BORLA
Old 07-07-2012, 01:03 PM   #197
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
I'm feeling your pain brother. I'm running rich at 10 when in 3rd at mid RPM also. I can actually feel the car pulling back the power. But she still running strong enough. I would go to Vengeance Racing and get mine tuned. But you get more flexibility with Trifecta.
Sent from my iPhone 4s using Tapatalk
Can't_C_Me is offline   Reply With Quote
Old 07-07-2012, 01:10 PM   #198
MACE_ENG
MACE_ENG's Avatar
Drives: LLT Machine
Chris, get the tune straight with vince and see if it get any better. AFR in the 10's seem too rich. At what RPM are you seeing the 10's by the way?
I didn't even realize you already got the car back and out on the track. Good for you!
Jay@Mace Engineering USA
Velocityport410@gmail.com
Home of the 31hp/33tq Ported intake/25mm Insulator!
MACE_ENG is offline   Reply With Quote
Old 07-07-2012, 01:19 PM   #199
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Yeah I've had the car back for less than 2 weeks, haha.
AFR in the 10's is VERY rich, Tracy and Vince were saying it should be mid 11's and even 12 is OK. So you figure that, and this thing is pig rich...
TBH I'm not too sure when the really rich 10's kick in. I was focused on watching so many different gauges, AND the road which is why I mounted the camera lol. I reviewed the video again and I'd say around 3,000 rpms. 3rd gear is such a long gear and compared to first and second just feels like a wimp
BaylorCamaro is offline   Reply With Quote
Old 07-07-2012, 03:35 PM   #200
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
***UPDATE***
OK, so I got an email from Vince just now and reviewed a couple of data logs I took at the drag strip. His exact response "Your fuel system isn’t holding up. 1st is OK, but 2nd is worse, and 3rd is really bad." So it looks like I either need to get the normal pulley from Tracy OR get the high pressure fuel pump. However Vince told me (a few weeks ago) that the tune for the HPFP hasn't been figured out yet and he honestly doesn't even know if it will work.
So it appears to me that we (anyone with an OD pulley) are in a bit of a pickle...
Old 07-07-2012, 03:40 PM   #201
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Originally Posted by BaylorCamaro View Post
***UPDATE***
Ok.. that makes absolutely NO SENSE... You were running RICH, NOT LEAN! If the HPFP wasn't holding up your car would be going lean!
scrming is offline   Reply With Quote
Old 07-07-2012, 03:43 PM   #202
scrming
scrming's Avatar
Looking at my setup I start in the low 12s and then the AFR works it way down to the upper 11s...
Old 07-07-2012, 05:14 PM   #203
ASH@IPF-TUNING
ASH@IPF-TUNING's Avatar
Drives: 4x4 Turbo
Hi !
When the HPRailpump gets Pressure deviation more then 20 bar , the ECU will go into LIMP-MODE and close the trottle-body for engine protection !
When you allow the HighPressure System more pressure deviation to keep the ECU out of the limp mode the AFM WILL GO LEAN anyway and not RICH !
To adapt the HPFP is an easy job with only a dozen maps to change , but when the new Railpump piston ist WAY tooo big , then you need to modify the rail pressure control valve , to prevent too high Railpressure at idle with fully open original rail pressure control valve or make the new Railpump piston smaller !!
that effect cant fixed by Software ... only in the hardware !
Greets ASH@IPF-TUNING
ASH@IPF-TUNING is offline   Reply With Quote
Old 07-07-2012, 06:45 PM   #204
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Well I don't have the HPFP, I'm saying if there is an issue with the fuel system not keeping up I might need the HPFP. However you bring a good point and I emailed Vince asking how the heck I'm running really rich IF the fuel system isn't keeping up..
This has me very confused
Old 07-07-2012, 06:52 PM   #205
scrming
scrming's Avatar
You have a HPFP, it is just the STOCK one.
Old 07-07-2012, 07:28 PM   #206
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Ok well those of us who still have a Camaro Refer to the aftermarket fuel pump as the HPFP. That's why I was confused.
Old 07-07-2012, 08:12 PM   #207
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
So, are you spraying meth? If so, how much and is it 100%?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 07-07-2012, 09:18 PM   #208
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Derrick has a good point. If you spraying you need to go 50/50 or turn it off and run it. This will let you go lean a little more.
Old 07-07-2012, 10:39 PM   #209
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
Nope, BUT I am using the super chiller, which gets my IAT temps to mid 60's low 70's
Old 07-08-2012, 08:22 AM   #210
GretchenGotGrowl
Were you measuring the AFR with a sniffer as well as your wideband when you had it on the dyno? If so, did they read close to the same?
