yet. I did find a source for the recommended winter tires, so I'm looking for rims to mount them. Never too soon to be thinking about winter. We get plenty of days in the 40's during September.
jazznurse is offline   Reply With Quote
Old 05-14-2012, 11:21 AM   #2
TheMichael
Drives: 2012 ZL1 #349, 1969 Camaro SS
What did you find for winters if you don't mind me asking?
TheMichael is offline   Reply With Quote
Old 05-14-2012, 11:38 AM   #3
jazznurse
jazznurse's Avatar
I found someone who is able to get the GM recommendedPirelli Winter Sottozero 305/35R 104V rear and Pirelli Winter 240 Sottozero Series II XL 285/35R 104V for the front.
Old 05-15-2012, 02:53 PM   #4
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Shouldn't pretty much any wheel that fits an SS also fit a ZL1?
*edit*
as long as they're 19" or more, to clear the brakes
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-15-2012, 03:10 PM   #5
ZL1 TIBS
ZL1 TIBS's Avatar
Drives: 1968 Camaro, 2012 ZL1
I was thinking the same thing. Get somebody's cast offs.
Alan Tibbetts
Aston, PA
1968 Chevrolet Camaro LS-1/T56 transplant
2012 CRT 6 SP ZL-1
ZL1 TIBS is offline   Reply With Quote
Old 05-15-2012, 05:43 PM   #6
jazznurse
jazznurse's Avatar
I don't think so. 20 X 10 in the front, 20 x 11 rear. If you don't put on what the computer was set up for, you have to get it reprogramed. Then when you put the summer tires back on, you'll need to repeat the process. And even though they are winter tires, I'll want to take advantage of the PTM, most notable mode 1, wet conditions. If I'm paying for it, I may as well use it.
Old 05-15-2012, 06:50 PM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
If you are that concerned about upsetting the computers, why are you even considering anything other than a set of stock replacement wheels? I mean, the whole point of going with aftermarket wheels is to get you something different from what comes from the factory. You want something to perfectly match the physical properties of the factory wheels so that you can have a set for your winter tires (by the way, tires would probably throw off the computers as much as, or more than, the wheels themselves). The only way to match the factory wheels in every regard (width may or may not factor into things, but others like weight & their inertial properties do) is to get another set of factory wheels.
Old 05-15-2012, 08:37 PM   #8
Rice Killer
Cooter
Rice Killer's Avatar
Drives: my wife crazy
Yeah, I would think as long as you got the height of the tires as close as you could you should be alright. Mostly so it doesn't throw off your speedometer. No matter what tire you get, other than factory, it will hinder the PTM to an extent. Rim size and tire width should not matter, as long as it ain't rubbing anything.
Pretty sure no one has or will take the time to reprogram the PTM for different tire packages. Reprogramming should not be required in any case unless you want to recalibrate your speedo. My 2 pennies.
#1451 - 2012 ZL1 - White, Black Wheels, Manual, Suede Package, and Exposed Hood Insert. Delivered on 6/20/12. Thanks to Jason from Symdon Motors in Evansville, WI.
Rice Killer is offline   Reply With Quote
Old 05-15-2012, 08:42 PM   #9
thespymaster
thespymaster's Avatar
Forgeline has wheels with the correct offsets!
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
