JDP Motorsports
Old 05-15-2012, 06:45 PM   #1
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
My stupid Adams question of the day
What are the differences between the waterless wash and the detail spray since neither add protection to the finish. Just trying to figure out if i really need both.
thanks
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 05-15-2012, 07:02 PM   #2
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
thanks
Waterless wash is jist that..to wash ur car when it is lightly dusted..u would use detail spray after to give it a shine
Sent from my SCH-I510 using Tapatalk 2
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You’ll never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 05-15-2012, 07:06 PM   #3
IneedAZ
IneedAZ's Avatar
Would u bother waterless wash if u use a California duster for light dusting? Seems like it would
cheaper that way then use detail spray as needed. Of course the duster wont do much for love bugs.
Old 05-15-2012, 07:08 PM   #4
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
[QUOTE=IneedAZ;4967597]Would u bother waterless wash if u use a California duster for light dusting? Seems like it would
cheaper that way then use detail spray as needed. Of course the duster wont do much for love bugs.[/QUOTEim not a fan of the cali duster..i use it here n there but u gotta use it a certain way so that it dont scratch ur paint. The waterless wash does a better job then the duster..but u gotta use the waffle weave.towels with it
Old 05-15-2012, 07:15 PM   #5
IneedAZ
IneedAZ's Avatar
ok, thanks for the replies, guess the real question whats different in Adams waterless wash and Mequiars quick mist and wipe. I already have two bottles of that, would like to hear from anyone that has tried both.
thanks
Old 05-15-2012, 07:26 PM   #6
babaron
Totally into it
babaron's Avatar
Drives: '67 427vette/'11 Pacecar/'02 BMW ci
ww has more lubricity but no gloss enhancer. ds has gloss enhancers but not as much lubricity.
____________________________________THERE MUST BE A SUPPORT GROUP FOR THIS ADDICTION. AM I IN THE RIGHT PLACE?
babaron is offline   Reply With Quote
Old 05-15-2012, 07:49 PM   #7
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
babaron covered it.
Basically the base of the 2 chemicals is identical... where they start to differ is with the additives.
Detail Spray leaves a gloss enhancer behind that will give you paint a little added shine.
Waterless doesn't have that gloss enhancer, instead its replaced by a high lubricity emulsifier that makes dust removal safer.
Basically you'd use Waterless for dust removal, Detail Spray for adding gloss. Figuring that you'll do dust removal more often than needing gloss waterless makes more sense as it costs less per oz.
Old 05-15-2012, 08:09 PM   #8
motorhead
motorhead's Avatar
Originally Posted by Dylan@Adams View Post
babaron covered it.
Why do you guys recommend using detail spray to clay with instead of waterless wash? If it's slippier wouldn't it be better to use for claying?
Old 05-15-2012, 08:13 PM   #9
IneedAZ
IneedAZ's Avatar
Good question !
Old 05-15-2012, 09:24 PM   #10
Adam's Polishes
a tad too slippery is the problem... it works a little too well at keeping the clay moving and doesn't allow it to work as it should. The only times I've used waterless to successfully clay is when claying wet, and with a good amount of water on the surface as it seemed to cut down on the slickness by diluting the waterless.
the detail spray has just the right amount of 'slip' to it that allows the clay to slide, but not so much that it doesn't work.
Old 05-16-2012, 04:16 PM   #11
motorhead
motorhead's Avatar
I gotcha! makes loads of sense...
Old 05-16-2012, 07:44 PM   #12
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
I agree !
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline   Reply With Quote
