JDP Motorsports
Old 05-13-2009, 02:41 AM   #1
Camaro_Psycho
Drives: 1981 Chevy Celebrity
Another Rear End Question
Hey guys.
Sorry to be a total noob, but how does the gears work?? What I mean is that, what does the actual number mean? When it says 4.56 gears, what does that mean? Is it for every 4.56 times turn of the drive shaft does the tires turn 1once or vise versa or what?
Thanks
Camaro_Psycho is offline   Reply With Quote
Old 05-13-2009, 04:41 AM   #2
TT C6
Banned
Drives: C6, 96 383ci Z28 hardtop
Google is your friend.
Final Drive Ratio
The gear ratio in a vehicle's differential. The ratio expresses the number of turns required by the pinion (which is attached to the output shaft of the transmission) to turn the drive axle one revolution, i.e. 2.73:1 means the pinion must turn 2.73 times to turn the drive axle once. A higher number means a lower (or shorter) gear. Short gearing gives quicker acceleration, but because the engine must turn faster, gas mileage and top speed are lower. Tall gears give better acceleration and higher top speed, at the expense of acceleration.
TT C6 is offline   Reply With Quote
Old 05-13-2009, 09:58 AM   #3
Grape Ape
Drives: 96 Bronco w/ a 5 speed
Originally Posted by TT C6 View Post
Final Drive Ratio
I think that should be better mileage and higher top speed, at the expense of acceleration.
Grape Ape is offline   Reply With Quote
Old 05-13-2009, 11:36 AM   #4
lrc250
480 HP 2010 2SS
lrc250's Avatar
Drives: 2010 Camaro 2SS
Originally Posted by Camaro_Psycho View Post
Hey guys.
Thanks
Yes, for every 4.56 turns of the drive shaft the tire rotates once. --> 4.56:1
Without data you are just another person with an opinion.
1100 :10/15/08
3000:3/2609
3300:4/18/09
3400 (broadcast)April 25, 2009
3800 (produced):May 4, 2009 #7470
4200 (Shipped): June 1, 2009
5000 (At Dealer) June 9,2009
374.9 rwhp & 371.7 rwtq - bone stock @ 85 deg.
lrc250 is offline   Reply With Quote
Aftermarket Cold air intake SSCamaro2010 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 40 10-01-2010 03:32 PM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 02:11 PM
2SS exhaust, 2 part question. HELP!! 2SS is mine!! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 11-16-2008 07:51 PM
rear end clunk PLEASE HELP! redriverchevy 4th Generation Camaros 26 09-10-2008 08:21 PM
Corvette C6 GTR TFord General Automotive + Other Cars Discussion 3 08-06-2008 10:26 PM
