Old 05-20-2012, 07:48 PM   #1
Dtrimpi87
Banned
Drives: 2010 2SS/RS A6 & 2011 1LT/RS
Quick service question
This probably belongs in a different section but this section gets more traffic. I have to take my camaro to the dealer tomorrow for a CEL. The light went off today but I read the stored codes and I had 1 for a misfire in cylinder 4 and 1 for the 2nd bank running lean. The only engine mod I have is a K&N Typhoon intake. Should I put the stock intake on before going to the dealer? I have the card that comes with the K&N that says the product WILL NOT void your warranty.
Dtrimpi87 is offline   Reply With Quote
Old 05-20-2012, 09:07 PM   #2
jd10013
Drives: 2012 camaro
I was always under the impression that a misfire would cause the CEL to blink, as opposed to steady on.
jd10013 is offline   Reply With Quote
Old 05-20-2012, 09:24 PM   #3
Stealthpanda
Thread Ender
Stealthpanda's Avatar
Drives: 2010 Camaro 2SS/RS L99
Intake shouldnt throw a code, but putting it back stock shouldnt be too much of a hassle and may make things easier in the long run. Cheers.
Stealthpanda is offline   Reply With Quote
Old 05-20-2012, 09:33 PM   #4
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
It's been quite a while, but I thought I remembered a thread about the K&N's causing a CEL... was that just the V6 though?
Sterling is offline   Reply With Quote
Old 05-20-2012, 09:37 PM   #5
Stealthpanda
Thread Ender
I mean... I was told some do. Random cars MAFs didnt like it or whatever. Dealer told me to be careful on what Cai I used and that there example was the Cobalts didnt like certain intakes and some threw codes... Id have to assume that this isnt intake related. Who knows though, certainly not me. Cheers.
Old 05-20-2012, 09:43 PM   #6
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
It won't hurt to but I was told by my delear that a CAI won't void anything unless maybe the oil from the filter damaged the mass air flow sensor
Proud owner of litho #179 Click Picture for Build Thread
Old 05-20-2012, 09:44 PM   #7
Dtrimpi87
Banned
It came on yesterday when I was driving the car moderately hard. No overheating issues, all fluids are good. It was a steady CEL, no flashing. After letting the car sit for an hour last night I restarted it and the light was gone. Its stayed off all day today too. It does seem to run a little rough on idle but everything sounds normal and it doesn't skip a beat when on the throttle. I'm taking it to the dealer to get checked out but I was just wondering if theyre going to give me a hard time for the K&N and be able to deny any warranty repairs if needed.
Sent from the rocket in my pocket, my all powerful DROID BIONIC.
Old 05-21-2012, 07:11 AM   #9
clg_98ta
clg_98ta's Avatar
Well, they will almost certainly blame the intake for the codes... so the problem won't be covered by your warranty. The only question is will they go so far as to void parts of your warranty...
It it were me, I would replace the stock intake and drive around for a few weeks. If the code comes back, take it in for warranty service. If it does not come back, you can reinstall the K&N and see if the code comes back. If it does, you'll probably need a tune (voiding powertrain warranty).
Old 05-21-2012, 11:19 AM   #10
merlin803
merlin803's Avatar
Drives: 2016 Summit White Camaro 2SS
Did you check your MAFs to see if it is "weak" one? I know that I saw some threads on here about certain ones not being able to handle aftermarket CAI's.
I believe that you want one that has a two digit ID on it as opposed to a one digit one.
merlin803 is offline   Reply With Quote
Old 05-23-2012, 01:47 AM   #11
Dtrimpi87
Banned
Well the dealer said they didn't see anything wrong. The tech pulled the codes and monitored the ECM and says everything is well within spec. No misfires detected and fuel trims are fine. Checked all the wiring for cuts, burns, and abrasions and said everything looks good. Cleared the codes and said to bring it back if it happens again.
The only thing they said about the K&N was that it wouldn't be the first time they've seen a K&N throw codes on a Camaro. My service writer said that if it happens again to look at getting a different brand intake lol completely the opposite of what I thought they'd say.
Old 05-23-2012, 01:49 AM   #12
Dtrimpi87
Banned
Now that you mention it, I do remember reading something about that. Ill check my MAF sensor out tomorrow.
Old 05-23-2012, 05:46 PM   #13
Stealthpanda
Thread Ender
Yeah, every dealer is different. I know Elkins did say there wouldnt be an issue, unless they could prove the modification caused whatever issue that might have risen. Cheers!
Old 05-23-2012, 07:30 PM   #14
TooCool5
Resident Gearhead
TooCool5's Avatar
Fuel injector cleaner.
