B&M Racing
Old 05-22-2012, 09:11 PM   #1
flyer08
Drives: 2010 2SS/RS
Upgrade speakers
First off Ill say Im a newb and need help. Ive looked around and found high remarks on this amp, JL audio 9005. I plan on running one 10" or possibly two 10" subs. Either one JL Audio 10W7-3 or two Rockford Fosgate P2D210 Punch 10". Would this amp be beneficial if I ran 500watts to sub and 400 watts to stock BA speakers? Or is this even possible? Am I getting to much? I want something that will hit when I have songs with bass but I dont need something so big/loud that I cant hear the lyrics.
Thanks
flyer08 is offline   Reply With Quote
Old 05-22-2012, 09:15 PM   #2
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
I have the non-BA system in my car. I added the HD900/5 and upgraded the front door speakers at the same time. I powered the stock rears, which are a lot worse than yours, off of the amp for a month or so, without any issues. It absolutely improved their sound.
The HD900/5 manual tells you what output voltage to use, based on the impedance of the speakers being used. I set it accordingly, and believe it would have lasted indefinitely.
http://www.camaro5.com/forums/showth...7&postcount=32
jeepguy_1980 is offline   Reply With Quote
Old 05-23-2012, 01:07 AM   #3
2010SSRSM6
2010SSRSM6's Avatar
I ran the Arc Audio 900.6 to my factory door speakers and as long as you don't turn the gain up too high they don't sound that bad.
I'm running a single 10" sub that has plenty of bass for most days. It isn't going to break any SPL records, but it give the music the right touch it is missing from the factory.
If you don't like the way it sounds, you may want to look into Hybrid Audio Technology. They make a great product.
Old 05-23-2012, 10:45 PM   #4
flyer08
Drives: 2010 2SS/RS
Taking out the stock amp and upgrading to a different 5 channel amp so I can add a sub, will the current wiring be able to be used or will I need to rewire things? Ive never changed stuff out like this before
