Old 05-16-2012, 06:18 PM   #1
silver2ssrs10
silver2ssrs10's Avatar
Drives: 2010 Camaro 2SS/RS 6MT
Long term fuel trims question
When datalogging LTFTs what do the values mean in relation to your air/fuel ratio? Is a ltft value of 0.90 rich or lean? Also will the long term fuel trim value modify your commanded pe air fuel ratio? Like say I am commanding the engine to run at 12.5:1, but at the time of WOT PE my long term fuel trim was at 0.90. Would I still be seeing 12.5:1 when monitoring with a wideband or would my air/fuel be off because the ltft is off? Thanks.
silver2ssrs10 is offline   Reply With Quote
Old 05-16-2012, 08:28 PM   #2
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
If the fuel system is operating rich, long term fuel trim will compensate for the rich condition by decreasing the injector pulse width, and a negative long term fuel trim is indicated.
If the control module determines that the fuel system is operating lean, long term fuel trim will compensate for the lean condition by increasing the injector pulse width and a positive long term fuel trim value is indicated
Tampa Tuning is offline   Reply With Quote
Old 05-16-2012, 08:47 PM   #3
silver2ssrs10
So greater than 1 is positive (lean and adding fuel) and less than 1, which in my case is .90 is rich and subtracting fuel?
Old 05-16-2012, 08:59 PM   #4
Tampa Tuning
Camaro Corvette GTO GM truck performance tuning in Tampa
I wouldnt worry about under or over positive 3 %.
That number will change slightly from day to day, fuel, weather, altitude, the type of driving you did that day, etc.
if your swinging 7-10% differance as the norm, that should be corrected.
You should be very happy with 1% because the only time its at zero in WOT.
www.TampaTuning.com
Old 05-16-2012, 09:15 PM   #5
silver2ssrs10
Ok I will keep an eye on it, but just to be clear 0.90 is off by 10% right?
Old 05-16-2012, 11:28 PM   #6
SRT10KLLR
No, 0.90 is 9 tenths of 1 percent.
1.0 would be 1% and 0.90 is 0.90%. If you look at the description it should be something like LTFT(%) so it is indicating it is already in percent format. Under normal circumstances the decimal 0.90 would be 90% but in your log it is already a percent value.
You are under 1% so you are golden.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 05-17-2012, 01:49 AM   #7
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Fuel trims do nothing when the computer goes into open loop. The computer does not compensate anything when doing a WOT pass. Thats why its important to dial in WOT because the computer doesnt care what it sees, its only going to do what it is commanded. The oxygen sensors turn off when in open loop.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 05-17-2012, 06:58 AM   #8
silver2ssrs10
Ok, I just heard if ltft was lean it would add that extra fuel on top of pe enrichment in open loop, so I just wanted to verify. Thanks.
Old 05-17-2012, 11:04 PM   #9
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Ya, that's a common misconception. The factory o2 sensors are actually narrowbands, which mean they can only read from like 13.5 to 15.5 afrs, so when the computer commands 12.x at wot, the sensors can't read it because that is out of their range, so the computer ignores them in PE.
Old 05-19-2012, 05:03 AM   #10
bluetorp
bluetorp's Avatar
Drives: 2010 2SS/RS IOM M6
That's not correct.
If there's a positive trim in the fuel trim cell prior to entering PE mode, the PCM will carry that positive trim over into PE as a protective measure.
Whipple 2.9L S/C, ARH LT's, Flowmaster AMT, HPTuners
bluetorp is offline   Reply With Quote
Old 05-19-2012, 08:34 AM   #11
white ZL1
Drives: none
They can go negative too.
white ZL1 is offline   Reply With Quote
Old 05-19-2012, 08:44 AM   #12
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Send me your logs I will have a look.
If your logging with SCT .90 LTFT means the MAF Curve is a little Heavy and can be adjusted to get closer to our target of .96-1.0
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 05-19-2012, 11:27 AM   #13
silver2ssrs10
Ted.
Ok I will send you the log Ted, thanks.
Old 05-19-2012, 07:30 PM   #14
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
Originally Posted by bluetorp View Post
That's not correct.
Please correct me if I'm wrong but is not a positive fuel trim a condition where the PCM interprets the fuel flow to be RICHER than commanded and reacts by reducing the fuel flow accordingly which effectively leans the AFR? If so, how can reducing fuel flow when entering power enrichment mode be a PROTECTIVE MEASURE?
2SSCAMARO is offline   Reply With Quote
