Accessspeed
Camaro V6 LFX Engine, Exhaust, and Bolt-Ons For all LFX related parts
Old 05-15-2012, 08:31 PM   #1
butters
It's not the batmobile!
butters's Avatar
Drives: 2012 Camaro LFX
3.91 Gear Set?
I know phastek sells a 3.55 set. I have an automatic and was wondering if anyone makes a 3.73 or 3.91 gear set or if it's even possible?
Installed: MRT v1.0 | CAI Intake | VMax PTB | 20" euroTEK UO6 | Toyo Proxes ST II 255/295 | Heritage Grill | RKSport Spoiler | RS Headlights + Demon Eye Halos | Showstopper Sidemarkers | 35% Window Tint | Concept BLACK Fender Scripts
Build Journal: 2012 BLACK Build Thread
butters is offline   Reply With Quote
Old 05-15-2012, 08:40 PM   #2
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
I believe both 3.73 & 3.91 are available for the manuals (auto V6 uses a different diff). I think LPE/AAM make the 3.91, not sure on the 3.73.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 05-15-2012, 08:48 PM   #3
Supercharged SS
Supercharged SS's Avatar
Drives: 2010 Camaro
The 3.70 and 3.91 are made for LPE by American axle and are as good as oem.
http://jreperformanceparts.com/linge...-70-ratio.html
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
Old 05-15-2012, 09:09 PM   #4
butters
butters's Avatar
It says there for the SS, these will still fit an auto v6?
Edit: nevermind, they say they can be adapted for the v6 with new half shafts and a new driveshaft.
Old 05-15-2012, 09:14 PM   #5
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
No. Only gears available for the v6 are 3.55 from richmond that I know of.
MAST 416 STROKER: RDS STAGE 3 TVS 2300
TICK PERFORMANCE CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS NITROUS KIT
CMGS METHANOL INJECTION
KDI HEAT EXCHANGER
CIRCLE D 2800 TCFLEX PLATE /ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
LPE 3.70 GEARS/JRE POSI MOD
DYNATECH HEADERS/MAGNAFLOW EXHAUST/ TEST PIPES
SQUASH RETURN STYLE E85 FS/ID 850's
BMR/EIBACH SUSPENSION
Killing mustangs,because the good Lord wants me to
lexlueger is offline   Reply With Quote
Old 05-15-2012, 09:32 PM   #6
butters
butters's Avatar
Right you are. Just found a great write up from Apex. The autos can upgrade to a 3.55 with a 10% increase in torque.
Manuals can upgrade to a 3.73 with similar results.
http://www.camaro5.com/forums/showthread.php?t=133090
