third_shift studios
Old 05-22-2012, 03:14 AM   #1
Noviathan
Drives: 2012 2LT RS Camaro Coupe
Factory Amp & Subwoofers
Hey guys, I just bought my first car ever a 2012 2LT RS Camaro coupe and I am loving it. Everything is good but I just have a few questions about the sound. I have the BA premium sound system package and I was wondering if I can just use that factory amp to hookup subwoofers to. I plan on getting a subwoofer from ********. How bad would the sound be if I didn't use another amp? Also I have no prior knowledge of installing subs or amps to any car. So any advice would be much appreciated!
P.S Can anyone of you guys who have installed subs and amps before list some tools/parts I should buy to make this installation idiot proof for a newbie? Thanks alot fellas
Noviathan is offline   Reply With Quote
Old 05-22-2012, 04:17 AM   #2
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
You have to use and aftermarket amp, subs won't work without em. With the ******** X3 harness all you really need is some exviromental splices, a crimper, heat gun, and wire strippers. You will need an amp install kit with the correct gauge wire and fuse setup for whatever amp / sub combo you are using. If you have never done it before I would reccommend having a friend who has done it before show you, or get busy watching videos online from car audio sites.
Bildo is offline   Reply With Quote
Old 05-22-2012, 04:58 AM   #3
Noviathan
do you think its a good idea if i purchase the dual sub package from ********? just to get me started and ill tweak/change amps/subs later.
Old 05-22-2012, 05:39 AM   #4
Brolik10
BLOWN!!!
Brolik10's Avatar
Drives: 2010 RJT 2SS
First time out, buy everything from the same source.. ******** will have everything you need..
Blown! Full Bolt-ons!
Brolik10 is offline   Reply With Quote
Old 05-22-2012, 03:45 PM   #5
2010SSRSM6
SoCal C5 Family Member
2010SSRSM6's Avatar
How crazy are you wanting to get with your system? Are you wanting something that will be heard from blocks away or are you wanting something you can turn up and just kill your own hearing? A single 10" will sub sound great, but you can always go with a single 12" or dual subs (either 10" or 12") if you want deeper, harder hitting bass.
I installed a single 10" drivers side enclosure from ******** and a passenger side amp rack. If I had it to do over, I would have gotten the passenger side sub enclosure and drivers side amp rack (it cuts down on the amount of cabling you have to run from the ******** amp harness to the actual amp helping to keep everything cleaner).
As far as tools, a good set of wire strippers, wire cutters, wire crimps (same gauge as the wire you are going to run to the amp from the harness, I think the harness uses 18 gauge but I don't remember off the top of my head), electrical tape and zip ties, 10mm wrench or socket for the battery cables, and patience will cover everything you need.
Since you are ordering your sub from ********, get his FARK (factory amp replacement kit), amp, amp install kit, box, amp rack and speaker grill and you will have a great starting point for your system. If you are going to use the JL amp that fits in the factory location, you can ditch the amp rack and save some $$$.
Once you get everything installed, you will be able to figure out what you like and don't like and can make any future plans from that point. The only thing I can say is the sound change from the factory amp to an aftermarket amp is HUGE! You may not want to swap the factory speakers out after you have replaced the amp.
Good luck!
UNDER CONSTRUCTION. ETA 2017 ish...
Old 05-22-2012, 07:08 PM   #6
ohsnow
ohsnow's Avatar
Drives: 2012 SS
I did JL audio 12" sub and 500X1 amp....
Install 2 hours.
Sound AWESOME
ohsnow is offline   Reply With Quote
Old 05-23-2012, 12:27 AM   #7
Noviathan
Thanks everyone, I saw a video on ******** about the t-harness and my question is that can i connect an amp through the harness to the factory amp? Or should I just replace the factory amp with an aftermarket amp?
Old 05-23-2012, 04:13 PM   #8
darkrider01
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Kia Forte5 SX
I highly recommend replacing the factory amp.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Pioneer DEX-P99RS * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
Old 05-23-2012, 10:03 PM   #9
Noviathan
I can't seem to find the FARK on ********. I see it listed on one of their packages but not by itself.
Old 05-24-2012, 06:50 AM   #10
Pur3vil
Drives: 2010 ABM 2SS/RS M6
From what I read, they re-designed the kit again and once it comes in, it will be available on the site.
Pur3vil is offline   Reply With Quote
