Emblempros
Old 05-12-2009, 09:55 PM   #1
viper612
Drives: 2010 Camaro SS/RS
2010 Camaro SS Issues
First off I want to make it clear that I really like this car.
Now for the issues after 1600 miles:
About 20% of the time the key fob does not unlock the car, I have to open the car with the key, the car starts to flash (hurry up before the alarms goes off), need to start the car, then press the unlock button to open the passenger side.
About 10% of the time I have to press the lock button about 10 times before the car will lock.
If you use a USB drive with MP3's on it for music, the stereo needs to re-index the list every time you insert the memory stick into the USB port (slow). Aside from this, you need to unplug the memory stick and put it back in before it will recognize the stick is even there after a restart of the car.
So I switched to an Ipod Touch, now no need to index anymore, after about an hour in the car the screen freezes (still getting music) and it does not update the next song that comes on, or any new songs for that matter. You need to shut the car down and restart to reboot the thing, turning it on and off does not do the trick, you need to turn the car off (odd).
The bluetooth is now acting up with my iPhone, it has started to crackle when I talk to people, I only hear every other word they say. I turn off the "General Motors" bluetooth and back to "Iphone" and everything is normal, not a signal issue.
The button to open the sunroof to vent most of the time opens the roof all the way back. You will learn to be fast and press it again if it starts to slide back, and if you quick enough you can stop it close to where you intended it to be. If you close it a few times it will finally just vent as designed.
So the question is, any one know if there is a firmware update for the Camaro yet to address some if not all these issues?
Thanks.
-Travis
viper612 is offline   Reply With Quote
Old 05-12-2009, 09:57 PM   #2
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 05-12-2009, 09:58 PM   #3
Milk 1027
Camaro➎ moderator
Milk 1027's Avatar
Drives: '13 BLK 1LE
Thanks.
-Travis
hmm. interesting. the key fob thing might just be that you need a new battery in it.
Old 05-12-2009, 09:58 PM   #4
viper612
You want pictures of the problems?
Old 05-12-2009, 09:59 PM   #5
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
The only issue I have had is with the USB and my flashdrive. The screen will freeze, music still plays. I have notice it only does it on certain songs. I am going to remove the two songs it does it with and see if it fixes the problem. I have not had any of the other issues you listed.
Old 05-12-2009, 10:00 PM   #6
Number_9
Number_9's Avatar
Drives: 2010 2SS/RS L99
Looking forward to testing this some day!
Number_9 is offline   Reply With Quote
Old 05-12-2009, 10:01 PM   #7
RPO_Z28
RPO_Z28's Avatar
Drives: 2007 C6Z
Sell it.
RPO_Z28 is offline   Reply With Quote
Old 05-12-2009, 10:03 PM   #8
Blue Joe
Drives: 2010 IBM/1SS
on the remote,try holding the button for 2 seconds.you may be releasing button too soon.They have been like that lately to keep from accidently unlocking your car.
Blue Joe is offline   Reply With Quote
Old 05-12-2009, 10:04 PM   #9
fbodfather
fbodfather's Avatar
Hmmmm...can't speak to the Blue-tooth and Ipod issue -- I haven't used those features yet. (I'm not the most technical kinda guy..)
The remote fob sounds like you may need either a new battery or perhaps one of the leads is not making contact.....I'd open it and take a look at the battery leads -- if not, take it to your dealer and have them replace it.
I've not had problems with the sunroof as I kinda like the 'express open' feature.
Old 05-12-2009, 10:04 PM   #10
levi1922
levi1922's Avatar
Drives: 2LT RS CGM
hmm, this is oddd. i havent heard anything else about it. you should call your dealer and see what they say
levi1922 is offline   Reply With Quote
Old 05-12-2009, 10:08 PM   #11
bugsy
Drives: 2000 gmc blue z71 ext
sounds like the body controller is a lil quirky as for the bluetooth ... who makes the head unit? or does the BCM also control the head? dono how the software is set up.. but thats sounds right if you got to restart the bcm for the head to work again.. soooo my guess bad software or Defective BCM.. also controlls windows and sun roof take it back and ask for a diagnostic..or a reflash....
bugsy is offline   Reply With Quote
Old 05-12-2009, 10:17 PM   #12
RPO_Z28
RPO_Z28's Avatar
Drives: 2007 C6Z
Bluetooth with IPhones have been a problem in Corvette. I would be curious what people with Blackberry's have to say.
Old 05-12-2009, 10:18 PM   #13
Number_9
Number_9's Avatar
Originally Posted by RPO_Z28 View Post
...I would be curious what people with Blackberry's have to say.
"Wish I had an iPhone!" ?
Old 05-12-2009, 10:19 PM   #14
viper612
I'll take it to the dealer, not 100% that dealers are up to speed on the car yet. I can at least ask that they swap out the "BCM" or reflash it.
Thanks.
-Travis
CAMARO WIKI Tran Wiki 54 02-06-2016 11:33 AM
Drag Test: 2010 Camaro SS Nine Ball 5th Gen Camaro SS LS LT General Discussions 129 11-10-2010 06:28 PM
Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 338 04-15-2009 05:33 PM
2010 Chevy Camaro to offer two V6s at launch; Z28 to trump SS? radz28 Camaro ZL1 Forum - ZL1 Specific Topics 51 06-23-2008 12:12 PM
