Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
JDP Motorsports
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 05-15-2012, 05:07 PM   #1
Drives: 2012 crystal red camaro 2LT
Audio Settings
What settings work best in everyone's Camaros? In terms of bass, treble, etc.
Chris517 is offline   Reply With Quote
Old 05-15-2012, 05:46 PM   #2
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
If its stock i found 12,12, 12 to be decent
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 05-16-2012, 01:16 AM   #3
Matic's Avatar
Drives: 2011 Summit White LS
Before I upgraded my entire setup, I think I had bass at 6 (the max before I got rattles), I think I had mid around -2, and kicked up the treble to I believe 10 or 11. Everybody has different tastes in sound and its hard to get a good sound period with the stock setup. I myself love treble and have had people in past cars tell me to fix my settings or started trying to press buttons and I had to slap their hands away. The dude who installed my headunit had some EQ settings that made me want to kill myself until I got in and messed with them, but im sure they sounded good to him.
Matic is offline   Reply With Quote
Old 05-16-2012, 03:46 PM   #4
Drives: black 1lt 2012
8 for treble, 5 for bass and mid for me. As already stated its all personal preference. I do adjust it per song, depends on the download quality of what I'm listening to.
black12lt is offline   Reply With Quote
Old 05-22-2012, 01:51 PM   #5
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
The total balance of your EQ curve should total somewhere around zero, otherwise it's similar to just turning the volume up. If I dial up some bass and treble, I'll dial out some midrange to emphasize the other changes.
Presently, I'm using a +2 bass, a -2 midrange and a +1 treble. I listen to a lot of talk radio/comedy channel and some rock.
To each their own, but I have to laugh when someone says +12 on everything (sorry), as you're not getting anything different. You're trying to use the EQ to equalize the sounds to your liking, not as a booster.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-22-2012, 04:10 PM   #6
Tysen's Avatar
Drives: 2011 RJT 2SS/RS M6
I use -8 for treble, -6 for mids, and 4 for bass. I also disconnected my center speaker.
"I'm a man who discovered the wheel, and built the Eiffel Tower out of metal and brawn! That's what kind of man I am." - Ron Burgundy
My build thread
Tysen is offline   Reply With Quote
Old 05-22-2012, 04:54 PM   #7
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
0,0,0 - but that's with a Clarion EQ after the head unit. I used to run something like 8,6,12 I think. Anything over 8 on Bass had my rear deck rattling like crazy.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Pioneer DEX-P99RS * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 05-23-2012, 08:11 PM   #8
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
+2 bass, 0 m, 0 t (non-BA system) before my sub install. Now -2, +2, 0.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Extendolator • SOLO Hi-Flo Cats and Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 05-23-2012, 09:10 PM   #9
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
That's no different than 0,0,0.
jeepguy_1980 is offline   Reply With Quote
Old 06-17-2012, 02:28 PM   #10
Drives: Black 2012 2LT
The only thing I've touched, so far, is lowering the midrange by 8, and lowering the fade by 8. So, it's -8 for both. That seems to make the sound "sound" like it's coming out of all of the speakers evenly (to make up for the center speaker, which really shouldn't even be there), and it makes it so that you can't really tell where the sound is coming from - which is how a speaker setup should be. I was always of the belief that changing these settings is mostly to make up for problems with your listening environment - but since the stereo was programmed for this size car, it should already be tuned for the proper listening environment. Only issue with this, is the center speaker. So, I believe that the -8 on those two settings will be the best way to have the optimum listening environment, without actually removing the center speaker.
DeAdMiKe187 is offline   Reply With Quote
audio, radio
