BORLA
Old 05-14-2012, 12:09 PM   #1
butters
It's not the batmobile!
butters's Avatar
Drives: 2012 Camaro LFX
Best way to clean Black wheels?
I have the Adams all-purpose cleaner. I just spray on and wash off and there still a lot of grime left. Should I be scrubbing with a brush before washing it off? Is there a better spray to use?
butters is offline   Reply With Quote
Old 05-14-2012, 12:13 PM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
All purpose cleaner isn't meant for wheels. Adam's makes a wheel cleaner.
http://www.adamspolishes.com/p-684-a...l-cleaner.aspx
You may also need to grab their wheel brush...saves allot of time
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 05-14-2012, 12:15 PM   #3
butters
butters's Avatar
makes sense, thanks!
Old 05-14-2012, 12:21 PM   #4
lexlueger
lexlueger's Avatar
No problem..don't forget we get a discount on Adams products with the "camaro5" coupon code.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 05-14-2012, 12:50 PM   #5
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
You won't find a spray on/hose off cleaner thats going to be safe for your wheels. In order to break things down chemically it would also be hard on the clear coat, so any cleaner you choose is going to take some kind of agitation to get 100% clean.
For light cleanings I take a couple oz's of our Car Wash and dilute it in a 36oz bottle w/ a foaming sprayer. This makes a nice, pH neutral, cleaning solution that won't remove wax or sealant from the wheels (which you should be applying) and if the contamination is fairly light only requires a little scrubbing with a boars hair wheel brush or spare wash mitt.
For heavier cleaning I go with our Green Wheel Cleaner as it is more effective at breaking up road grime/brake dust. It does, however, degrade the sealant/wax to some degree so its important after cleaning with it to reapply your preferred wax or sealant for protection.
I'd avoid using APC for wheels unless its diluted 1:1 and honestly its not great for that type of cleaning... its better suited to cleaning the tires and fender linings.
Old 05-14-2012, 02:11 PM   #6
Chevrolet Customer Svc
Drives: GM Vehicles
As per my GM resources, on page 10-92 it describes how to wash your wheels. It states: Use a soft, clean cloth with mild soap and water to clean the wheels. After rinsing thoroughly with clean water, dry with a soft, clean towel. A wax may then be applied. Keep the wheels clean using a soft, clean cloth with mild soap and water. Rinse with clean water. After rinsing thoroughly, dry with a soft, clean towel. A wax may then be applied.
Notice: Chrome wheels and other chrome trim may be damaged if the vehicle is not washed after driving on roads that have been sprayed with magnesium, calcium, or sodium chloride. These chlorides are used on roads for conditions such as ice and dust. Always wash the chrome with soap and water after exposure.
Hope this helps!
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
Old 05-14-2012, 02:25 PM   #7
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Give Sonax Full Effect wheel cleaner a try. Best I've used. You should still agitate with a microfiber cloth or boars hair brush.
Dylan- I think you meant tires in the last sentence.
Sent from my Galaxy Nexus using Tapatalk 2
[B]
Old 05-14-2012, 02:31 PM   #8
Adam's Polishes
Thanks... yes. Catching up on 3 days or responses... my fingers are working better than my brain this morning.
Old 05-14-2012, 02:34 PM   #9
spacecowby
spacecowby's Avatar
Drives: 2010 black 2SS/RS
I have black painted rims and i use Adams green wheel cleaner. After letting it soak for awhile i wipe my rims with a microfiber towel and Adams soap. Then every couple months I use Adams revive and quick sealent.
Black cars are not hobbies, they are an obsession
spacecowby is offline   Reply With Quote
Old 05-14-2012, 07:25 PM   #10
butters
butters's Avatar
It's crazy, I never thought to wax my wheels
Thanks for all the info!
Old 05-14-2012, 07:38 PM   #11
Adam's Polishes
You're not alone... most people don't. I ask that question at most detail clinics I run and when I say "by show of hands how many of you wax your wheels?" I generally get < 25% of the people.
Its easy and it keeps them easier to clean over time!
