Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires
Old 05-22-2012, 10:34 PM   #1
hansolo79
hansolo79's Avatar
Drives: 2012 Camaro 2LS
Tire size opinion
Purchased a 2012 LS about 2 months ago and i'm looking to change out the stock black wheels. I'm pretty sure i'll go with TSW Vairano. The hard part is, trying to find the right size tire to where i don't have to lower the care. I was thinking of doing a setup of 245/35 or 40/20 all the way around. Do you guys/gals think that would work? Would a staggered setup be better?
hansolo79 is offline   Reply With Quote
Old 05-22-2012, 10:43 PM   #2
The Stig
I used to be Stieger....
The Stig's Avatar
Drives: a PBM camaro
Originally Posted by Nine Ball View Post
I will list tire sizes that are similar to OEM diameter, as this should help tire shoppers. The heights shown below are approximate, based on calculations. Refer to tire manufacturer's specs for the most accurate tire diameters. We recommend you stay within 0.5" (plus or minus) of the factory tire height in order to maintain accurate vehicle systems. This gives you an acceptable range of 28.2-29.3" diameters. Wheel widths shown are recommended, and only serve as a suggestion for proper fitment/appearance/performance.
Factory 2010 Camaro SS tires and wheels
Front 245/45-20 = 28.7" tall, 8.0 wheel
Rear 275/40-20 = 28.7" tall, 9.0 wheel
Factory 2012 Camaro ZL1 tires and wheels
Front 285/35-20 = 27.9" tall, 10.0 wheel
Rear 305/35-20 = 28.4" tall, 11.0 wheel
Recommended 18" Tires for 2010 Camaro
245/55-18 = 28.6" tall, 8.0-8.5 wheel
255/55-18 = 29.0" tall, 8.0-8.5 wheel
265/50-18 = 28.4" tall, 8.5-9.0 wheel
275/50-18 = 28.8" tall, 9.0-9.5 wheel
285/45-18 = 28.1" tall, 9.5-10.0 wheel
295/45-18 = 28.5" tall, 10.0-10.5 wheel
305/45-18 = 28.8" tall, 10.0-11.0 wheel
315/45-18 = 29.2" tall, 10.5-11.0 wheel
Recommended 19" Tires for 2010 Camaro
245/50-19 = 28.7" tall, 8.0-8.5 wheel
255/50-19 = 29.0" tall, 8.0-8.5 wheel
265/45-19 = 28.4" tall, 8.5-9.0 wheel
275/45-19 = 28.7" tall, 9.0-9.5 wheel
285/45-19 = 29.1" tall, 9.5-10.0 wheel
295/40-19 = 28.3" tall, 10.0-10.5 wheel
305/40-19 = 28.6" tall, 10.0-10.5 wheel
315/40-19 = 29.0" tall, 10.5-11.0 wheel
Recommended 20" tires for 2010 Camaro
245/45-20 = 28.7" tall, 8.0-8.5 wheel
255/45-20 = 29.0" tall, 8.0-8.5 wheel
265/40-20 = 28.4" tall, 8.5-9.0 wheel
275/40-20 = 28.7" tall, 9.0-9.5 wheel
285/40-20 = 28.9" tall, 9.0-10.0 wheel
295/35-20 = 28.1" tall, 9.5-10.5 wheel
305/35-20 = 28.4" tall, 10.0-10.5 wheel
315/35-20 = 28.7" tall, 10.5-11.0 wheel
Recommended 21" tires for 2010 Camaro
245/40-21 = 28.7" tall, 8.0-8.5 wheel
255/40-21 = 29.0" tall, 8.0-8.5 wheel
265/35-21 = 28.3" tall, 8.5-9.0 wheel
275/35-21 = 28.6" tall, 9.0-9.5 wheel
285/35-21 = 28.9" tall, 9.5-10.0 wheel
295/35-21 = 29.1" tall, 10.0-10.5 wheel
305/30-21 = 28.2" tall, 10.0-11.0 wheel
315/30-21 = 28.4" tall, 10.5-11.0 wheel
Recommended 22" tires for 2010 Camaro
245/35-22 = 28.8" tall, 8.0-8.5 wheel
255/35-22 = 29.0" tall, 8.0-8.5 wheel
265/30-22 = 28.3" tall, 8.5-9.0 wheel
275/30-22 = 28.5" tall, 9.0-9.5 wheel
285/30-22 = 28.8" tall, 9.5-10.0 wheel
295/30-22 = 28.9" tall, 9.5-10.5 wheel
305/30-22 = 29.2" tall, 10.0-11.0 wheel
315/25-22 = 28.2" tall, 10.5-11.0 wheel
Recommended 24" tires for 2010 Camaro
245/25-24 = 28.8" tall, 8.0-8.5 wheel
255/25-24 = 29.0" tall, 8.0-8.5 wheel
265/20-24 = 28.2" tall, 8.5-9.0 wheel
275/20-24 = 28.3" tall, 9.0-9.5 wheel
285/20-24 = 28.5" tall, 9.5-10.0 wheel
295/20-24 = 28.7" tall, 10.0-10.5 wheel
305/20-24 = 28.8" tall, 10.0-10.5 wheel
315/20-24 = 29.0 tall, 10.5-11.0 wheel
Hope that helps!
Tony
here you go
Stieger's BLACK Build Thread thanks for the sig Russ
Old 05-23-2012, 09:40 AM   #3
hansolo79
hansolo79's Avatar
Thank you. BTW, nice ride.
