Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros > 4th Gen Marketplace
Old 05-21-2012, 12:30 AM   #1
pincushin3819
pincushin3819's Avatar
Drives: 11 AGP TT SS, 14 ECS C7
TSP 418 LS2/L92 conversion
BRAND NEW
LS2/L92 conversion package: LS2 front cover w/cam sensor, LS2 valley cover, LS2 single roller timing set, cam & knock sensor extension harness, LS2 lifter trays, GM L92 aluminum block, 4.065 factory bore size, Eagle LS1 4.00inch stroke crankshaft, 24x tooth reluctor, Eagle LS1 6.125 h-beam connecting rod set w/upgraded ARP 2000 rod bolts, 2.100 crank journal, .927 wrist pin, Dimond Racing 418 L92 stroker piston set, 4.080 bore, 4.000 stroke, 6.125 rod length, flat top -4cc valve reliefs, setup for L92 chamber, TSP total seal ring set, 4.080"+.005", 1.5mm plasma moly top, 1.5mm napier 2nd, camshaft bearing set for LS2 & 2nd gen LS1 engine block, 8 Clevite LS1 h-rod bearing, Clevite h main bearing set, full block work & preparation, vat block, line bore, install new cam bearings, bore/hone w/torque plate, blalance rotating assy., line hone, 10 GM bolt LS2 side main cap & rear cover, GM LS1 oil restrictor, GM LS1 oil galley core plug, GM LS1 large coolant plug, 3 GM engine block small coolant plug, GM engine oil supplement, assemble short-block, Precision Race Components CNC ported L92 heads, fully assembled w/PRC dual valve spring kit & hollow stem 2,16/1.59 valves, Comp cams custom camshaft, TSP chromemoly 7.40 pushrods, 2 cometic L92/LS3 4.085 bore .040 thickness cylinder head gasket, 2 GM cylinder head bolts, 4 GM LS1 lifer tray bolts, GM camshaft retainer plate, 4 GM cam retainer plate bolt, GM LS1/LS2 rear main seal housing gasket, GM LS2 timming cover gasket, GM LS2 valley cover gasket, GM oil pump o-ring, GM LS1 balancer pulley bolt, 2 LS1 exhaust manifold gasket, GM LS1 oil pan gasket, 2 GM LS1 water pump gasket, GM LSX rear main seal, GM LS1 front crankshaft seal, 4 GM engine block dowel pin, 8 GM L92 intake rocker arm 1.7:1 ratio, 8 GM Exhaust rocker arm 1.7:1, 16 GM LS1 rocker arm bolt, 2 GM L92 rocker arm pedestal, assemble long block, GM bare L76 intake manifold, GM L76 fuel rail, 8 FAST fuel injectors, 4 GM L76 fuel rail bolt, PTM 92mm throttle body, 10 GM L76 intake manifold bolt, GM L76 throttle cable bracket manifold.
Asking price $10,000 + shipping
pincushin3819 is offline   Reply With Quote
