| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
![]() Drives: 2013 2ss/rs A6 yellow !!!!! Join Date: Nov 2011
Hurst billet plus side too side play
Does anyone else have this ? I have an inch side too side in gear or not but its tiggt front too back
![]() Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
Yep. Mine does it, and it seems normal from the other cars I've driven with this shifter.
2011 Camaro 1SS/RS
Hotchkis Chassis Brace, Rotofab Intake, Hurst Short Shifter, BMR Springs / Trailing Arms / Sways, Nitrous Outlet 150 Shot, SubThump Stealth Box, TSP 1 7/8 Headers, VMax TB, JRE Scoop, Rotofab Washer Relocation, JRE Tune |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS M6 Join Date: May 2011
There was a thread a while back about a bushing going bad that caused excess slop. Hurst was sending out free replacements to people who called.
I would never accept that much slop in a performance car shifter. |
do you think you could find that thread for me please and yeah is unacceptable play it feels like a piece of crap im pretty let down.....
OSOSIK
Drives: 2010 SS LS3 /2005 SS Silverado Join Date: Sep 2010
How many miles do you guys have on this shifter? I only have about a half inch with 6200mi on it.
#6 |
#7 |
I have the same issue. I called Hurst, and they were quick to send me a replacement bushing for free, but I haven't installed it yet. Not really a big deal to me, still love the shifter.
#8 | |
ʇuɐıʌǝp lɐıɔos
Drives: 2011 2SS/RS LS3/M6 Join Date: Feb 2011
Way too many mods and way too much money. Wouldn't have it any other way. |
#9 |
![]() Drives: 2010 SS2,6M Join Date: May 2012
I installed the Hurst shifter, after only a few hundred miles on it the side play was rediculous. I called Hurst and they sent out a "new" design bushing. I recieved it and it was the same as originally that came with the shifter. What I did to fix the problem was design and MFG my own. I made a split bushing out of oilite bronze, I Incresed the side surface area ( to increse side load stability ) Turned the O.D for a +.001 slip fit. I bored the I.D to -.0005 under size then took the original locating pin and burnished the bore to the pin. Installed and has been driven for over 5k miles. It's just perfect. I had my car serviced last week ( Z06 clutch assemlbey ) and the service guy asked,.. who did your shifter install ? I laughed.
#10 | |
ʇuɐıʌǝp lɐıɔos
#11 | |
![]() Drives: Silver 2SS, 68 Firebird 400,70 vett Join Date: Jul 2009
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 SS/RS Join Date: Jun 2011
Mine was pretty tight in the.beginning and the slopped up a few months down the road.
#13 |
#14 |
Well i called them and finally got someone on the line... At first i got the old ..we havnt had any reports of that untill i said o yeah so all the guys on camaro5 are crazy then? And then he said "sir ill get those out too you right away" he said he was sending me a few so we will see. I really feel that this is unexcusable especialy coming from HURST? Am i right or wrong? So i basicly paid for shiny shifter with more slop then the factory one ? Im so confused
#15 |
The issue is that the Hurst bushing is made from (PTFE) Teflon, I believe. And while this is excellent for low friction applications and smooth surface to surface operation it has a very low tensile strength and an RC of 55. I designed and made one from oilite bronze (SEA 841) that has inherent self lubricating properties. In my opinion this is what Hurst should be using for a bushing material.
#16 |
![]() ![]() ![]() ![]() Drives: 2010 2SSRS headers/CAI/tune/corsa, Join Date: May 2010
I have read that the Barton's & others also do it so it sounds like its in the trans linkage to me. Mine seems to be the same after only ? 500 miles .No more slop then the stock but to early to tell.
Stainless works headers/cats Roto fab CAI /
Corsa and install and tune Livernois TSW Nuburgring 9 &10" x20 on Invos JL Audio XD400/4 amp Pfadt trailing arms & tie rods sway bars. pedders street 1 package |
#17 |
![]() Drives: Camaro LLT Join Date: May 2012
Does anyone have a picture, and dimensions for this bushing. Becausse I have a full machine shop at my command, and I can put a job to have a couple made.
Me with all this horsepower, and no room to gallop! Mods are as follows.
Flowmaster thunder axle back, Magnaflow resonated x-pipe, Custom Inkonel mid pipes, BBK short ram, RX Black Ice-olator, BBK headers with titanium wrap, V- Max Plenum spacer, Barton short throw shifter, TWM Big Type R weighted Shift nob, Goodrich SS lines, EBC Red stuff pads, Grant steering wheel, RX ported throttle body, RX catch can, Soon to come. RX supercharger, TSW tanaka & nitto invo red line, 1LE shocks, PFADT 1" drop springs, Full BMR bushings. |
| Thread Tools | |
