Emblempros
Old 05-20-2012, 10:50 PM   #1
NLCamaro
Drives: 2011 SS1 1/2 Camaro
Help with interior scratches
I recently bought some used Aux Gauges for my SS1 Camaro everything works great however they do have some scratches on them. Can Anyone give me some tips to fix them without having to go out a repaint them completely? I tried some car wax didnt work at all.
NLCamaro is offline   Reply With Quote
Old 05-21-2012, 02:05 AM   #2
2010abmss
2010abmss's Avatar
Drives: 2010 ABM SS
More than likely you'll just have to repaint them
Sold 2010 ABM 2SS RS. Kooks, Corsa CB
2010abmss is offline   Reply With Quote
Old 05-21-2012, 05:44 AM   #3
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
Yes, I agreed on this. Looks like you might have to repaint it again unless you can find someone or a product that will remove those scratches like using a polish by hand. Let us know how it turns out for you.
Old 05-21-2012, 07:10 AM   #4
Angelo@Autopia
Also I do remember that you may be able to repaint it yourself using OEM Spray paint from Dupli-Color.
Old 05-21-2012, 08:11 AM   #5
NLCamaro
I'm going try a few products to remove scatches if they dont work ill just go ahead and respray
Old 05-21-2012, 09:08 AM   #6
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
It never hurts to try. When you remove scratches you end up smoothing the surface around the scratch as well (polishing). This leads to that area having more gloss/shine than the other areas. That is why it is near impossible to remove scratches from satin or flat finishes.
Old 05-21-2012, 08:56 PM   #7
NLCamaro
Do you know whats the color name ? I'm going to respray it this weekend
Old 05-21-2012, 08:59 PM   #8
Angelo@Autopia
Maybe your GM dealer will be able to tell you the color code you need.
Old 05-28-2012, 08:52 PM   #9
NLCamaro
I was having a hard time trying to find the paint in a spray can so I decided to try wetsanding the the scratches out . I started out with some 2000 grit sand paper wetsanding the area with plain water then I polished the area with plastic headlight polish and it worked good. The only thing you wanna watch out for if you going to try this is not to sand too much I did on one of the scratches and it didnt come out as good as the rest .
Old 05-28-2012, 08:59 PM   #10
NLCamaro
I posted the wrong image for the upper part of the bezel here is the right image
