Advanced Composite Specialties (ACS)
Old 05-17-2012, 01:52 PM   #1
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Upgraded Injectors for ZL1
For those of you putting a pulley/CAI/tune on your ZL1, are you also upgrading the injectors? If so, which injectors are you going with and why? Also, if anyone did a pulley/CAI/tune without new injectors, what max duty cycle did you see on the stock injectors?
Drew P is offline   Reply With Quote
Old 06-20-2012, 01:03 PM   #2
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
wondering this also
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams stage 3 cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 06-21-2012, 01:42 PM   #3
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
I'm going with ID850's. This is with a 2.55 upper/8.6 lower pulley combo, CAI, ported supercharger, and a better HX. I was told with only the 2.55 upper or 8.6 lower, stock objectors would "be ok" but with both, ID850's were needed. I'm also planning a cam and heads later.
Working with KD Innovations. None of it has been installed yet. Starting on the porting next week.
1st Gen Forever is offline   Reply With Quote
Old 06-21-2012, 08:26 PM   #4
ADM PERFORMANCE
214-228-8782
Drives: 2013 ZL1 #138
Our ZL-650 package uses stock.
Our ZL-650+ package uses stock.
Our ZL-750 package uses ID 850.
Our ZL-750+ package uses ID 850 as well (700rwhp 85% duty at 6600)
Our ZL-1000 package uses ID 1000 and ADM Dual fuel pump system with ADM Exhaust Controller
Andy Mages
Owner/Operator
214-228-8782
admperformance@gmail.com
www.admperformance.com
ADM PERFORMANCE is offline   Reply With Quote
Old 06-22-2012, 08:13 AM   #5
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Thanks for the comments. I am doing the same setup as you 1st Gen, except with a custom reservoir with heat sinks built in for additional cooling. Using ID850s as well.
Old 06-22-2012, 09:02 AM   #6
ADM PERFORMANCE
214-228-8782
What car was that?
Andy Mages
Owner/Operator
214-228-8782
Old 06-25-2012, 06:13 AM   #7
Drew P
Drew P's Avatar
Drives: Camaro ZL1
Andy, the car is not finished but should be this week. Pics to follow. As of right now, the new setup is keeping the IAT2's under 140 after multiple pulls.
Old 06-29-2012, 09:32 AM   #8
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Stock injectors just make it with this setup, but depending on the intake and size of the pulley the factory pump will not be enough as they start to drop fuel pressure and air-fuel is not able to be controlled around 630-650BHP.
63lb Siemens or ID850's are two great options. The 63lb will support 650RWHP with ease.
Meister@Torq is offline   Reply With Quote
Old 03-15-2013, 02:12 PM   #9
snapp32e
snapp32e's Avatar
Drives: '81-Z28/'07-Tundra/'12-ZL1/'13-Jeep
Reviving an old thread here. So have we established a good top line performance limit for the stock injectors??? Doing 10% OD pulley/balancer, CAI, Long Tubes, cat eliminate, 102mm Throttle body, RX Chiller / Catch Can and a tune. I'm thinking injectors will prob be in order but just wanted to see if anyone who knows more about it can give me some advise.
ZL1 #612
snapp32e is offline   Reply With Quote
Old 03-15-2013, 09:48 PM   #10
TripleBlkZL1
TripleBlkZL1's Avatar
Drives: 2013 Camaro ZL1 M6
my .02 cent.. don't go with the 102 mm throttle body, especially if your not getting your snout ported to 102 mm.. LS7 throttle body will be good enough.
2013 M6 ZL1..
Mods so far- Roto-Fab Carbon Fiber Cold Air Intake, Ported and Polish LS7 Throttle Body and Snout, 2.5 Upper Pulley, 100mm Idler Pulley, Solid Supercharger Isolator, Afco Heat Exchanger with fans, ID850' fuel injectors, Stainless Works 2" Longtube Headers With High Flow Cats, and 91 octane dyno tune.. 579.8rwhp and 537.4rwtq
Tune done by Ryne at Cunningham Motorsports
TripleBlkZL1 is offline   Reply With Quote
Old 03-15-2013, 09:49 PM   #11
snapp32e
snapp32e's Avatar
I am getting it ported.
ZL1 #612
Old 03-16-2013, 08:48 AM   #12
Mattzl1
Mattzl1's Avatar
Drives: 2013 ZL1
I would say that if you are getting it ported for the 102 throttle body, you should install the 2.5 upper pulley being the snout is off already. Easy boost in power. I would definately go with the ID850's . They are so much better for fine tuning. From all my readings just about anything over stock should have bigger injectors. My .02
2013 ZL1 AGM, ECF, A6, sunroof, black rims
mods complete! 664 RWHP, 645 RWTQ
Ported snout, 2.5 upper, Innovators west balancer with 9.1 lower, New era intake, American Racing headers with cats and X pipe, KDI heat exchanger, ID850's, TS29 cam !
Mattzl1 is offline   Reply With Quote
Old 03-17-2013, 09:30 AM   #13
snapp32e
snapp32e's Avatar
I agree. My tuner said that he figured there would be enough left in the stock injectors but i would rather error on the side of caution and upgrade. Thanks for the advice.
ZL1 #612
