Flowmaster Exhaust
Old 05-17-2012, 12:58 AM   #1
UNDsioux
Drives: Silver SS
Can u wax rims?
I have meguirs wax and I'm wondering if I can wax my rims. They are 45th anniversary rims
UNDsioux is offline   Reply With Quote
Old 05-17-2012, 12:58 AM   #2
Sleez
Sleez's Avatar
Drives: 2010, 2LT, RS, 6M, ABM (#1893) SOLD
most rims, especially if they have a clear coat, can and should be waxed, i always do mine!
Sleez is offline   Reply With Quote
Old 05-17-2012, 01:05 AM   #3
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
YES!!!
Old 05-17-2012, 01:13 AM   #4
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
Not only CAN you wax your wheels, you SHOULD wax your wheels. Like any other surface of the car as you drive they will be subjected to abuse and the elements. Using a durable wax or sealant to protect them helps make sure that contamination doesn't lead to bigger problems as well as makes them MUCH easier to keep clean.
I personally like our Quick Sealant on wheels. Its very durable, highly heat and detergent resistant, and best of all fast/easy to apply.
Old 05-17-2012, 02:08 AM   #5
spacecowby
spacecowby's Avatar
Drives: 2010 black 2SS/RS
Plus one on the quick sealant. Just put a coat on mine today.
Black cars are not hobbies, they are an obsession
spacecowby is offline   Reply With Quote
Old 05-17-2012, 06:54 AM   #6
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Yes you may, the only problem I run into is that the wax doesn't last long because of the heat that comes the brakes. I like using a sealant for more durability..
Old 05-17-2012, 11:12 AM   #7
Chevrolet Customer Svc
Drives: GM Vehicles
Yes, yes, yes! You can definitely wax your rims. On page 10-90 in your owner's manual is a good starting point on how to clean your wheels. It states: Use a soft, clean cloth with mild soap and water to clean the wheels. After rinsing thoroughly with clean water, dry with a soft, clean towel. A wax may then be applied. Keep the wheels clean using a soft, clean cloth with mild soap and water. Rinse with clean water. After rinsing thoroughly, dry with a soft, clean towel. A wax may then be applied.
Hope this helps!
Brandon
Chevrolet Customer Service
Chevrolet Customer Svc is online now   Reply With Quote
