Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Mid-Atlantic > Local Marketplace
Old 05-22-2012, 12:27 AM   #1
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
FS: Remote Vehicle Starter
Remote Vehicle Starter never used. Made by "ALERT". I opened the package to make sure all was there but never got around to installing it. Everything is there, instruction manual, instructional dvd, the wires have never been touched still wrapped up in original packaging and includes on and off key fob for easy convenience.
This could be a great addition to your camaro, other car, truck or suv, with summer approaching you could have the A/C cooling down your vehicle while you are waiting to get in.
Asking $30 OBO
Old 05-22-2012, 04:03 AM   #2
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Will this kit work for a manual transmission?
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 05-22-2012, 12:47 PM   #3
camaroitalia
Drives: 2010 CGM
I just read through the instruction manual and all and it does not state that you cannot use it on a manual transmission. So I am assuming that yes you can.
Old 05-22-2012, 09:02 PM   #4
edog
edog's Avatar
Drives: 2010 2SS/RS IOM
Remote starts can be installed in manuals, but recommend against it. If you leave the car in gear and try to start it with the remote start it will buck forward, and if it does start you could hit objects/people in friont of the car.
I had it on a manual 91 Maxima once. I watched it lurch across the top deck of parking garage. It was hilarious, but could be dangerous.
NOVI1500 ECS SC, 13lb boost, LS3 Conversion 113/225/238 COMP CAM, Pro Yank 3600, 1-3/4 Doug Thorley Tri-Y LT/HF cat, X-Pipe, Lingenfelter dual fuel pump, ATI super damper pulley, Ported TB, 160 therm, Tranny cooler, Pedders sways/end links/sub frame bushings, BMR trailing arms & toe rods, 1" Eibach Drop, 3.45 gears. 705HP/589TQ
edog is offline   Reply With Quote
Old 05-27-2012, 06:57 PM   #5
camaroitalia
Drives: 2010 CGM
$25 OBO
Old 05-31-2012, 08:31 PM   #6
camaroitalia
Drives: 2010 CGM
First $20 takes it!!!
