Solo Performance
Old 05-12-2009, 06:42 PM   #1
logan1080
logan1080's Avatar
Drives: 2003 Crew Cab Duramax
Good brand for rear gears?
Hey I was wondering how to go about swapping the gears out in the camaro for a set of 3.73's. What all would have to be changed, what is a reliable durable brand? cost?
logan1080 is offline   Reply With Quote
Old 05-12-2009, 08:42 PM   #2
kdoske
Waiting For My 1SS/RS SIM
kdoske's Avatar
Drives: Sold My Lancer, now carless :/
why is everyone so obsessed with changing the gearing and the batteries on this car, im baffled...
kdoske is offline   Reply With Quote
Old 05-12-2009, 08:50 PM   #3
bobby35ny
bobby35ny's Avatar
Drives: 2017 ZL1 M6, bye 2013 ZL1, 2010 SS
Richmond gears was always good brand to go with.
Alot of us feel that the 2010 is coming with a pretty dead rear. A 3.73/3.90 would help alot with accelleraton.
No clue on the batteries.
=bobby
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is online now   Reply With Quote
Old 05-12-2009, 09:04 PM   #4
Warpick
Drives: Rust bucket and a jalopy
3.73 or a 3.90 is also going to kill your gas milage.
Warpick is offline   Reply With Quote
Old 05-12-2009, 09:07 PM   #5
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
Maybe the 2011 camaro will get a choice in gear size, I've used Richmond in three of my cars with no problem.
69 Hugger is offline   Reply With Quote
Old 05-12-2009, 09:13 PM   #6
bobby35ny
bobby35ny's Avatar
Kill it? doubt it, 6th gear is solid. Sure MPG will be affected but not kill it.
=bobby
Old 05-12-2009, 09:21 PM   #7
logan1080
logan1080's Avatar
not worried about mileage, this car isn't my daily driver, its going to be a pavement pounder.
Old 05-12-2009, 09:33 PM   #8
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
No. Assuming a .50 or .56 6th gear, as Tremec has always put in as their second overdrive, you should really only lose 1-300 rpm when cruising in 6th at 60-70-80. TR6060s and T56s are geared long as is.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 05-12-2009, 09:41 PM   #9
Shurenuff
Shurenuff's Avatar
Drives: 2002 Nissan Altima
That's what I'm really hoping for when I order next year.
Shurenuff is offline   Reply With Quote
Old 05-14-2009, 09:23 PM   #10
ADM PERFORMANCE
Drives: 2016 CAMARO SS
Gears-update coming very soon!
I should have concrete information very soon.Already have 1 apart taking measurements and will have ratios spec out very soon.
Currently the Camaro SS runs through the traps on the rev limiter in 3rd gear.This will be eliminated once our gears are available.With that being said,you can also just add more power or change the rev limiter.
Lotta data coming down the pipe on this vehicle
ADM PERFORMANCE is offline   Reply With Quote
Old 05-14-2009, 09:37 PM   #11
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
Originally Posted by PoleCat2SSRS2010 View Post
Same here. My other used to get 6 mpg with 4.11s and Sunoco purple.
LOL, yeah I can relate to that. Nothing improved milage like the computer controlled closed loop EFI.
From a 2.73 to a 3.73 we only saw about a 1 MPG drop in consumption.
Depends on a lot of factors.
I got the call tonight. I will have a 3.90 in my hands Tuesday or Wednesday of next week. I have a spare diff assembly that we will install the gears.
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 05-14-2009, 10:25 PM   #12
69 Hugger
69 Hugger's Avatar
The cars got an OD so it can't /shouldn't be that bad with 3:73 ? need to get a close up of the IRS,
Old 05-14-2009, 10:40 PM   #13
mmbarberoilman
mmbarberoilman's Avatar
Drives: 2SS, 48 Plymouth, 77 Coup Deville
People jumped all over me when I talked about better gears for my 2SS Auto. Depends what you want. I can not see this car suffer much with a stiff gear. It has that 6 speed trans folks. Think about it. We used to run 3 gears in a turbo 400. Besides not all of us need to go 170 MPH, especially when the plastic front end destoys itself at 155 anyway. PLEASE list any mods needed to upgrade. Anyone that does it PLEASE list costs, mods needed to keep everything else happy and of course performance differences. I want more from my car and it should be relatively easy to get this car scary with just gears and another 100 horses.
mmbarberoilman is offline   Reply With Quote
Old 05-14-2009, 11:04 PM   #14
rayhawk
rayhawk's Avatar
Drives: Trailblazer SS
I would do a lot of things before I put gears in the Automatic car. Think about it, you are already using 4 gears to go through the 1/4. And the first gear is very low on that trans. You are right that it will not suffer much on the highway with a change in gears, but I don't think it will really be a great performance boost. Now on the M6 car, I think a gear swap will be very worthwhile. Think about it, you are running up against the rev limiter on that car at the track, and will probably have to shift into 4th right at the end of the 1/4 if you add any power.
If I had the automatic car I think the best money would be spent doing the exhaust first, Long tube headers, etc., then the next step would be to get rid of the AFM cam and lifters, and put a decent cam in there. This should get you to 475 crank hp without much trouble, and you could move the rev limiter up to at least the 6600 limit of the LS3. Hell, our 01 z28 auto had a 2.73 rear and only used 2 gears through the 1/4 mile-now that car needed some gears!
And BTW, the plastic front end was a preproduction part, the issue was addressed on all consumer cars. Feel free to do 155 on your daily commute.
Hooters, hooters, yum yum yum, hooters, hooters on a girl thats dumb.
-Al Bundy
07 2WD Trailblazer SS, LS1 E-fans, 4" FWI, pcmforless tune
rayhawk is offline   Reply With Quote
Good Idea? Bad Idea? cam2fst4u Off-topic Discussions 25 04-13-2009 09:06 PM
Saw Fast & Furious tonight. It's.... GOOD! 2Muchmark Off-topic Discussions 2 04-11-2009 12:25 PM
Good Dealer themossman Camaro Price | Ordering | Tracking | Dealers Discussions 0 04-01-2009 03:01 PM
Big 3 CEO's (and UAW CEO) answering questions on CNBC (yesterday) TAG UR IT General Automotive + Other Cars Discussion 101 11-21-2008 02:14 PM
Crash tests downgrade small cars KILLER74Z28 General Automotive + Other Cars Discussion 0 12-19-2006 04:31 AM
